Old Dec 29, 2003, 07:33 AM
Littlescreamers is online now
Find More Posts by Littlescreamers
Edmonds Wa. (Seattle)
Joined Nov 2003
all done!
Littlescreamers is online now Find More Posts by Littlescreamers
Old Dec 29, 2003, 04:46 PM
Takao Shimizu is offline
Find More Posts by Takao Shimizu
Tokyo, Japan
Joined Nov 2002
rcflyer2,
Wow, well done!
Did you use almost pure iron as magnetic back york for magnet can?
Takao
Takao Shimizu is offline Find More Posts by Takao Shimizu
Old Dec 29, 2003, 09:15 PM
Joined Nov 2003
This is a stock can and all I made is the mount!
The stator is plastic with 100 wraps of very fine wire I got 20T of 30g wire on it now, But have not tested it yet.
I also drilled 3 mounting holes and taped the for 4-40 to mount through the firewall.
Thanks and I'll post pics when it's done.
Scott
Old Dec 31, 2003, 09:26 AM
Joined Nov 2003
complete!
Old Dec 31, 2003, 09:40 AM
azfrench is offline
Find More Posts by azfrench
Tucson Avra Valley, Arizona, United States
Joined Nov 2003
when replacing the magnets, what type of CA are you using to keep them secure. I saw it somewhere but this thread is HUGE. Thanks.
azfrench is offline Find More Posts by azfrench
Old Dec 31, 2003, 05:49 PM
Tokyo, Japan
Joined Nov 2002
azfrench,
I use thin CA for metal glueing.
http://www.rcgroups.com/forums/showt...59#post1279959
Takao
Old Dec 31, 2003, 09:10 PM
Matthew Cotten is offline
Find More Posts by Matthew Cotten
Joined Oct 2003
Hi folks,will the magnets pull keep the bell from pulling off when throttled up on a cd rom set up as a puller?Thanks.Matt
Matthew Cotten is offline Find More Posts by Matthew Cotten
Old Dec 31, 2003, 09:53 PM
ssatoru is offline
Find More Posts by ssatoru
ssatoru's Avatar
Chiba, Japan
Joined Jan 2002
Yes, it stays there if it is well ballanced.
Satoru
ssatoru is offline Find More Posts by ssatoru
Old Dec 31, 2003, 10:41 PM
Joined Oct 2003
Thank you Satoru,GREAT!!Matt
Old Dec 31, 2003, 11:25 PM
Robbie d is offline
Find More Posts by Robbie d
Crazy Cessna Owner
Robbie d's Avatar
Australia, SA, Windsor Gardens
Joined May 2001
that looks pretty good scott. an easy way to mount them.
Robbie d is offline Find More Posts by Robbie d
Old Jan 01, 2004, 08:15 AM
Cheesehead is offline
Find More Posts by Cheesehead
Ego varius quis.
Cheesehead's Avatar
Wisconsin
Joined Nov 2003
Could someone please compare the efficiency to Uberball's nippy motors?
I just wanted to know how they compare.
Cheesehead is offline Find More Posts by Cheesehead
Old Jan 01, 2004, 12:34 PM
Joined Oct 2003
Thats a loaded question but I would love to hear it to,I do Nippy and cd rom.Thanks in advance if some one goes through the trouble of doing this.Matt
Old Jan 02, 2004, 01:28 AM
Tokyo, Japan
Joined Nov 2002
CD-ROM motor prop. saver
I have some broken shaft troubles at landing.
The prop. saver is important goods for CD-ROM motor flying.
Old Jan 02, 2004, 09:45 AM
Ego varius quis.
Cheesehead's Avatar
Wisconsin
Joined Nov 2003
Has anyone tried the motor from a laptop's HDD or CD-rom drive? I was thinking of going brushless for my second plane, and need something about the size/weight of an IPS. It's a Hobbico F/F Zero, if anyone wants to know.
Old Jan 02, 2004, 10:37 AM
Joined Nov 2003
Cheeshead:
That motor in the post above of mine that says complete! Is only 10 grams How small do you want to go?
I have laptop hard drives and dvd/cd drives but the motors are built into the case and are a little tough to work with but I can do it?
But they are new lighter then the one above.
rcflyer2
One hour CD ROM construction part 7 rysium Power Systems 806 Dec 18, 2006 02:58 AM
One hour CD ROM construction part 6 arx_n_sparx Power Systems 1050 Mar 10, 2005 07:08 PM
One hour CD ROM motor construction PART 4!! t-turley Power Systems 555 Jun 07, 2004 07:33 PM
One Hour CD ROM Construction Part 5 arx_n_sparx Power Systems 537 May 07, 2004 09:56 AM
One hour CD ROM motor construction PART3 rysium Power Systems 511 Mar 22, 2004 01:03 PM
