Spektrum DSM2 ladybird v1/v2 & 939 flight control board discussion
This thread is being started based on a discussion that started in the Micro RTF Quadcopters Thread, due to possibly being a whole different type of thread based around the product being offered.
This is not the mqx/ladybird hybrid that has been discussed in other threads, but yet a new board that has been created as an exact drop in, in place of the ladybird/v939 board in order for your quad to be controlled using a DSM2 Spektrum Transmitter to fly the ladybird/v939. At the moment little is known about it due to no one (at least on the forums) having one yet or hearing any real information on it. However a few have ordered them and hopefully we will learn if this will allow us to fly the ladybird/v939 with the same precision and maneuverability as the original while using a Spektrum Tx. So far the 2 places that seem to have it for sale are: 9imod.com and hobby-wing.com EDIT It seems that there are three places now carrying a BNF version. So all you'll have to do is charge up the 240mah lipo and bind to spektrum radio and you're ready to go. Here are links for the BNF version. 9imod.com rc711.com hobby-wing.com Product Description The Flight-Ctrl Board is a DSM2 system for Quad-copter, compatible with all JR, Spektrum DSM2 system 2.4G requiring full range 5ch up transmitter. This Controller could be used to modify V939, Ladybird, Ladybird V2. Specification: Remote control distance: > 80 m Drive motor current: 1500 mA Low-voltage protection: 3.0V Fail-Safe: after 2 seconds closing motor output Outline dimension: 25 * 26 mm Mounting hole size: 20 * 20 mm II. Mode of Connection ![]() Connect the motor to flight control board in accordance with the above method, when the motor rotating in the opposite direction, swap two motor lines to adjust. III. Bind: The Flight-Ctrl Board must be bound to the transmitter before it will operate for the first time. The detailed operation is as follows: Do not turn on the transmitter at first, but power on the Flight-Ctrl Board. Wait for LED starts blinking fast, then the Flight-Ctrl Board will be into frequency mode£»turn on the transmitter bind switch to boot (Same as the ordinary receiver frequency mode, referring to the instructions of the remote control), when the FC board LED flash slowly means radio has received signal, do not move the FC board at this time until the LED stays on, it can flight directly after LED lit. It is unnecessary to bind with transmitter next flight, but turn on the transmitter at first, and then power on flight control board. IV. Flight control board power-up initialization The FC board will be initialized when it connects to power. Once it connects to power, LED will flash, and then FC will wait for transmitter signal. Make sure you have opened the remote control and joystick (including Trim) is in the middle. Under the throttle channel joystick is in the smallest, and the LED is not lit during waiting for the remote control signal. If no signal is received within the specified time, then enter the frequency mode. Receiving the remote control signal, it will go into the gyroscope self-test status, at this time the LED will flash every two times. Keep the FC circumstance no vibration, nor could get in the hands. When Gyro self test is completed and LED stays on mean it can fly. V. Low-voltage protection when the battery voltage is lower than 3.0V, the FC will go into the low voltage protection mode. Then LED will flash, while slowly reducing the speed of the motor until the motor stops. VI. Fail-safe Motor will stop in 2 seconds when the flight control can not receive the signal. VII. Flight control parameter adjustment UPDATED This has been updated to the directions created by Oxygen which worked for him, myself and others, so a huge shout out for the correct way to set this quad up I figured it out (with some help from others) this is my setup on my DX6i My goal was set to have the board/LB react to the GYRO switch to switch from 3D mode (10%) to Stable mode (55%) 1. remove power from the LB and set all the switches on the TX to there default 0 position 2. power up the TX and select a new model (or reset a model) 3. set model type to HELI 4. set model name [something usefull] 5. check that all REVERSE options are set to N 6. set SWASH TYPE to 1 SERVO 90 7. check that D/R EXPO is all 100% 8. set TRAVEL ADJ GYRO to 55% (switch position 0) 9. flip the GYRO switch (to position 1) and set TRAVEL ADJ GYRO to 10% (this will be 3D mode) 10. check that SUB TRIM is all 0 11. check that GYRO is set to INH 12. all other MIX options should be INH 13. power down the TX 14. power the Ladybird 15. wait until the light blinks fast 16. power the TX with the trainer button (BINDING MODE) and wait for the light on the LB to blink slower -- and release the Trainer button (TX stops beeping) 17. wait for a steady light on the LB You are DONE P.S. remember you are still in 3D mode (gyro/flap switch is in the 1 position) -- and that is a lot of FUN but a bit hard for a beginner P.P.S. if you go over 60% there will be a very noticeable wobble in the bird in low throttle mode P.P.P.S if you change the GYRO switch while in flight it will not alter the Flight Characteristics!!! you have to move throttle back to 0 (on the ground) to achieve that! Due to the different models, definition of the remote control may not be exactly the same, so please be sure aircraft movements before the first flight This Controller could be used to modify V939, Ladybird, Ladybird V2. From a few video's it seems to be very stable and in the one outdoor video you can see it is extremely windy and yet the wind doesn't seem to effect the stability of the quad. First here is a video showing how easy the switch is from 9imod's website:
Here is a video of it flying indoors:
A video flying outdoors in heavy winds:
Video from rc711.com
Ultimately I think this will be interesting to see how well it performs in all situations. If the ladybird/v939 doesn't lose any of it's flight characteristics which in my mind are just incredible as is, then I think this could be a huge seller. I loved my mqx/ladybird hybrid, but #1 it involves a little stripping of wires and the board is really large for the size of quad and using larger batteries really weighed it down. #2 even though it was aerobatic, I find it sluggish and slow in it's flips and rolls after doing the same maneuvers on a real deal ladybird. #3 this is about as plug and play as you get and you can still use the stock canopies. #4 many like to led mods and with this it seems as though it would also be plug and play. Just byv939 booms plug them in and you're good to go. |
Hobby-wing.com is selling a BNF model
You can check it out here: http://www.hobby-wing.com/dsm2-quadcopter-arf.html |
New York
Joined Oct 2008
this looks very interesting. can you tell me what advantages it might have over the lower cost blade board used in this thread:
http://www.rcgroups.com/forums/showthread.php?t=1647401 this new board is significantly more expensive. but maybe it has more features? new modes that the mqx dont have? that mqx project is the one that inspired me to build my own micro hybrid in the first place. however since im a flysky fanboy the wlt v929/v939 was a better choice. i do have a spektrum radio but never use it. is there anything special about this new one compared to the mqx or v929 version. if so it might be worth the extra bucks and dusting off the spektrum. |
I found this http://www.rc711.com/shop/micro-4ch-...xs-p-6785.html
BNF for 79$ shipping included. Still a little on the expensive side... But less than the 21$ for shipping alone that I read somewhere else. @dehicka : is it me or you had to file your board a little ? Second pic one of the corner appear filed. btw where did you found the micro-JST ? |
Russia
Joined Nov 2007
My old v929 board was a donor for the connectors. But you can get them from ebay or HK http://www.hobbyking.com/hobbyking/s...5pcs_bag_.html |
Thanks for the plugs.
Found another site even cheaper on the BNF and free shipping. http://9imod.com/index.php?main_page...oducts_id=2060 They claim to have more than 300 units in stock. Grabbed one couldn't pass a bnf dsm2 for 56.29$ shipped, could I ? ![]() Only the shipping is noted as "best way", don't know what that means. Hope it is not a 60 days slow boat ![]() The board is also cheaper than others. |
| Thread Tools | |
| For Sale Mcp x V1 & V2 Flybarless 3in1 Control Boards $45 each | tunnelvision | Aircraft - Electric - Helis (FS/W) | 8 | Sep 08, 2012 11:23 AM |
| Discussion Alternative MK Flight Control FC v1.33 - v2.0 MK THREAD | Quad_Addict | Multirotor Talk | 4985 | Aug 18, 2012 07:21 AM |
| Wanted X AIRCRAFT AHRS + Flight Controller - V1 or V2 | Jelico | Aircraft - Electric - Multirotor (FS/W) | 3 | Mar 24, 2012 04:44 PM |
| Found Looking to trade mcpx v2 board + extras for v1 board | f.a.r.m.e.r | Aircraft - Electric - Helis (FS/W) | 1 | Mar 14, 2012 10:48 PM |
| Sold MK Clone FLight control v1.35 gold edition & Dist board | Quad_Addict | Aircraft - Electric - Multirotor (FS/W) | 11 | May 26, 2011 09:00 PM |
