Old Oct 05, 2012, 03:47 PM
v8truckin is online now
Find More Posts by v8truckin
Should've, Would've, Could've
v8truckin's Avatar
United States, CA
Joined Dec 2010
Looks like the skyflight/LX B25 79"(distributed by BH) brakes which I believe the plane is at least 12-15lbs wet n wearing boots. correct me if I'm wrong...
v8truckin is online now Find More Posts by v8truckin
Old Oct 06, 2012, 07:54 AM
viperviper is offline
Find More Posts by viperviper
Antarctica
Joined Apr 2012
axle size? and where to buy one set?
viperviper is offline Find More Posts by viperviper
Old Oct 06, 2012, 11:23 AM
4stripes is offline
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
Tom Yu
Stop teasing us!
Where can these be bought, without buying a whole B25 from BH?
4stripes is offline Find More Posts by 4stripes
Old Oct 06, 2012, 06:01 PM
turbonut is online now
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
its all good...
No offence taken...my skyray will get over it!...its tuff being small
Originally Posted by racer1 View Post
Sorry wasn’t trying to be condescending, I do not use brakes on my smaller jets, and I did not mean to insult your jet. It appeared that the jet in the video was a foamy.
turbonut is online now Find More Posts by turbonut
Old Oct 07, 2012, 06:30 AM
Dr Honda is offline
Find More Posts by Dr Honda
Dr Honda's Avatar
Pittsburgh Allegheny, Pennsylvania, United States
Joined May 2004
I fly large EDFs and brakes would be nice. I normaly use BVM stuff which is a little pricey. So there is a big difference from stopping a 4 lb foamy and 24 lb EDF.
Well..... sort of.
I will agree that a big model is different... but even if they only apply a small amount of drag on a heavy model... it's still better than nothing.
I fly turbines, and in the USA, we are required to have brakes... but there is no rules on how well they work, other than "They have hold the model while the turbine is at idle." (AMA requirement)
Dr Honda is offline Find More Posts by Dr Honda
Old Oct 07, 2012, 08:57 AM
Tom yu is offline
Find More Posts by Tom yu
Joined Sep 2012
http://www.amaxrc.com/electrical-mag...em-p-3728.html
↑Procurement can take a look at the URL above
Brake controller features explained
Voltage input :7.2V-30V Can tap directly on aircraft batteries Or use an external battery 7.2V-30V
Signal input : Connect remote control receiver, set an action
Capacity control: adjustment clockwise will increase the power
, vice versa.
brake wheel: Connect the power input line on the tire
Taiwan Tornado select rubber of the tire same class with automobile which leads to better improvement on brake wheel tire when landing and better control at the player’s option. Spare tire is optional.
Tom yu is offline Find More Posts by Tom yu
Old Oct 07, 2012, 09:08 AM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Sweet thanks just ordered 3 sets, before they go outta stock.
Old Oct 07, 2012, 09:31 AM
Tom yu is offline
Joined Sep 2012
Break news, our first Electrical magnetic brake system for 15KG JETS will be available by www.amaxrc.com in November.
Aluminum alloy
Old Oct 07, 2012, 10:01 AM
Maxthrottle is offline
Find More Posts by Maxthrottle
You are a "go" for reentry
Maxthrottle's Avatar
High Orbit.....
Joined Jun 2009
?Procurement can take a look at the URL above
, vice versa.
Tom; Thanks first of all.
Questions.Control.
Can the radio position to activate the bakes be adjusted. I mean, do I Y this off say the elevator channel and they activate with only down input or does the controller have to be off a separate channel.
If you know what the usec activation point is please advise?
Would you happen to know if they'll be producing various wheel OD?
I also assume it has no differential control to apply more brake to one side than the other or even counter brake ware imbalance.
Thanks for answering any of these questions.
Maxthrottle is offline Find More Posts by Maxthrottle
Old Oct 07, 2012, 10:35 AM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Cool! Thanks for info Tom. Actually ment bought 2 sets, darn cellphone touch screen. I'll keep an eye out for those new brakes. Wish they could be made bigger and used on warbird taildraggers, but those nose overs wouldn't be good.
Old Oct 07, 2012, 12:03 PM
kimhey is offline
Find More Posts by kimhey
kimhey's Avatar
nøtterøy, NORWAY
Joined Mar 2006
One control board for each wheel, connected to a gyro with two input/output channels (ie Futaba GY351), and you may just achieve this.....maybe?
kimhey is offline Find More Posts by kimhey
Old Oct 07, 2012, 01:03 PM
High Orbit.....
Joined Jun 2009
Ya thus my question. But if its programmed non reversible, or the span of usec activation is not adjustable, it may need a reverser in pairs or may need a separate channel. Thus the question about the usec transition point. If they are all programmed the same direction then the controller on one side will need a reverser to work in pairs.
Still steering with command from the TX or even a disconnected gyro, sits at a neutral point which for most devices is 1500 usec, AKA between the +100% vs -100%. Surfaces, Rudder or Elevator, swing from 1500 to 900 or 1500 to 2100 as do gyros. If the preset transition point is say 1000 and below or 2000 and above only, then by Y'ing the RX from a elevator or rudder will always be partially engaging the brakes as you take off.
Thus my next if it has to be off a separate channel and naturally there after all mixing etc is then done on the radio. If he can answer even some of these questions it can tell us if can even be set up on a radio that is already maxed out on channels or mixes.
It obviously has a group of interest. Maybe they will later come out with these features in a future iteration if not in this one.
Old Oct 07, 2012, 08:34 PM
rfodor is offline
Find More Posts by rfodor
United States, GA, Alpharetta
Joined Feb 2009
, vice versa.
Anyone have a clue as to what size wheels come with these from amaxrc?
rfodor is offline Find More Posts by rfodor
Old Oct 07, 2012, 09:00 PM
High Orbit.....
Joined Jun 2009
First post look at the pic.
Old Oct 08, 2012, 08:45 AM
Tom yu is offline
Joined Sep 2012
JET jet Dedicated electromagnetic brake
Sold retractable tail wheel and wheel brakes rcshirt Aircraft - General - Miscellaneous (FS/W) 1 Sep 27, 2012 10:26 AM
Sold BVM 2 1/4" sport main wheels w/ brakes and nose wheel Chuchuf Aircraft - Electric - Jets (FS/W) 4 Sep 14, 2012 07:28 AM
Sold BVM 2 1/4" sport main wheels w/ brakes and nose wheel Chuchuf Aircraft - Fuel - Jets (FS/W) 0 Sep 13, 2012 01:00 PM
Sold REDUCED BVM *NEW* 3-1/2" Mains, 3-1/4" Nose Wheels and Brakes inpieces Aircraft - General - Miscellaneous (FS/W) 1 Mar 07, 2012 09:13 PM
For Sale FEMA Retract, wheel brake, gas spring, servo holder, wheel cover, wheel, etc iflytailies Aircraft - Sailplanes (FS/W) 0 Aug 05, 2011 09:55 PM
