Old Dec 08, 2012, 05:15 PM
Desert Fox is offline
Find More Posts by Desert Fox
"In Thrust I Trust"
Desert Fox's Avatar
United States, GA, College Park
Joined Nov 2011
What keeps the brake hub from rotating? The Air Brakes hub has a slot for the strut.
Could you post a video of the brake system working on a 15-25 pound aircraft? Shulman Aviation video is a foamie aircraft.
Desert Fox Heli
Desert Fox is offline Find More Posts by Desert Fox
Last edited by Desert Fox; Dec 13, 2012 at 03:29 AM. Reason: still waiting for reply added another question
Old Dec 17, 2012, 04:47 PM
DamonH is offline
Find More Posts by DamonH
DamonH's Avatar
United States, NM, Clovis
Joined Oct 2011
Originally Posted by DamonH
Anyone know if these will be available for the Habu 32 that will fit the tamjets struts?
Tamjet Strut Diameter: 0.137 in (3.5mm)
Yes, it can fit in Habu 32, and our standard axles Dia 3mm/4mm/5mm
For any special axle you need for your Jets.
Please contact our dealer in USA ( Shulman Aviation)
Yes, you can select axle size to fit Habu 32 but the issue is that the smallest tire is 2" and that is too big for the H32 which has stock tire size of less than 1.75". Is it possible to get them in that size or is 2" the smallest?
DamonH is offline Find More Posts by DamonH
Old Dec 17, 2012, 05:41 PM
4stripes is offline
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
My two sets arrived today. The quality of these alloy wheels with built in bearings is excellent.
Can't wait to try them in my Starmax F-16. As expected, they are a bit of extra weight but well worth it.
4stripes is offline Find More Posts by 4stripes
Old Dec 17, 2012, 10:10 PM
DON SHULMAN is offline
Find More Posts by DON SHULMAN
Joined Aug 2005
Desert Fox Heli
Hi Desert Fox: I think we spoke on the phone last week about the Em~Brakes. FYI, the A-26 in our video is an ARF, made from balsa/lite ply, and fiberglass--it is not a foamie.
The plane weighs 12 pounds and is powered by 2-Fury SA-41's (same power as a glow 40). Check out the video again and you can see the 'holding power' of the Em~Brakes-which are made by Taiwan-Tornado.
Shulman Em~Brakes (1 min 18 sec)
We currently have every size wheel and axle diameter in stock, plus accessories and spare parts. You can see them at:
shulmanaviation.com
BTW, the axle is held into the strut with 1 or 2 set screws, which prevent the brake from spinning.
Thanks, Don
DON SHULMAN is offline Find More Posts by DON SHULMAN
Old Dec 18, 2012, 12:09 AM
"In Thrust I Trust"
Desert Fox's Avatar
Joined Nov 2011
Don,
You are correct, that was me. I was glad you called, I had been waiting for a reply here. I have a couple of follow up questions. Do the tires have treads and is the tire (rubber material) user replaceable?
Desert Fox Heli
Old Dec 18, 2012, 12:28 PM
BILLYDSRC is offline
Find More Posts by BILLYDSRC
BILLYDSRC's Avatar
OHIO
Joined Aug 2009
Great video Don!! They work really good too..
Thanks Billy D
BILLYDSRC is offline Find More Posts by BILLYDSRC
Old May 03, 2013, 07:30 AM
viperviper is online now
Find More Posts by viperviper
Antarctica
Joined Apr 2012
Just curious,
1. May I ask how u hold the wheel to the struct when there is no thread on the wheel shaft itself in the newer version brake system? esp on a taft viper jet...Can anyone share a pic of your wheel brake installation? Greatly appreciate it.
2. And what is the different between using a 7.4v pack vs tapping the power from a 6S pack? more braking power?
3. Can the new version braking system, able to adjust any braking capacity?
Pls advise.
viperviper is online now Find More Posts by viperviper
Old May 03, 2013, 10:41 AM
4stripes is offline
4stripes's Avatar
Joined Jan 2009
I am using these electric brakes in my FW 262, and my 90mm Starmax F16. I was going to use the balance lead from my 6s battery to power them but was told it is not recommended (and to use a separate 2s pack). A very small 2s pack made from a couple micro helicopter batteries seems to be working fine. There is no control of the braking power, just ON or OFF. Perhaps the newer ones are different. My F16 brakes seemed to grab very strong, so I reduced their effectiveness by placing a thin brass shim inside the hub which give me the amount to stoping power I want.
The axles are smooth but are held into each leg with the typical set screws that hold an axle. There are a couple bolts that stick out of each hub that end up straddling the gear leg and will prevent any possibility of the hub turning.
Very happy with my 60 and 65mm versions, but I do think the price is rather high.
A total of 200g extra weight can be expected with this system (assuming a very small 2s battery).
Old May 03, 2013, 10:48 AM
DamonH is offline
DamonH's Avatar
Joined Oct 2011
Do you have any idea why it isnt recommended to use the balance lead?
Old May 03, 2013, 10:58 AM
Antarctica
Joined Apr 2012
Is 2S pack enough for the braking...anyone use it before.
I may go for 3S..
Old May 03, 2013, 11:17 AM
4stripes is offline
4stripes's Avatar
Joined Jan 2009
Don't know why the balance lead is NOT recommended.
2S is more than enough (1s doesn't work) and I haven't tried 3S.
Old May 03, 2013, 11:20 AM
Antarctica
Joined Apr 2012
Thanks 4Stripes. oh ok. may i ask how heavy is your jet and the stopping distance? pls advise. tks!
And which TX switch u tied to?
Taking this oppty to take mw46mw46 who whatsapp me for answering my queries i raised previously. tks.
4stripes is offline
4stripes's Avatar
Joined Jan 2009
One thing that could be improved upon is than the brakes should not be applied when the receiver is not powered. As they come, the brakes are applied until you power up the receiver to select them off.
If you forget to disconnect the battery supply to the brakes after disconnecting your flight pack, the battery will be emptied completely.
Old May 03, 2013, 11:22 AM
4stripes is offline
4stripes's Avatar
Joined Jan 2009
My F-16 is rather porky at around 3.7kg. Never measured stopping distance but guess around 75feet in no wind. If I removed the brass shims, I'm sure it will stop in 40 feet .
Old May 03, 2013, 11:26 AM
Antarctica
Joined Apr 2012
12 meters... very long stopping distance..
Sold retractable tail wheel and wheel brakes rcshirt Aircraft - General - Miscellaneous (FS/W) 1 Sep 27, 2012 11:26 AM
Sold BVM 2 1/4" sport main wheels w/ brakes and nose wheel Chuchuf Aircraft - Electric - Jets (FS/W) 4 Sep 14, 2012 08:28 AM
Sold BVM 2 1/4" sport main wheels w/ brakes and nose wheel Chuchuf Aircraft - Fuel - Jets (FS/W) 0 Sep 13, 2012 02:00 PM
Sold REDUCED BVM *NEW* 3-1/2" Mains, 3-1/4" Nose Wheels and Brakes inpieces Aircraft - General - Miscellaneous (FS/W) 1 Mar 07, 2012 10:13 PM
For Sale FEMA Retract, wheel brake, gas spring, servo holder, wheel cover, wheel, etc iflytailies Aircraft - Sailplanes (FS/W) 0 Aug 05, 2011 10:55 PM
