| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#1 |
Crash and Build
What prop fo this combo? (razor 400 etc)
My Switchback
3 cell etech 1200's GWS C GB Razor 400. APC SF 10x7? I am just switching to the Lipolys and want advice lest I fry some expensive batteries, what amps am I shooting for and how shall I prop it? (i prefer apc sf) thanks David |
#2 |
Gravity brings me down
6A max for continuous use.
#3 |
The factory is comfortable with suggesting a maximum continuous draw of 7.5c from these cells... That would be 9A for the 1200's I have pushed them harder then that for short bursts up to 12A ~10sec.... That RZ-400 will be happiest ~ 10A peak power... you could prop for 10A and just use a little caution with the left stick - You won't be lacking for power so that shouldn't be an issue.
-Bill |
#4 |
Crash and Build
OK, if i want to prop for 9 amps, what prop?
#5 |
Live to ride... and fly!
David,
I posted Whattmeter/ thrust results for various props on a RZ-400/ C box/ 3x1200's here: http://www.rcgroups.com/forums/showt...hreadid=135155 |
#6 |
Crash and Build
woo hoo, EXACTLY what I needed. thank you very much!
#7 |
No problem David! I'd probably go with the 9x7 or 10x4.7. The 10x8 is pushing the cells at WOT, but it's possible you wouldn't need WOT much so it might work too. I'd start with the other props initially and see how it goes though.
Those are static thrust numbers, so the higher pitch props (9x7 and 10x8) were likely stalled and would generate more thrust in the air. Good luck!
| Thread Tools | |
| Question What prop for an E-Flight 400 outrunner?? | Mchone, Jake | Power Systems | 14 | Jun 26, 2006 08:56 PM |
| Discussion What prop to use on a GWS EPS 400 in "D" box? | craab | Parkflyers | 5 | Jun 08, 2006 12:04 AM |
| Question New plane; Prop and Gearbox Problems with Razor 400.. | jessewvu | Power Systems | 4 | Jan 02, 2006 09:50 AM |
| what prop/esc for e-flite 400 brushless | birdie_in_texas | Power Systems | 0 | Aug 17, 2004 12:11 PM |
| Help with what prop for this motor and GB | Mike Parsons | Power Systems | 8 | May 21, 2003 08:52 AM |
