Old Dec 01, 2003, 07:03 PM
dpoles is offline
Find More Posts by dpoles
Crash and Build
dpoles's Avatar
United States, NY, Ithaca
Joined Oct 2001
Question
Where to charge LiPoly?
Ok, I took the plunge a 3 cell and a 2 cell Etech and a Triton with a temp probe.
Now where do you guys charge? I know the horror stories.
Do I charge in the garage, leave 'em out in the driveway! Or charge them in my building room, while I am in the room? Which is safer...close supervision or out of the house?
I am planning on using an old pyrex dish as my vessel.
input?
David
dpoles is offline Find More Posts by dpoles
Old Dec 01, 2003, 07:10 PM
sylair is offline
Find More Posts by sylair
Toledo, Ohio
Joined Apr 2003
Charging li-polys
I put mine in a coffe can while charging.just dont leave to go the the store or anything and keep a eye on them to make sure they dont get hot.
luke.
sylair is offline Find More Posts by sylair
Old Dec 01, 2003, 07:28 PM
Phreakish is offline
Find More Posts by Phreakish
Nickel what?
Phreakish's Avatar
Prescott, Arizona, United States
Joined Jan 2003
I charge mine in my dorm living room, on my desk, with a homebuilt charger, while I'm in class... no problems EVER. The only way I've managed to kill these things is to feed them way too much voltage for too long (I sent 20V at 3A into a 1020 2s pack for 3 hrs one day, and still no explosion). I run kokams almost exclusively if you're wondering
Phreakish is offline Find More Posts by Phreakish
Old Dec 01, 2003, 08:09 PM
edkoz is offline
Find More Posts by edkoz
Watch This !!!
edkoz's Avatar
Rochester, MI
Joined Apr 2003
Where to charge
I keep mine in a "Sentry" portable fireproof safe ($19.00 Looks like a small lunch box from Office Max) on my basement floor away from everything.
Leaving it Unattended on a desk is just asking for trouble. Eventually you will pay the price.
Ed
edkoz is offline Find More Posts by edkoz
Old Dec 01, 2003, 08:26 PM
The Blue Max is offline
Find More Posts by The Blue Max
CO of The Flying Circus
The Blue Max's Avatar
wind and rain,Oregon
Joined Jul 2002
Li-Poly fires can burn through metal and I do not recommend a metal container for charging. The Pyrex is a good idea but make sure you find some kind of lid to keep a possible explosion from throwing burning hot debree out of the container. The only charger I have for charging my Li-Poly's is the little BEL and it does a good job but I do not have a power supply to charge with so I have to charge in my vehicle while it is running in order to provide the voltage and amps necessary to fully charge 3s1p packs. Some people have questioned this and don't think it is very smart but I built a ceramic box out of high quality ceramic tile that the heat of a Li-Poly fire or the force of an explosion cannot penetrate. Ceramic tiles are what the outer armor on the M1A1 abrams tank is and they can defeat depleted uranium armor peircing projectiles so I am confident that my setup is safe from fire or explosion.
The Blue Max is offline Find More Posts by The Blue Max
Old Dec 01, 2003, 08:35 PM
Dogsbd is offline
Find More Posts by Dogsbd
South Carolina
Joined May 2003
Errrrr, I kinda doubt you've obtained any ceramic near as tough as the chobham armor on the Abrams. It's true make up is a closely guarded secret.
Dogsbd is offline Find More Posts by Dogsbd
Old Dec 01, 2003, 09:28 PM
edkoz is offline
Watch This !!!
edkoz's Avatar
Rochester, MI
Joined Apr 2003
Sentry
The interior of the Sentry has asbestos sandwiched between the case and the inside. Really a pretty slick setup. There is no bare metal exposed to the battery.
Ed
Old Dec 01, 2003, 09:32 PM
Joined Jul 2002
Picky Picky Picky
O.K. so I'm not going to be stopping any anti tank rounds but ceramics can withstand heat that would make steel turn to a molten liquid that would flow like water. That is why the tiles on the space shuttle are ceramic, so what do you have to say about that, huh!
Old Dec 01, 2003, 09:42 PM
Joined Jul 2002
Sentry
Ed
That sounds pretty safe (pun intended ) I have read several posts where people have used simple metal boxes or a safe without any kind of fire proof liner and if they do experience a fire they may be in for a nasty surprise since Li-Poly fires sometimes have a "blowtorch" type of flame, and I have even heard of packs flying off of work benches onto a floor where they could ignite combustible floor coverings. I happened to have some ceramic tile laying around and before I used it I used an acetylene cutting torch to test it's fireproof properties. Didn't cost me a dime but not everyone has ceramic tile laying around so your safe is a good idea and I would highly recommend that anyone deciding to use Li-Poly's get something like the Sentry you recommend.
Old Dec 02, 2003, 09:29 AM
kansascloud is offline
Find More Posts by kansascloud
Checking the wind
kansascloud's Avatar
Aubry Township, Kansas South of KC.
Joined Jan 2002
You guys are all wusses. I charge mine under my pillow when I sleep!
Well seriously....I charge on the basement floor away from everything. Maybe I should get some kind of container though after reading all of this?
I've been using Kokams for almost as long as they have been available and haven't had any problems.
kansascloud is offline Find More Posts by kansascloud
Old Dec 02, 2003, 10:27 AM
Zoomzoom is offline
Find More Posts by Zoomzoom
Joined Jul 2002
I had $30,000 worth of damage done to my house from a LiPo fire. There wasn't any structrual damage, just smoke and soot damage. It was a three month ordeal to get the house back to normal. The wife and I even had to move out for three weeks while work was getting done to it. Not a fun thing to go through.
Charge your batteries outside the house away from any combustable materials if you can't watch them continually while they are charging. The smoke damage alone can be more than you realize or thought about if anything around it catches fire.
Typically I charge mine on the patio with everything else cleared off around it.
Zoomzoom is offline Find More Posts by Zoomzoom
Old Dec 02, 2003, 10:32 AM
Martin Hunter is offline
Find More Posts by Martin Hunter
Leave me alone!
Martin Hunter's Avatar
Kamloops, BC, Canada
Joined Feb 2002
I'm moving this to the batteries and chargers forum.
Martin
Martin Hunter is offline Find More Posts by Martin Hunter
Old Dec 02, 2003, 10:46 AM
mkirsch1 is offline
Find More Posts by mkirsch1
United States, NY, Spencerport
Joined Oct 2001
Blue Max,
Check out this 15V Wall Wart from MECI:
http://www.meci.com/default.asp?mode...s&category=216
MECI Part Number: 600-0413
$3.95. You have to replace the plug on the end with one from RadioShack to fit the BEL, but it works a treat! Even though MECI's minimum order is $20, it's still cheaper than paying for gas to run your car all the time...
mkirsch1 is offline Find More Posts by mkirsch1
Old Dec 02, 2003, 10:49 AM
FreeFlier is offline
Find More Posts by FreeFlier
...still seeking PyrE
Long Island's North Shore
Joined Aug 2003
Charge Lipos in a Pyrex baking dish which sits on a welding/ceramic tile, topped off with another Pyrex dish, upside-down on top. Packs are stored in a Sentry safe, as mentioned above, on a concrete floor (shed) outside of the house.
Yes, the horror stories are not just stories, real people suffered real trauma, and lost not just property, but also a sense of security; in many ways an irreplaceable element.
FreeFlier is offline Find More Posts by FreeFlier
Old Dec 02, 2003, 11:02 AM
Tres Wright is offline
Find More Posts by Tres Wright
Live to ride... and fly!
Tres Wright's Avatar
Forney, TX
Joined Mar 2002
First, always make sure your settings match the pack you are charging. Never exceed 1C charge rate, and never charge a 2 cell pack on the 3 cell setting. So far, every li-po accident I've read about was due to wrong charger settings or a pack being damaged in a crash. One of these days the manufacturers are going to have to step up and dummy-proof the chargers. Anyone can get distracted while putting a pack on the charger, and that can lead to disaster.
As for location, I personally charge in the garage and monitor the packs (check temps by hand) every 10 minutes or so. I double or triple check charger settings for every pack charged.
On the power supply, I highly recommend a regulated supply. The voltage can fluctuate substantially on an unregulated supply leading to a damaged charger and/ or packs. I got my 3 amp supply at Radio Shack that I use to run my BEL charger and SC-2 (2 port) charger simultaneously. Works great!
Tres Wright is offline Find More Posts by Tres Wright
Where to put a lipoly on a HB montu Micro Helis 2 Apr 01, 2004 05:21 AM
Is it OK to charge LiPoly outside in cold winter temps (32 C or less)? duganderson Batteries and Chargers 2 Nov 27, 2003 04:59 AM
how long to charge lipoly? kindjordan Batteries and Chargers 12 Oct 14, 2003 03:42 PM
Can you charge lipoly batts through a wattmeter? slammin Batteries and Chargers 6 Sep 01, 2003 12:30 AM
What rate to charge lipoly cells? Cubby Boy Batteries and Chargers 14 Jun 30, 2003 12:56 PM
