I received the kit last Monday but due to time sensitive work stuff I really haven't had a chance to do much on the Recruit.
Very much impressed with the wood from Charlie. Here's my progress so far. Top & bottom fuse halves pretty much done. Bottom half went together rather uneventful but did have a couple minor hitches with top half. When fitting the top keel (K2T) into the top fuse formers it seemed a little too long and bowed former F7T. I did a double checked all the other interlocking pieces several times just knowing I had something out of whack. The only ill fit was at F7T I wound up cutting a little out of the notch in K2T and it all fit well. Will be interested if kdahlhaus has the same problem. ...or if I goofed something. Also, there are two sets of former F4T that fit along side FST. There is no notch in FST for the rear pair of F4T. No biggie. I didn't see it as a critical part and just sanded off the tab and glued it in. Did a quick mock up of the two fuse halves just to see what she'll look like. After scratch build four jets in a row working with these laser cut parts seems like cheating. ![]() Almost feels like I'm putting together an ARF.
