Old Jan 05, 2004, 12:34 AM
rysium is offline
Find More Posts by rysium
Why not Delta?
rysium's Avatar
Sacramento, CA
Joined Jun 2003
I love these CD-ROM motors
The plane I have with it (Mini Depron Edge 540 Profile) has more relative power than the original Big Brother with Razor 300 (mini is 75% linear scaled down and weights a half of it's big brother), giving me over 12 minutes of 3D on 3x700 LiPo. I call it E-Z 3D trainer
Now back to the subject.
I have stripped down already over 30 CD-ROMS evaluatiing motors in there. The attached ZIP file has an Excel spreadsheet of 28 different CD-ROM models with some information what kind of motor is in there and some comments about conversions.
If you guis can add some more models I'll be glad to add it to this database. This will help me pick the right CD-ROM for demolition
RysiuM
rysium is offline Find More Posts by rysium
Old Jan 05, 2004, 12:44 AM
Matthew Cotten is offline
Find More Posts by Matthew Cotten
Joined Oct 2003
It says the zip file is corupted?Couldn't get in,might be my machine though.Matt
Matthew Cotten is offline Find More Posts by Matthew Cotten
Old Jan 05, 2004, 02:27 AM
Takao Shimizu is offline
Find More Posts by Takao Shimizu
Tokyo, Japan
Joined Nov 2002
Cheesehead,
>Now, if someone had a good design for a homemade ESC....
I am debugging now. And I recieve a lot e-mails about my schematic.
This is the hint of my CD-ROM BL ESC design.
Takao
Takao Shimizu is offline Find More Posts by Takao Shimizu
Old Jan 05, 2004, 06:40 AM
t-turley is offline
Find More Posts by t-turley
Joined Mar 2001
Scott,
Where did you find 24 magnets small enough to keep the weight that low?
Tony Turley
t-turley is offline Find More Posts by t-turley
Old Jan 05, 2004, 08:26 AM
Littlescreamers is offline
Find More Posts by Littlescreamers
Edmonds Wa. (Seattle)
Joined Nov 2003
I made them!
Scott
Littlescreamers is offline Find More Posts by Littlescreamers
Old Jan 06, 2004, 12:48 PM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
Originally posted by Cheesehead
... Now, if someone had a good design for a homemade ESC....
Six brushless diy designs:
http://www.rcgroups.com/forums/showt...hreadid=140454
Originally posted by rcflyer2
Thought you all may want to see the latest to come out of the Little Screemers shop! ...
Plenty of space left in the slots. Thicker wire are two/three wires in parallel will improve efficiency, at the cost of weight of course.
Groeten Ron
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Jan 06, 2004, 09:55 PM
crvogt is offline
Find More Posts by crvogt
RIP "Long Shadow Flyer"
crvogt's Avatar
Upstate New York-- Rochester, NY USA
Joined Oct 2001
Having attempted to read ALL the post on the subject, Looks like I want to give this a try. IF I undersand the needed items to add to the parts list is a roll of 30 Ga magnet wire ( between the 26g - 32ga people have used) and some 5x5x1mm magnets. Am I correct if I get these item I should be able to create a usable motor??? Assumeing I have the winding skill, etc.
Carl
crvogt is offline Find More Posts by crvogt
Old Jan 06, 2004, 10:20 PM
Joined Oct 2003
Yes,there are larger and small cd rom motors,smaller ones fit 1mm mags and larger ones fit 1.5mm to 2mm mags.Some of the motors have bad spacing and it makes it hard to just glue in magnets.You'll find a good one in 5 or so.Matt
Old Jan 07, 2004, 12:18 PM
t-turley is offline
Joined Mar 2001
I found a really sweet little motor in a defunct CD-RW drive. The stator is only 18 mm in diameter, and is twice the height of other CD-ROM stators I've seen. It only has bushings, but has a nice machined center that will hold bearings after the one-piece bushing is pushed out. Looks like it should be a torquey little motor.
Tony Turley
Old Jan 07, 2004, 03:47 PM
galloping gimp is offline
Find More Posts by galloping gimp
galloping gimp's Avatar
Ohio, USA
Joined May 2002
Carl-
You have the basic concept. As Matt pointed out, it's the details that can make the conversion challenging.
My recommendation is to find a surplus CD-ROM drive and take it apart. At that point, make some photos and post them here, and allow the collected knowledge of this forum to advise you further.
I was lucky in that the first and only drive I disassembled was perfect for conversion. I used #26 magnet wire from radio shack and 5x5x1 N45 magnets from Engineering Concepts.
- Jeff
galloping gimp is offline Find More Posts by galloping gimp
Old Jan 07, 2004, 04:48 PM
Joined Nov 2003
Jeff,
You know I have been having trouble with the 5x5x1 in some of the really little motors and I ordered some 5x5x.9 to fit in there.
Last motor had 24 magnets as I had to snap them in half to get them to fit (what a pain)
I will find the site and post it.
P.S.
Is a N45 a 80C Cus the ones I got commin are 120C ?
rcflyer2
Old Jan 07, 2004, 05:20 PM
Ohio, USA
Joined May 2002
rcflyer2-
I saw your post showing the motor with the 24 half-magnets. Nice job.
The N45 magnets from Engineering Concepts are rated at 80C. George's site also says:
"Also available in N42 SH if operating temperatures will exceed 80 C. Price is the same as the N45."
The site doesn't mention the temperature rating. I'm sure an e-mail to George would produce that info.
- Jeff
Old Jan 07, 2004, 07:01 PM
Joined Nov 2003
Well I did some testing and this is what I get
Motor is wound with 22 wraps of 26gauge wire stock grey ring magnet and test was done with a 2s1p E-Tech 1200s
This is a Brushless full bearing Custom Cd-conversion motor:
fully tested and ran at 1/3throttle 1A ,9W, 7.1volts. for 53min, No stutters or hesitations, Clean throttle responce throughout complete range and No detectable heat at all! NONE!
WOT test with a zagi prop 5 1/4 x ?
Total weight: 24 grams
1st Test:
Thrust= 7.3oz WOT
amps=9 WOT
volts=8.4 WOT
2nd Test with 6030 prop
Thrust=10.1oz WOT
amps= 5.5 WOT
volts= 6.7 WOT
This is the prop for this motor!
Still waiting for my new Tach to show up.
Little Screemers!
Scott
matt
rcflyer2
Old Jan 07, 2004, 07:03 PM
Joined Nov 2003
pic
Old Jan 07, 2004, 08:45 PM
t-turley is offline
Joined Mar 2001
My mini:
Pic 1 shows the untouched original @ 1.5oz / 40g. The second shows the innards. #3 shows the unnecessary junk stripped away, and a new shaft inserted in the hub. Result so far: .75oz / 22g! Sorry for the poor quality pics - I'm temporarily between "good" digicams, and have to use a cheapie pencam.
Tony Turley
One hour CD ROM construction part 7 rysium Power Systems 806 Dec 18, 2006 02:58 AM
One hour CD ROM construction part 6 arx_n_sparx Power Systems 1050 Mar 10, 2005 07:08 PM
One hour CD ROM motor construction PART 4!! t-turley Power Systems 555 Jun 07, 2004 07:33 PM
One Hour CD ROM Construction Part 5 arx_n_sparx Power Systems 537 May 07, 2004 09:56 AM
One hour CD ROM motor construction PART3 rysium Power Systems 511 Mar 22, 2004 01:03 PM
