Canada, QC, Saint-Laurent
Joined Jan 2002
I don't think since I try it too that it is possible unless all the trims would be the same etc.. I didn't succed..so I am looking here at what others may come with, so far we are 2 that didn't work.
Only thing I didn't try yet is having the DX5 as a master then it's very limited.. |
i have asked this same question on another forum i use and someone has said this.....
''A little Google-ing shows there to be an issue between the DX6 and the DX5 when buddy boxing and using the DX5 as the slave. If you use the DX5 as the master you will be good to go by all accounts, just means you have the hastle of rebinding every now and again.' im trying to find some info as we speak,not having much luck though |
The best way to set up buddy box is to use the servo monitor screen and adjust the slave's sub-trim and travel adjustment so no visible channel movement is seen on the monitor of the master when you switch over controls to slave.
Since the dx5e does have any of these adjustments it would be better if the dx5e was the master and the dx6i the slave. You could easily match the dx6i to the dx5e |
Latest blog entry: Get Help by posting your SPM File
United States, NY, Cortland
Joined Sep 2010
ok thanks gents. anyone else think spektrum dropped the ball on this one? why have they not resolved this issue a long time ago? considering how many people use the 6i/5e combo to teach others,they should make sure they are compatible.
surely it would be a much better business practise to have all their tx's compatible,training wise,with each other.after all,they all run on the same software as far as i know. now ive just bought a 5e that is basically useless to me. dont really want to be handing over my 6i to my young boys,or my brother for that matter. id only feel comfortable letting another pilot use it,not someone who does not have a clue! i guess the only way to utilise the 5e is to bind it just to the plane i am training them on,saving me from having to rebind my 6i every 5 mins! of course,this does not solve the issue of having to hand over my 6i to the newbs!! wish id gone for the 4e now :0/ |
Joined Sep 2010
From the related threads shown at the bottom of the page-
http://www.rcgroups.com/forums/showthread.php?t=1101952 "I had trouble when using the same setup as it would throttle up randomly when switched to trainer control. I had set all the reversing the same, so I was baffled for a while. Turns out my throttle trim on the dx5e was a couple clicks above neutral. On the off chance something like this happens to you, you know at least one thing to check." http://www.rcgroups.com/forums/showthread.php?t=1004674 "I've just got a DX5e to link to my existing DX6i. With the 6i as the master the motor starts spinning when the trainer switch is pulled. The settings on the 5e cannot adjust the motor to a low enough value to switch it off. Well, there is one way I found to do it. If I reverse the throttle on the 5e and move the throttle stick fully up it then works fine...pulling the throttle stick backwards makes the motor start and pushing it forwards stops it. I've tried it on a couple of models and it does the same. Re-binding the model to the 5e and using it as the master and the 6i as the slave works fine." |
thanks for that dave. i have a dx5e for sale if you are interested!! lol
whats that in your sig about a fatal flaw? im intrigued.... also that last paragraph in your post intrigues me....if you can reverse the throttle and have top stick as zero throttle and bottom as 100%, i wonder if you could set it like that and open up the tx and flip the gimble 180*,making the stick work in the right direction again.? mind you,that would not solve the lack of throttle response the 5e is giving me. looks like the only way around it is to use the 6i as slave. something i really didnt want to do. |
Joined Sep 2010
I don't know anything about this problem except what I was able to post up from other threads, I'm afraid.
The DX5 fatal flaw is a crappy cheesy sliding power switch, it is prone to glitching the power or even just shutting the power off. On mine it glitched the power fast enough to kill the TX (locked up the microprocessor, I think), without the LEDs going out and without it playing the startup tones. On mine I just soldered wire across the ON position of DPDT switch position (after removing the switch) and added another toggle switch in series with the battery. I can't use it as a slave that way though, the power switch connects internal circuits while in the 'off' position for slave use. The test for the switch problem is to bind to your plane and then tap the power switch and TX case, and very very slightly nudge the power switch in the 'off' direction. |
thanks for the heads up mate. just tried that with mine. mine seems to be ok. small mercy's huh! will have to make do with the 5e for now by the looks of it until i can save up some pennys for the 4e (i assume this issue does not occur with the 4e as well?!) fwiw,i emailed horizon uk earlier explaing my problems. you never know,maybe they can suggest a fix?! long shot i know as i doubt im the first to contact them about it.....and prob not the last either! |
| Thread Tools | |
| Question DX6i elevon issue with a buddy box and 9503 | Hance | Radios | 2 | Apr 09, 2012 09:20 PM |
| Question DX6i and DX5e buddy box system | brookfreeman71 | Beginner Training Area (Aircraft-Electric) | 37 | Feb 04, 2011 09:57 PM |
| Discussion dx5e as buddy box, chan 5 issue | ryokox3 | Radios | 4 | Jun 14, 2010 09:33 AM |
| Discussion Spektrum DX5e and DX6i buddy box! | Danyal | Beginner Training Area (Fuel) | 7 | Apr 23, 2010 08:08 AM |
| Discussion Can the DX6i and the DX5e be used as a buddy box system? | vampy | Radios | 2 | Feb 26, 2009 07:15 PM |
