Old Jan 10, 2004, 01:34 PM
rysium is offline
Find More Posts by rysium
Why not Delta?
rysium's Avatar
Sacramento, CA
Joined Jun 2003
Originally posted by Acer
You should get more thrust and less amp draw when you change out the magnets. Mine went from turning a 4.75x4.75 prop at 15,000 r.p.m. at 9.7A to turning the same prop at 16,200 r.p.m. at 8.5A.
By giving stronger magnets you will have two things:
1 - when you have a stronger magnetic field on the rotor, you can have the same torque with less current on the stator = better efficiency
2. stronger magnets in rotor causes lower motor's rpm/V with the same power so if you run the same current you will get more torque. Using the same gearbox you can put bigger prop and have more static thrust using the same power (it's the same result as you put additional gearing.
RysiuM
rysium is offline Find More Posts by rysium
Old Jan 10, 2004, 01:40 PM
galloping gimp is offline
Find More Posts by galloping gimp
galloping gimp's Avatar
Ohio, USA
Joined May 2002
Cranky-
There are several ways to construct and mount a converted CD-ROM motor.
In some designs, the stator is mounted directly to a flat bulkhead or firewall. See post #202 above.
Some builders have even left the stator attached to its circuit board from the CD-ROM, then attached the circuit board to the airplane. See the first page of the original "One hour CD_ROM motor construction" thread.
In other designs, a tube of metal or other material is attached to the stator, and the tube is somehow affixed to a firewall or motor mount. See post #207 above. Depending on the materials involved, builders have used CA, epoxy, and other adhesives to attach the tube to the stator.
My choice was to retain the original brass stator hub and solder a short piece of brass tubing to it. See photo below. This resulted in a fairly heavy motor, but it was easy to do with minimal tools. I have yet to see how well it works in an airplane, but it generates at least as much thrust as an IPS.
Everyone's solution is a little different, based on their own skills and tools, the kind of plane they are flying, and the details of the CD-ROM components.
- Jeff
galloping gimp is offline Find More Posts by galloping gimp
Old Jan 10, 2004, 03:26 PM
Matthew Cotten is offline
Find More Posts by Matthew Cotten
Joined Oct 2003
Hi Jeff,just wondering if you still get good performance with the motor you have pictured above with all the space between the magnets and stator heads.Nice looking motor.Matt
Matthew Cotten is offline Find More Posts by Matthew Cotten
Old Jan 10, 2004, 03:51 PM
crvogt is offline
Find More Posts by crvogt
RIP "Long Shadow Flyer"
crvogt's Avatar
Upstate New York-- Rochester, NY USA
Joined Oct 2001
Working on my first conversion, made a scrounging raid on the local ACE hardware, looking for someting aluminum to turn on a lathe or fashon into a motor mount.... In the specialty nuts and bolts drawers found " Weld Nuts" #10, 1/4... looks like it may do the trick. I plan on inserting a GWS bushing into the threads to help align the parts while the Epoxy sets, will coat the shaft with white lithium grease to prevent sticking... Will keep you posted on results and which size works best. These are a common item at ACE, Home Depot and Lowes. The shaft is one of the laser positioning slides, 3mm. neat!!!
Carl
crvogt is offline Find More Posts by crvogt
Old Jan 10, 2004, 04:06 PM
Franck is offline
Find More Posts by Franck
-plancks only-
Franck's Avatar
The Netherlands, UT, Benschop
Joined Oct 2001
Acer,
What nr. of turns did you use ?
Jeff,
You have some mighty airgaps shown on the picture!
Regards,
Franck
Franck is offline Find More Posts by Franck
Old Jan 10, 2004, 06:26 PM
GIFLYRC is online now
Find More Posts by GIFLYRC
GIFLYRC's Avatar
INDEPENDENTLY POOR in OHIO
Joined Dec 2001
t-turley
Quote....My tach indicates 3600 with the lights on, so I have to turn off all of the lights and try to get the readings by flashlight.
Tony, your tach is reading the 60 cycle flicker from the lights and is a good way to check the calibration of your meter
I set up the flashlight to shine through the prop and take my reading from the front
I also mount the prop as a pusher so that it does not fly off (anymore ) having been hit in the side once ( it cut me right through the shirt!! )
You mentioned small bearings, Where did you get them?
I have not yet found a CDR motor with bearings and I have disassembled nearly 60 motors so far
Roger aka GIFLYRC
GIFLYRC is online now Find More Posts by GIFLYRC
Old Jan 10, 2004, 06:32 PM
Rad Racer is offline
Find More Posts by Rad Racer
Hi Wattage Electrics - Cool
Rad Racer's Avatar
Jordan, Minnesota
Joined Jan 2004
My motor bell has room for (16) 5x5x1 magnets, will this work with a 9 pole motor?
Somewhere in this thread, I think I read that motor poles must be a multiple of 3, and magnets must be a multiple of 2....is this correct?
Rad Racer is offline Find More Posts by Rad Racer
Old Jan 10, 2004, 07:19 PM
rysium is offline
Why not Delta?
rysium's Avatar
Sacramento, CA
Joined Jun 2003
Out of 32 cd-roms types I found so far 8 types with BB.
Here is the list of CD-ROMS with BB. If shaft is 3mm, motor uses 3x6x2.5 BB, for shaft 2mm the B is 2x4x2
RysiuM
Old Jan 10, 2004, 07:52 PM
CrazEflyer is offline
Find More Posts by CrazEflyer
CrazEflyer's Avatar
olympia, Wa
Joined Sep 2003
Hi
I have a cd-rom motor that i have converted, and it shuters at half throtle and it all so gets very hot.
The cd-rom motor is a sony 56x with a thin gray magnet.
I put 16 turns of 22 or 24 guage wire Y wind on it and instaled ball bearings.
Do any of you know what i could do diffrent to fix it.
CrazEflyer is offline Find More Posts by CrazEflyer
Old Jan 10, 2004, 07:55 PM
t-turley is offline
Find More Posts by t-turley
Joined Mar 2001
Here's a shot of my 2 latest rewind efforts: I finished rewinding the big 44mm guy just this afternoon, with 15T of #20. Pulls 11.5A from 7 cells on an APC 9x6 SF. I still haven't figured how to get good, consistent readings on my tach when using it indoors, but I did get a transient reading that said 12,000. That sounds too high to me, although it is clearly spinning the prop much faster than it did with 23T of #22.
The 22mm micro is wound with 10T of dual-strand #26. It screams like a banshee with the Gunther black 5x5, but doesn't like anything above about 3/4 power. I'm hoping the N45s will help change that. I ordered the 5 x 1.5 x 1mm magnets, to be installed in NN SS NN, etc pairs.
Tony Turley
t-turley is offline Find More Posts by t-turley
Old Jan 10, 2004, 08:02 PM
t-turley is offline
Joined Mar 2001
t-turley
Roger aka GIFLYRC
Roger,
Thanks for the tip on the tach. As for the bearings, I've found a couple that had ball bearings in them; one was actually an ancient 4X drive, with a pair of really nice bearings - which I've since lost in 2 separate mishaps! My LHS can also order 3x6mm bearings for me.
Tony Turley
Old Jan 10, 2004, 10:27 PM
rysium is offline
Why not Delta?
rysium's Avatar
Sacramento, CA
Joined Jun 2003
Originally posted by CrazEflyer
Hi
I did almost the same - motor didn't run more than half throttle and was very hot - indicates short somewhere in winding.
I rewound it and was fine, but with 18T didn't run on 3 cells full throttle. When replaced magnets, it run without the problem.
So first - check if you have short somewhere before you do anything else. It's common that enamel on the wire gets broken and wire gets short to stator.
What I do, I paint with enamel all the stator's surface where the wire might touch it - it makes the surface smooths and soft, so it doesn't hurt the wire's insulation while you wind it.
RysiuM
Old Jan 10, 2004, 11:15 PM
CrazEflyer's Avatar
olympia, Wa
Joined Sep 2003
Thank you RysiuM i will try that.
Old Jan 10, 2004, 11:48 PM
ssatoru is offline
Find More Posts by ssatoru
ssatoru's Avatar
Chiba, Japan
Joined Jan 2002
Wing rules!
-- Acer
http://speedwing.net
Conguratulation on CDROM motor, Acer. Nice mount. I have been flying my CDROM motor on a Depron small wing (MH60 airfoil, inspired by CLiC) for a while. I think wing is very suited for these powerful motors. Mine takes about 90-105W with ET1200 3S, can climb 218g vertical to out of sight in 15 seconds, can do 'active' knife edge.
Isn't your motor getting too hot? Mine got too hot to melt soldering with that wattage. You might want to try DoppelWhopper.
Satoru
ssatoru is offline Find More Posts by ssatoru
Old Jan 11, 2004, 02:18 AM
Ohio, USA
Joined May 2002
Some of you asked about the apparent large gap between the magnets and stator in my CD-ROM conversion.
The gap is smaller than it appears from the photo I posted earlier in this thread. Something about the camera angle and lighting made the gap appear larger than it actually is. The photo below shows the actual gap, which is about 0.5mm.
Motor configuration:
stator diameter: 24mm
rotor outer diameter: 28.8mm
26 turns, #26 (~4mm) wire
winding: "star" (seeking torque rather than RPM)
prop shaft: 3mm GWS IPS
ball bearings: two 6x3mm (from IPS)
weight: 28g
Tested with:
GWS 9x7 prop (smallest prop I own)
370 mAH 8.4V NiMH battery packs (only battery packs I own)
Jeti 08-3P controller
The static performance measured so far:
With original ring magnet
3.5 ounces (~100g) thrust @ 4.5A
With 5x5x1 N45 magnets
4.9 ounces (~139g) thrust @ 4.3A
While running with the stock ring magnet, the motor got very hot and drew so much current that the battery pack voltage decreased to the low voltage cutoff point of the Jeti controller, which then shut down. After installing the N45 magnets, the current draw was reduced, the battery voltage stayed above the LVC point, and the motor got warm but not hot.
I'm sure it will do better with smaller props, which I do not have yet. I am considering:
GWS RS 8x4.3
GWS HD 8x4 or 9x5
Do you have any suggestions or other recommendations for props or anything else?
I know I am seriously stressing the battery packs, but they are all I own at this time. Li-Polys are probably the way to go.
- Jeff
One hour CD ROM construction part 7 rysium Power Systems 806 Dec 18, 2006 02:58 AM
One hour CD ROM construction part 6 arx_n_sparx Power Systems 1050 Mar 10, 2005 07:08 PM
One hour CD ROM motor construction PART 4!! t-turley Power Systems 555 Jun 07, 2004 07:33 PM
One Hour CD ROM Construction Part 5 arx_n_sparx Power Systems 537 May 07, 2004 09:56 AM
One hour CD ROM motor construction PART3 rysium Power Systems 511 Mar 22, 2004 01:03 PM
