Old Oct 04, 2012, 12:39 PM
jrb is offline
jrb
Find More Posts by jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
How to straighten an aluminum wing tube?
Got a bit of a bend during a hard landing – what’s the best way to get an aluminum wing tube straight again?
Pushing a dowel into it?
Chuck it in a lathe and add a bit of pressure?
TIA,
Jim
jrb is offline Find More Posts by jrb
Old Oct 04, 2012, 01:11 PM
rtbates is offline
Find More Posts by rtbates
Joined Mar 2010
buy a new one... anything you do will result in a weak spot at the kink...
rtbates is offline Find More Posts by rtbates
Old Oct 04, 2012, 02:12 PM
Mr. foambuilder is offline
Find More Posts by Mr. foambuilder
I fly 3-C Crash,Crunch,Crumble
Mr. foambuilder's Avatar
USA, NM, Clovis
Joined Feb 2010
I'm a retired machinist, and believe me, you will never get it straight, and it will always have a kinked spot in it. As stated b4, just bite the bullet and buy a new one. I aactually found one at an Ace hdwe, that was close enough to use. Roy
Mr. foambuilder is offline Find More Posts by Mr. foambuilder
Old Oct 04, 2012, 03:31 PM
Rockin Robbins is offline
Find More Posts by Rockin Robbins
Drone offender FA377YHFNC
United States, FL, DeLand
Joined Mar 2009
Run over it with a car?
Rockin Robbins is offline Find More Posts by Rockin Robbins
Old Oct 04, 2012, 05:10 PM
Piece is online now
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
Ask it nicely.
Piece is online now Find More Posts by Piece
Old Oct 04, 2012, 05:26 PM
RC Man is offline
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
Aluminum does not straighten well.
Just replace it with carbon fiber and you will never have that problem again.
RC Man is offline Find More Posts by RC Man
Old Oct 04, 2012, 05:30 PM
Lardog is offline
Find More Posts by Lardog
ex-noob
Lardog's Avatar
Sammamish, WA, USA
Joined Jan 2010
Right, instead you'll have a broken/cracked wing tube and no desire to try and straighten it.
Lardog is offline Find More Posts by Lardog
Old Oct 04, 2012, 08:18 PM
Evan D is offline
Find More Posts by Evan D
Evan D's Avatar
Charlotte, NC
Joined Jan 2004
Put it in a press and bend it back 180, no that won't work either....
Evan D is offline Find More Posts by Evan D
Old Oct 04, 2012, 09:19 PM
fastfwd is offline
Find More Posts by fastfwd
United States, ID, Burley
Joined Mar 2012
http://www.goodwinds.com/merch/list.shtml?cat=carbon any carbon rod you want
fastfwd is offline Find More Posts by fastfwd
Old Oct 05, 2012, 09:18 AM
solentlife is online now
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
The usual way is to force an interference fit rod down the tube. But as others say - it's a weakened tube and best replaced.
Personally I would not replace with CF - there is a reason for choice of material and making it more stronger may in fact create another problem that is harder to correct.
Most tube can be found at DIY stores ... and no need to pay out LHS inflated prices ... (sorry shops ... )
Nigel
solentlife is online now Find More Posts by solentlife
Old Oct 05, 2012, 12:41 PM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Chucked them up in a lathe and used a live center to keep the tube straight.
Then drove (attempted to) a wooden dowel into them -- didn't keep them straight .
Maybe I'll find some when I'm in Taipei next week as I can't find them here: OD/ID/L (mm), 15 / 13 / 315 & 10/ 8 / 175 .
Old Oct 06, 2012, 09:19 AM
LesUyeda is offline
Find More Posts by LesUyeda
LesUyeda's Avatar
San Diego, California
Joined Dec 2004
I have straightened motorcycle fork tubes by putting supports under each end, bend on top, and applying force to the top of the bend.
Les
LesUyeda is offline Find More Posts by LesUyeda
Old Oct 06, 2012, 11:36 AM
xrx1113 is offline
Find More Posts by xrx1113
xrx1113's Avatar
United States, FL, Lehigh Acres
Joined Aug 2011
Its gone.
xrx1113 is offline Find More Posts by xrx1113
Discussion how to straighten a steel wire modelerchina The Builders Workshop 27 Nov 15, 2013 06:57 AM
Discussion How to straighten a wood fuselage (pico stick) Lhorn Beginner Training Area (Aircraft-Electric) 4 Jul 27, 2012 02:59 PM
For Sale 6 sq tubes = 1/2" x 1/2" x 2' feet .062 walled aluminum square tubing Percalotor - Quad_Addict Aircraft - Electric - Multirotor (FS/W) 1 Jul 23, 2012 11:53 AM
Help! How to straighten an aileron??? fabmaster911 Sailplane Talk 2 Jul 18, 2010 09:20 PM
Need help fixing my obechi foam wings (replacing aluminum tube for carbon wing rod) bfraser The Builders Workshop 4 Dec 29, 2003 08:08 AM
