Old Dec 01, 2003, 08:19 PM
Takao Shimizu is offline
Find More Posts by Takao Shimizu
Tokyo, Japan
Joined Nov 2002
One hour CD ROM motor construction PART2
Over 500 posts are already in "One hour CD_ROM motor construction".
http://www.rcgroups.com/forums/showt...hreadid=127606
This is the new thread for continue.
Anyway, I am tring to have N52 magnets.
Some Japanese manufactures are available, so far.
Takao Shimizu is offline Find More Posts by Takao Shimizu
Old Dec 01, 2003, 09:01 PM
Trprhook is offline
Find More Posts by Trprhook
Vacaville, Calif
Joined Jul 2003
Hi All.. Part II ! Great
Need to thank you Takao for having started this thread.
I'm doing my first re-wind tonight.
I do have a comment though concerning the spacing of the magnet wire. Spacing is important! By having gaps and irregular winding reactance is introduced. Reactance means heat which means loss of power. Being somewhat of a purist on windings, (my mentor is a notable in the field of electromagnetics) I find it difficult to not eliminate the spaces. It takes just a few more minutes, and by then your fingers are so stiff they wont notice the few minutes.
I did take apart a few HDD motors.. argh!
The key seems to be driving the front housing off with a drift pin ( in my case a nail), you can then salvage bearings also.
I hope to post a few pics later this week, either of a succesful rewind or the local fire department responding..
Anyway.. thanks to all Zoners for their invaluable contributions here..
Hook
Trprhook is offline Find More Posts by Trprhook
Old Dec 01, 2003, 09:46 PM
GIFLYRC is offline
Find More Posts by GIFLYRC
GIFLYRC's Avatar
INDEPENDENTLY POOR in OHIO
Joined Dec 2001
PERFORMANCE & PROBLEM
My latest rewind got closer to my goal of 3K with a 1260 prop and also created the following problem
28 mm stator 30 turns # 26 wire
~= 2800 rpm with 1260 prop
~= 3 to 1 gear ratio with 22 tooth pinion & 64 tooth spur gears
current is 3.6 A AND 36 WATTS @ WOT
My problem is that I am unable to secure the stator so that it does not twist out of the mount. I have glued it to the mounting plate using 5 minuet epoxy and also GOOP, and also thin c/a with baking soda (not all at once ) Hmmmm, mabe I should try that!
I can get several min. of operation and then the bond fails due to heat and torque
So if you have any suggestions, or sketches of a gear box that I can make or tips to help me secure the stator, I would like to see them
Thanks, Roger aka GIFLYRC
GIFLYRC is offline Find More Posts by GIFLYRC
Old Dec 01, 2003, 09:57 PM
Jim Miller is offline
Find More Posts by Jim Miller
Parkton, MD
Joined Dec 2000
Cure the Epoxy?
I find your post interesting because my first motor mount will be a Y of glassboard epoxied to the windings. My guess is that we'll need to use something other than 5 minute since it isn't very strong. I'd go with 30minute or more and heat cure it at 200F or so. Start the heat cure as soon at the epoxy is set but still green.
You could also try heat curing 5 min but I don't think it will do much good.
I've now got wire and my magnets. Need to go dumpster diving for CDROMS.
good luck
jtm
Jim Miller is offline Find More Posts by Jim Miller
Old Dec 02, 2003, 02:32 AM
ssatoru is online now
Find More Posts by ssatoru
ssatoru's Avatar
Chiba, Japan
Joined Jan 2002
Re: PERFORMANCE & PROBLEM
Congratulation on promising result, Roger!
How about using red Loctite? They are 150 deg C resistant. I use a little bit of CA to fix as stator is rather tight fit to the mount.
Satoru
ssatoru is online now Find More Posts by ssatoru
Old Dec 02, 2003, 06:55 AM
cwalsh is offline
Find More Posts by cwalsh
Transfixus sed non mortus
cwalsh's Avatar
Joined Nov 2001
Hi,
Here is my new motor, 28 turns of double wire, sorry I dont know the size of the wire!
3mm carbon shaft, rare earth magnets, and prop adapter modified into a rather nice looking shaft saver, works very well indeed.
Mount is an 8mm aluminium tube, this can be shimmed to fit a PJS mount.
This prop is a 9*4.7 and she pully 4 Amps out of a 2 cell 1500 Kokam pack.
I am thinking that if I change to a 8*4.7 I could use 3 cells at around the same or slightly more Amps.
BR,
C.
cwalsh is offline Find More Posts by cwalsh
Old Dec 02, 2003, 09:41 AM
Parkton, MD
Joined Dec 2000
Loctite versions
Red Loctite is a good idea. Loctite also has some primers that cause the Loctite to setup more quickly. I've used it on my telescope.
Loctite also makes versions specifically to gap fill. I've seen posts on the other thread indicating that Loctite can't be used to seat the magnets since it cures anaerobically. That seems inconsistent with a gap fill designation.
I'm going to try some test pieces (not magnets!) with some gap fill to see how well it works, esp w/ the primer to shorten magnet assembly time.
have fun
jtm
Old Dec 02, 2003, 10:22 AM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
The link to part I of this thread:
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Dec 02, 2003, 10:25 AM
Joined Feb 2001
Wait half an hour, one hour, until the oven temperature has settled. An initial tempature overshoot may kill the magnets.
Met vriendelijke groet Ron van Sommeren
diy outrunner brushless e-motor discussion.
Electric fly-in & lrk meet, June 27th, 2004, Nijmegen, the Netherlands.
Old Dec 02, 2003, 10:37 AM
Parkton, MD
Joined Dec 2000
Ron
If you're referring to the curing of the epoxy in your post I don't think the bell/magnets need to be inserted into the stator housing during the cure of the mount
At least I'm not planning to do that!
tnx
jtm
Old Dec 02, 2003, 10:39 AM
azfrench is offline
Find More Posts by azfrench
Tucson Avra Valley, Arizona, United States
Joined Nov 2003
cwalsh, I think I have the same motor as you. What are some numbers you are getting out of it? RPM, Thrust, ??? I have not replaced magnets or rewound it yet but it runs stock. I think it is going about 1000 rpm no load. Im using a cc25. Some of the stock magnet material broke off while getting the shaft out so this may be why the rpms are low. Til then.
Rick
azfrench is offline Find More Posts by azfrench
Old Dec 02, 2003, 01:04 PM
galloping gimp is offline
Find More Posts by galloping gimp
galloping gimp's Avatar
Ohio, USA
Joined May 2002
Here is my CD-ROM conversion so far.
I used the original brass stator insert, then soldered a brass tube to it. An aluminum tube at the rear holds a 6mm GWS ball bearing. I swaged the .25" aluminum tube to fit the bearing. Another ball bearing is CAed into the brass stator insert at the front. A GWS 3mm shaft is press fitted and CAed to the bell. This motor is a bit heavy because of all the brass -- already more than 25g.
I have 5x5x1 N45 magnets which will replace the ring magnet.
I want to try this motor in my GWS Tiger Moth. I'm going to wind with #26 magnet wire (= 0.0159" ~ 0.4mm). Am I correct that a larger number of turns (20-25) and a Star connection will give me lower RPM and more torque than fewer turns and Delta connection?
Is it correct that lower RPM and more torque = ability to drive larger prop = better for slow flyer like the TM?
Does anyone have recommendations on where to obtain metric-dimensioned aluminum tubing in the U.S.? Would CF tubing also work?
Jeff
galloping gimp is offline Find More Posts by galloping gimp
Old Dec 02, 2003, 06:10 PM
Cody W is offline
Find More Posts by Cody W
Cody W's Avatar
Plaistow, NH
Joined Nov 2003
I'm gonna build a CD-ROM with dual stators, custom machined bell, and 20 5x5x2 N45 magnets. I know this has been done before; any links?
Cody W is offline Find More Posts by Cody W
Old Dec 02, 2003, 09:19 PM
Trprhook is offline
Vacaville, Calif
Joined Jul 2003
EEhaaaaaaaaa.. it works!
Just fired up the first CDRom..
It was already wound "Y" but I disnantled it anyway, put longer leads on it and let 'er rip.
Jeez.. its so quiet I can't hear it. I was using a 8.4 Nimh with a CC Phnx 10.
9 Pole. Stock ring magnet. No prop.
I have a tach due in any day, and have a stack of NE45s.
Man a BL for under 6.00!
Will post a few pics and some data as I get it.
Also have a totally rewound I may try tonight. 9 pole 18 turns @ #26 wire.
Hook
Old Dec 02, 2003, 09:38 PM
iva is offline
iva
Find More Posts by iva
iva
iva's Avatar
Vancouver Harbour Sp, Canada
Joined Jan 2001
I do not remember exactly when and where I read it but magnet wire and CA glues should be kept apart. Supposedly CA fumes will weaken or degrade insulation and that may lead to shorts.
That process is gradual and it may take some time for insulation to become useless.
Zoran
iva is offline Find More Posts by iva
One hour CD ROM construction part 7 rysium Power Systems 806 Dec 18, 2006 02:58 AM
One hour CD ROM construction part 6 arx_n_sparx Power Systems 1050 Mar 10, 2005 07:08 PM
One hour CD ROM motor construction PART 4!! t-turley Power Systems 555 Jun 07, 2004 07:33 PM
One Hour CD ROM Construction Part 5 arx_n_sparx Power Systems 537 May 07, 2004 09:56 AM
One hour CD ROM motor construction PART3 rysium Power Systems 511 Mar 22, 2004 01:03 PM
