Old Oct 17, 2012, 08:28 AM
OCD RC Freak
United States, CA, Riverside
Joined Aug 2011
Well, got the kit pretty much put together, just need all my electronics now, shipped yesterday from honk kong... Tail rotor is spinning the wrong way so I think I need to adjust the twist in the belt. Am I right?? Anyway, this is what I ordered (for now)
4400kv, turnigy motor
Red brick 50A heli mode ESC
3ea turnigy 1800 cyclic servos
One HK high speed, digital MG servo for the tail
An 11 and 13 tooth pinion
One HK401b gyro (will upgrade later)
I already have some 2650mah 3S batteries, hopefully not too heavy
And not sure which radio to use yet, I have an airtronics rds8000 and the turnigy 9x v2
Comments? Suggestions? And I know about the gyro, just can't afford a different one right now)
chuckman49 is offline Find More Posts by chuckman49
Old Oct 18, 2012, 08:23 AM
OCD RC Freak
Joined Aug 2011
Yep!! The twist in the belt was the cause. Quarter twist the other direction and voila!! Tail rotor spinning in the right direction! Any suggestions as to which radio I should use (see above post)
Old Oct 25, 2012, 03:51 PM
If I build it, it will fly
United States, OR, Portland
Joined Jan 2012
I have the 9x v2 (mode 2) and love it. My 450 has a terminal case of bad electronics (all servos under $10ea & a bumb ga250), but the TX/RX have yet to give me any issues. Added a back-light kit to my 450, love it.
~psguardian
psguardian is offline Find More Posts by psguardian
Old Oct 25, 2012, 05:33 PM
OCD RC Freak
Joined Aug 2011
~psguardian
Cool, thanks for the suggestion, that's the radio I wanted to use anyway! I did the green backlight mod and love it. I use that radio for 3 of my planes. Never had one issue! Just never done helis. Before so programming will be fun for me. Seen plenty of you tube videos with programming suggestions though so I should be ok. Still waiting for all my electronics, Hong Kong must be far or something... Ha ha LOL!!!!
Old Nov 04, 2012, 05:04 PM
OCD RC Freak
Joined Aug 2011
OK so here I am, completely done building my new Heli and having some serious issues! Setting up the gyro of course!! I can get the gyro to switch between HH mode and Rate mode but thats about it!! Ive read every setup article, watched every setup youtube video and it's all crap!! No matter what settings I use it either spins out of control or drifts it doesnt lock for anything!! I am using the Turnigy 9X V2 and HK401b... Any help here would be great!
Old Nov 04, 2012, 05:09 PM
Joined Jan 2012
I had the spinning out of control issue, direction reversed on gyro setup.
The hk401b have been reported as being loose in the case, due to only being held in place via the wires. A few videos on it show taking it apart & removing the film from the dip switches, laying it back in the case, filling case with hot glue or silicone & putting the base back on. This eliminates vibes induced by theboard bouncing around inside the case.
Hope these two points put you on track to a steady tail.
~psguardian
Old Nov 04, 2012, 05:12 PM
OCD RC Freak
Joined Aug 2011
tested direction already, and already did hot glue fix...
Old Nov 04, 2012, 05:30 PM
Joined Jan 2012
If tall drifts in one mode & piros in the other, I think it's a gain issue.
Or bum gyro?
~psguardian
Old Nov 04, 2012, 05:31 PM
OCD RC Freak
Joined Aug 2011
Holy crap!! I retested direction and you were right, it was reversed!! Not sure what the heck I was thinking.... going to have to try again!!
Old Nov 04, 2012, 06:18 PM
OCD RC Freak
Joined Aug 2011
YEAH BABY!! She flies!! Hovers like a dream!! I 'm using a 4400kv motor with an 11t pinion. The 50 amp ESC is getting pretty hot, and I'm just hovering... does this sound right?? I forgot to mention that on my throttle curve it only goes from 0 - 80% I figured this would be plenty for hovering
Old Nov 04, 2012, 06:52 PM
Joined Jan 2012
SWEET!
Now onto the heat,
A. Hovering is hard on ESCs cuz the rotor disc is living in 'dirty air' (sitting on it's own down wash)
B. Not much air moving over it compared to normal flight.
C. Motor draws more due to A.
What motor are you using? It's time to pull out the dark horse calc & find you a stable head speed.
~psguardian
Old Nov 04, 2012, 07:02 PM
Joined Jan 2012
Turnigy 2223 H 4400kv... Ok I should have just scrolled, but i'm lazy Sry bout that.
So what are your collective & cyclic pitch limits set to? Do you know your all up weight with that 2650mah Batt?
~psguardian
Old Nov 04, 2012, 07:28 PM
OCD RC Freak
Joined Aug 2011
My what and my huh??? :-) I'll get back with you about all up weight, going to make dinner right now, my throttle is limited to 80% by my throttle curve, and my pitch is set from 0-10 degrees, I'm hovering right now at about 45-50% throttle and about 5deg pitch. Does that answer your question?
Old Nov 04, 2012, 07:37 PM
OCD RC Freak
Joined Aug 2011
Here's a quick vid... I guess all that Simulator time paid off...
HK450 V2 first hovering attempts (4 min 7 sec)
Old Nov 04, 2012, 08:08 PM
Joined Jan 2012
0-10° would be the collective pitch (swash plate moving up/down level). Cyclic pitch is the measure of pitch from forward/back or left/right inputs... Your throttle & collective pitch are controlled by your left stick & your cyclic inputs are on the right stuck (for mode 2 radios).
Your first hover looks better than any of mine so far... But then I haven't had the benefit of SIM time either. My win 7 & XP machines both HATE the SIMS I've tried.
~psguardian
New Product Hobby King Sbach 342 v2 balsa 1000mm kmdunnster Electric Plane Talk 56 May 01, 2013 01:30 PM
Alert Hobby King 450Pro V2 Flybarless Upgraded Heli New Release $58 Mahu Hot Online Deals 2 Jun 16, 2012 04:06 PM
Help! hobby king multicopter control board v2.1 colliams Multirotor Talk 1 Jun 08, 2012 08:50 PM
Discussion Hobby King FPV/UAV V2 or EPP FPV? onboardtherc Video Piloting (FPV/RPV) 7 Mar 19, 2012 10:19 AM
Sold [Sold] - Like new Hobby King 2.4Ghz 4Ch Tx & Rx V2 (Mode 2) HK major.monogram Aircraft - General - Radio Equipment (FS/W) 14 Feb 29, 2012 01:09 PM
