Old Oct 04, 2012, 10:54 PM
HoosierGuy is offline
Find More Posts by HoosierGuy
HoosierGuy's Avatar
United States, IN
Joined Jan 2012
What TX Do You Use for Electric Gliders?
What TX do you all use for your electric gliders? How many channels do you use on a regular basis and how many mixes, etc... do you use?
As for me - my electric glider is the Lanyu Evolution and I fly that with my DX6i. I don't use flaps but I could with my DX6i. My DX6i would be perfect but it has no telemetry and no light behind the screen.
I really like my DX6i and it's a great beginners radio. I'm very close to deciding on upgrading to a DX8 because I want telemetry now and also lighted screen.
I'm interested in knowing what everyone else uses.
HoosierGuy is offline Find More Posts by HoosierGuy
Old Oct 04, 2012, 11:30 PM
JimNM is offline
Find More Posts by JimNM
WAA-08 THANK FRANK!
JimNM's Avatar
Las Cruces, New Mexico, United States
Joined Jun 2002
FWIW, I have found telemetry to be of limited utility in flight. My radio shows battery voltage but I rarely check it. Whiz bang is what I call that .
Hitec A9. 6 or 7 channels, up to 5 mixes and 4 flight modes..
JimNM is offline Find More Posts by JimNM
Old Oct 05, 2012, 12:47 AM
ssulti is offline
Find More Posts by ssulti
ssulti's Avatar
Finland, Pirkanmaa, Siuro
Joined Aug 2012
Turnigy 9X, with open9X firmware and FrSky telemetry modules. Including telemetry mod to 9X so all information is shown on radio screen. And also norma extras like backlight and haptic mods.
Had no troubles while I was flying with stock 9X V2 RX/TX module set, but decided to buy FrSky to get telemetry - mostly due variometer and voltage information - and alerts because I probably won't be watching screen while flying.
Using this set to fly my Phoenix 2000 and created full-house mixing to it with camber/reflex/butterfly mixes and flight mode delays (open9x feature). I'll send that config if someone like to check it or test it out. Just pop an PM.
ssulti is offline Find More Posts by ssulti
Old Oct 05, 2012, 02:58 AM View Post
jiexiang007
A moderator felt this post violated the following rule: Excessive Advertising (Spam). Show it to me anyway.
Old Oct 05, 2012, 03:53 AM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
I use a DX5e to fly my Radian. No mixes.
Futaba 9C Super to fly Easy Glider and Sky Runner. Both are aileron gliders with no flaps.
mixes- flapperon, aileron diff, variable camber/reflex on side slider, flapperon to elevator fo landing mix.
aeajr is offline Find More Posts by aeajr
Old Oct 05, 2012, 05:29 AM
Piper J3 is offline
Find More Posts by Piper J3
Full Scale Piper Cub Driver
Piper J3's Avatar
Hinckley, Ohio
Joined Nov 2008
DX8 here. Been doing this since 1975 and I'll be Spektrum now until the end. The 8 has telemetry and all the bells and whistles. Flew my Sensor 117 3-meter sailplane today to 2654' altitude with only 14 missing frames and zero holds. 2654' is 1/2 mile straight up. That's confidence. Model match, telemetry with flight log to monitor RF link, ease of programming, backlight display, auto timer start, vibrator for warnings (I wear two hearing aides), DSMX, smooth gimbals, LiPo compatible with super long run time, excellent support. All this for ~ $400.
Piper J3 is offline Find More Posts by Piper J3
Old Oct 05, 2012, 07:22 AM
Leadchucker is offline
Find More Posts by Leadchucker
AMA7224 LSF1832
Leadchucker's Avatar
United States, DE, Seaford
Joined Sep 2008
Used Hitec Optic 6's for the last 5 years or so,they worked just fine even in the full house ships. Upgraded to the A9 this summer basically just to upgrade. I haven't needed all the additional capability yet but do find the touch screen much easier to fiddle with and I like the display. Main reasons for using the Hitec TX's is I like the layout and the feel of the Optics and A9, they fit my hands just right and are very comfortable to me.
Like Jim I find telemetry of limited value so far but it's nice to have in case I want to fool with it in something. I might employ the altitude telemetry when Hitec finally issues the module for it, however I'm not sure it will be legal to have it in operation in ALES contest. It could be considered a vario type link if you dare to look at it while in flight.
Leadchucker is offline Find More Posts by Leadchucker
Old Oct 05, 2012, 07:26 AM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
DX18 for me - it has sliders and I like that for gliders and electric gliders for flaps and crow.
Old Oct 05, 2012, 07:40 AM
timography is offline
Find More Posts by timography
Electric Glider Nut
timography's Avatar
Australia, WA, Perth
Joined Feb 2012
I started back into R/C aircraft only about 12 months ago. I bought a DX7s at the time and I have stuck with it so far. It works well enough - even with full-house programming for camber, reflex and flaps and crow. The only real disadvantage for me is, as I still fly powered aircraft as well and want to keep everything the same - so I keep the throttle where it belongs on the stick, but Crow is on the gear switch; so its either on or off. But I'm used to it now and I don't really see it as too much of a problem... well at least that's what I'll tell myself until the day I can afford a DX18 lol.
I have telemetry installed in all my aircraft and I have gotten quite used to taking quick peeks at the screen on the DX7s whilst I am flying - even specked out in a thermal - to see my current altitude and main flight battery/Rx voltages...
my 2c's worth...
timography is offline Find More Posts by timography
Old Oct 05, 2012, 08:05 AM
Hawksnest is offline
Find More Posts by Hawksnest
Hawksnest's Avatar
United States, PA, Perry
Joined Apr 2002
I fly all JR since 1990, currently a JR 9503, and a JR 12 X. both 50 model memory. Bill G.
Hawksnest is offline Find More Posts by Hawksnest
Old Oct 05, 2012, 08:19 AM
kilwein is offline
Find More Posts by kilwein
kilwein's Avatar
Joined Jan 2007
Had Cirrus, JR then Futaba 9ZHPS now Futaba 14MZ, use 3-12 channels, ET tele in a few of the planes.
Have 4 sliders 3 knobs, 8 switches, 6 trim controls along with the two sticks for lots of flexibility. Flaps on stick and slider, camber, reflex, crow all on sliders and or switches. Lots of model memory, 16K+ models, we wish.
Have mixing within mixing within mixing if you want to go there. Plus many other programming features. It is over kill but it is nice. Many ways to do same things, programming fun to be had.
Bottom line lots of good computer radios out there, find one that fits your current and future needs along with cost, get it and don't look back. If you can look at a buddies and get a hands on try that is nice. Other thing is if you are learning you may consider the brand most are using where you fly. Programming hell could be a issue on some. Having a buddy copy his program and dump it in yours could save some setup time, especially if you buy his old plane or get one like it. Some of the brands have online instruction manuals you can download and get a good look on it.
kilwein is offline Find More Posts by kilwein
Old Oct 05, 2012, 09:14 AM
Esprit Model is online now
Find More Posts by Esprit Model
espritmodel.com
United States, FL, Melbourne
Joined May 2010
This one is mine with full telemetry and tons of very interesting features.
My Albatros 3E and new 16-channel Jeti DS-16 transmitter with built in Variometer.
http://www.espritmodel.com/jeti-cz.aspx
Zb/Esprit Model
Jeti Telemetry Variometer w/DC-16 Radio (4 min 10 sec)
Jeti Duplex Telemetry Vario & Mezon Application
Jeti Duplex Telemetry Vario & Mezon Application (7 min 24 sec)
Esprit Model is online now Find More Posts by Esprit Model
Site Sponsor
Old Oct 12, 2012, 10:51 AM
raineswn is offline
Find More Posts by raineswn
Nashville, TN, USA
Joined Jan 2001
Just getting back into the hobby after a few years out.
My preference is electric launch sailplanes, V-tail and spoilerons.
Going back to a Multiplex Cockpit MM...does everything I want and I really, really like the servo travel limit setting.
Probably convert it to 2.4ghz at some point.
Too bad they didn't get the new SX type certified in the States.
Bill R
raineswn is offline Find More Posts by raineswn
Old Oct 12, 2012, 11:16 AM
B12 is offline
B12
Find More Posts by B12
B12
Finland
Joined Sep 2010
Flysky TH-9X with ER9X, backlight and Frsky DJT telemetry module.
Turnigy 9x with ER9X, backlight, stock AFHDS module.
11-20 mixes and 5-8 channels in use depending on model.
Staufenbiel Vitesse 3m full house all-rounder
Topmodel Prelude 2,5m full house thermal floater
Orion V3 warmliner
V-max eco warm(er)liner
I solved this by following mix (ER9X):
The throttle is where it should be. When I flip throttle cut it cuts the throttle and turns the throttle stick into flap/crow control. From bottom to middle it only lowers the flaps and after that it starts to raise the ailerons for crow/butterfly.
B12 is offline Find More Posts by B12
Old Oct 13, 2012, 01:55 AM
tkallev is offline
Find More Posts by tkallev
LSF303-AMA Fellow
tkallev's Avatar
USA, IL, Wheeling
Joined Jan 2003
JR 12X ... 7 channel RX for full house e-sailplanes.
tkallev is offline Find More Posts by tkallev
Question What Stand are you using for your glider ? FRIDAY_2008 Sailplane Talk 23 Oct 07, 2012 11:22 AM
Question What do you use for wing tape on 3 piece wing hog2soar Sailplane Talk 14 Aug 31, 2012 01:28 PM
Discussion Using Virtualdub to record FPV - What settings do you use? NorCalMatCat FPV Talk 12 Feb 25, 2012 08:33 PM
Question What TX do you use for your multicopters? JossyRC Multirotor Talk 12 Mar 12, 2011 12:20 PM
Discussion What radio do you use for gliders? raptor22 Slope 37 Mar 08, 2006 09:29 PM
