Old Jan 19, 2004, 12:36 AM
galloping gimp is offline
Find More Posts by galloping gimp
galloping gimp's Avatar
Ohio, USA
Joined May 2002
Glenn-
My admittedly rudimentary understanding is that a Star winding is more suited to direct drive, while a Delta winding is more suited to a geared drive.
To generalize, all else being equal, the Star winding provides lower RPM but more torque, which helps in turning a prop without a gearbox. The Delta winding produces higher RPM but less torque, so a gearbox may be necessary to use the same prop.
Perhaps one of the more knowledgeable posters will confirm this.
Your description of how to test the windings sounds just right. That's how I did it.
- Jeff
galloping gimp is offline Find More Posts by galloping gimp
Old Jan 19, 2004, 12:51 AM
JRW21 is offline
Find More Posts by JRW21
JRW21's Avatar
Dunlap, Illinois, United States
Joined Aug 2003
I don't consider myself more "knowledgeable" but you are correct jeff.
JRW21 is offline Find More Posts by JRW21
Old Jan 19, 2004, 01:14 AM
rysium is offline
Find More Posts by rysium
Why not Delta?
rysium's Avatar
Sacramento, CA
Joined Jun 2003
Someone posted here, that star is more dificult to work for ESC. What is the story with that?
I need to wind a small 19g direct drive motor for my mini (micro) Ultimate Biplane (16 in wingspan, aiming at about 4-5 oz RTF weight). Because I don't want any gearbox therefore I will need every bit of torque I can get, so help me out with it, please.
I need the motor to be able to turn the biggest prop that is possible (Max static thrust) using no more than 5A from 2s 350 LiPo.
RysiuM
rysium is offline Find More Posts by rysium
Old Jan 19, 2004, 01:45 AM
Ohio, USA
Joined May 2002
RysiuM-
I, too, have read that the Star winding is more difficult for the controller to handle. I've also read that the problem is less likely to occur if you replace the ring magnet with stronger magnets, as so many of us have done.
ESCs with adjustable timing can help, too.
That said, my CD-ROM brushless with Star winding worked fine with my (non-adjustable) Jeti 08-3P controller, even with the stock ring magnet. It worked better (less current, cooler operation) when I replaced the ring magnet with 12 N45 magnets.
I think you can only experiment and see what happens.
- Jeff
Old Jan 19, 2004, 01:56 AM
Matthew Cotten is offline
Find More Posts by Matthew Cotten
Joined Oct 2003
I had trouble with a low wind hot motor that I put N45s in and going from medium speed start up to slow start solved the problem.It would just jitter if I quickly went from no throttle to full.I could get it to start but only if I wiggled the throttle at start up then once it started it would run fine but would suck on a plane.Matt
Matthew Cotten is offline Find More Posts by Matthew Cotten
Old Jan 19, 2004, 02:04 AM
ssatoru is offline
Find More Posts by ssatoru
ssatoru's Avatar
Chiba, Japan
Joined Jan 2002
double wire
Originally posted by soundman
Some people have been double winding.....what effect does double (or more) winding have, examples:
a 30 turn single wind motor vs a 30 turn double wind motor.
a 30 turn single wind motor vs a 15 turn double wind motor.
soundman
Let me try to explain. I am not 100% sure about it. Please anyone give correction. Actually I use double turn mostly to have more variety from less variant of wire.
0.3 mm dia wire double is about the same as 0.4 mm wire. i.e. Cross section area is about the same.
((0.3mm / 2) ^2 * pi * 2 = 0.141 mm2, (0.4mm / 2) ^2 * pi = 0.126 mm2).
If the area section of copper is the same (for example filled fully), 30 turn double will be the same as 30 turn single.
Some say you can wind smaller wire more than thicker wire but it is not true. (There is a chance you can fill the gap of edge near the winding area with smaller wire though.)
Some say it is better to have more surface area and double wire does have more surface area. I am not sure of this effect.
Satoru
ssatoru is offline Find More Posts by ssatoru
Old Jan 19, 2004, 06:40 AM
GIFLYRC is offline
Find More Posts by GIFLYRC
GIFLYRC's Avatar
INDEPENDENTLY POOR in OHIO
Joined Dec 2001
Satoru
TRUE.
and this is because electrons are lazy seeking the path of least resistance so that they avoid flowing through the center of the wire and prefer to flow near the outer surface----therefore a double wind increases the surface area about 33 % vs. / single wind.
Roger aka GIFLYRC
GIFLYRC is offline Find More Posts by GIFLYRC
Old Jan 19, 2004, 06:51 AM
GIFLYRC is offline
GIFLYRC's Avatar
Joined Dec 2001
Depdog
You are correct about checking continuity--
check the wires and between wires using R x 1
check the wires to the stator using R x ( the highest setting on your meter) looking for high resistance shorts that break down under power
Keep in mind that you can read continuity through your body at this high setting so avoid contact with the meter probes
Roger aka GIFLYRC
Old Jan 19, 2004, 06:59 AM
soundman is offline
Find More Posts by soundman
soundman's Avatar
Norfolk, UK
Joined Jul 2002
So would I be right in saying that if you compare a 30 turn single wind with a 30 turn double wind - they would both have the same rpm & power characteristics, but the double wind would be more efficient?
soundman is offline Find More Posts by soundman
Old Jan 19, 2004, 09:05 AM
GIFLYRC is offline
GIFLYRC's Avatar
Joined Dec 2001
Quote
soundman
I don't know the answer to that one and perhaps the only way to find out would be to wind two identical stators one with a single wire and the other with a double wind and then compare results
Roger aka GIFLYRC
Old Jan 19, 2004, 09:36 AM
ronin8451 is offline
Find More Posts by ronin8451
E-Flight Addict
ronin8451's Avatar
Weatherford, Tx.
Joined Oct 2003
From my days racing electric cars, a double wind would have more torque vs the single wind, but the single will have slightly more RPM's.
I have a problem which I believe is in my quantity of magnets. I have the large stator Toshiba drive with bearings that I rewound to 27 turn single with #26 wire (green Radio shack) "Star" config. and put 8 n45 magnets in the bell N-S-N-S-N-S-N-S at 45 degree increments. The motor stutters at start then will only go to 1/3 throttle and the esc shuts down. Amp readings are no more than .6 amps. Should the number of magnets be greater than stator poles, ie.: 12 magnets to 9 poles ? My friend and I have the exact same problem and have gone to 4 magnets and it does the same. HELP!
Rick
ronin8451 is offline Find More Posts by ronin8451
Old Jan 19, 2004, 11:34 AM
Rad Racer is offline
Find More Posts by Rad Racer
Hi Wattage Electrics - Cool
Rad Racer's Avatar
Jordan, Minnesota
Joined Jan 2004
I struggled with the same question. What I found was that with 12 magnets like everyone uses, you only have the 3 "energized" motor poles directly lined up with magnets at any given time. i.e. 120 deg apart. So, when you look at other magnet counts, you'll find this also happens with a count of 6.... not 8 or 10. I am not a real math guy, but it's a trig. thing. I layed down some lines in CAD to verify this is true.
I hope I explained this well enough.... it's easy to see on paper, kinda tough to describe in words.
Wayne
Rad Racer is offline Find More Posts by Rad Racer
Old Jan 19, 2004, 11:42 AM
E-Flight Addict
ronin8451's Avatar
Weatherford, Tx.
Joined Oct 2003
I thought so, I started scratching my head and thinking about it and figured a 6 or 12 count would be better. I used 8 instead of 12 because allelectronics shorted me 2 magnets so I only have 10 instead of 12. I am going to order some from engconcepts today so I can make a bigger "bell" to fit thicker magnets. Thanks for the help!
Old Jan 19, 2004, 11:43 AM
Rad Racer's Avatar
Jordan, Minnesota
Joined Jan 2004
So to take magnet count a step further.... I think any of the following magnets counts would work.
3 magents = 120 deg apart
6 magents = 60 deg
12 magnets = 30 deg
24 magnets = 15 deg
48 magnets = 7.5 deg
Wayne
Old Jan 19, 2004, 11:56 AM
Depdog is offline
Find More Posts by Depdog
Foam Flyer
Depdog's Avatar
Stockbridge, Georgia, United States
Joined Jan 2003
Roger Gantz
I know next to nothing about electronics. I do have a good multi meter (but have not much of a clue on how to use it) I know what the D/C, A/C, Ohm's, Continuity settings are, but sometimes not sure how to use the OHM's.
What is R?
Glenn
Depdog is offline Find More Posts by Depdog
One hour CD ROM construction part 7 rysium Power Systems 806 Dec 18, 2006 03:58 AM
One hour CD ROM construction part 6 arx_n_sparx Power Systems 1050 Mar 10, 2005 08:08 PM
One hour CD ROM motor construction PART 4!! t-turley Power Systems 555 Jun 07, 2004 08:33 PM
One Hour CD ROM Construction Part 5 arx_n_sparx Power Systems 537 May 07, 2004 10:56 AM
One hour CD ROM motor construction PART3 rysium Power Systems 511 Mar 22, 2004 02:03 PM
