It's nothing to do with Beastx's property,you can check it.One thing certain is that the New Bigaole FBL unit isn't nothing inferior to BeastV3 on stability,If you doubt it,you could fly it yourself. Of course,if players rather pay more 100dollars for a BeastX,it's ok for all of us as brand value msut be respected. |
Australia, VIC
Joined Dec 2011
Hmmmm
Im currently using the CopterX CX3x1000 ...
Being Noob it was interesting ... The cyclic is more or less sorted [ works ] , and the major issue was getting the tail to stop waging [ a CX3x1000 issue ] , still ongoing [ Hope to be closer to a fix ] How much better is the Tarot zyx than the CopterX ? What about the Align 3G ? or the VCTRC 3GX ? or the CopterX CX3-2000 or KDS - Ebar Being noob , its a different perspective ... There are a lot of gyros out there , and some are directly intended for competition and others more for general use [ like comparing apples and oranges ] So depending on user experience desires etc , hopefully there is something for everyone .. Plug and play would be nice but with so many variables ? Anyhow , so far the discussion seems to have been quite limited ... |
Letchworth, Great Britain (UK)
Joined Jul 2004
For me the BeastX was plug and play. I had no luck with the 3Gx on my T-Rex 550, but the BeastX worked straight out of the box on factory settings. I'm a learner too, so I can't say what it's like if you want anything other than simple hovering and forward flight though. But for my level of competence, it's brilliant.
United States, IN, Michigan City
Joined Nov 2003
I have used the 3GX on my trex 500. Not too bad setting up and flew ok.......UNTIL it went into reboot or reset for some reason and I lost control. When I got SOME control back and to keep it away from people, cars or buildings I nose dived it into the street. I have used the Walkera RX270V FBL controller and it was a serious pain in the arse to set up but it flew awesome. Made my 450 feel like a bigger bird. It could only be used though with the Walkera 2801 Pro TX. Now have the beastx, AR7200BX, very easy to set up and I only hovered and short fly arounds it was awesome as well. If there is any such thing as plug and play I would have to say the beastx is it. I highly recommend a swash plate level tool though. Very straight forward going through the menu selections and flew right out of the box so to speak.
For the price, ease of setup, flies right after setup I give the beastx or AR7200BX BeastX & Spektrum combo thumbs up all the way |
That's the problem, these gyros try to appear to be smart, but shoot themselves in the foot at the same time, so if your helicopter drifts, you will end up turning the swash knuckles to stop the drift.
So what is the point in leveling it in the first place if you will end up putting a turn or two in the swash links anyway? In [my] theory, all flyarless helicopters should fly like the mCPx, but in reality it is far from that. All the gyros that I own (except the CY and the mCPx) will drift with the wind and drift if your CG is off, so no reason to get everything "perfect" because it will not fly straight anyway. The CY gyro and the mCPx will fly even if your swash is completely crooked and CG is way off, that's why you can slap a 120SR tail motor and it does not even budge the little chopper. |
USA, WA, Bremerton
Joined Feb 2007
What does a 120SR tail motor do on my Mcpx if I'm still brushed on the main motor? Is this something I should upgrade. I had thought it was only when I went (if ever) BL on the main?
I just did my first inverted hover on the Mcpx this weekend, so I'm a long way for needing massive power on that little bird but maybe the tail is something I'm missing the boat on. |
In my opinion the 120SR on the tail is incredible, even with a brushed main motor. I have tried an extended tail with a stock tail motor, but that was not enough for me, so I now fly a 120SR tail with stock length boom and it holds through anything. I would like to try brushless main motor one day and probably will do so, but I can't justify spending too much money on the mCPx at this time.
Latest blog entry: Turnigy dlux 80A HV: Soft Start and...
Joined Nov 2012
Australia, VIC
Joined Dec 2011
Hmmm
Would love to try Tarot firmware ... Some say it fixes the tail wag ... |
| Thread Tools | |
| Help! Flybar or flybarless? Which one do your prefer? | super2012 | Electric Heli Talk | 55 | Aug 07, 2012 10:41 PM |
| Question cheap flybarless system | Hellysmack | Mini Helis | 1 | Jun 23, 2012 02:37 PM |
| Discussion Long Range System, Which one?! | MtnSnowFlyer | Video Piloting (FPV/RPV) | 2 | Jun 16, 2012 05:13 AM |
| Question Which Flybarless System | Greg_E | Electric Heli Talk | 8 | Feb 12, 2011 05:17 AM |
| Discussion Cheap, good quality nitro's. Any good sites? | Faithflyer | Fuel Warbirds | 1 | Jan 30, 2008 09:57 PM |
