Go Back   RC Groups > External Feeds > Mailing Lists > EFLIGHT Mailing List
Old Dec 01, 2003, 07:03 PM   #1
Jim Keller
Guest
Posts: n/a
[EFLT] Astro Charger as a Power Supply
This message from "Jim Keller" <jkeller1@peoplepc.com> brought to you by EFLIGHT!
The Astro 110D charger has a "Test" mode that allows
one to provide a constant DC voltage via the current
adjust knob. I've used this mode to power brushed
motors at low voltages for break-in. Therefore, the
110D can be used as a power supply (yes, I know you
need another power supply to power it - just bear with
me here). Since it can charge up to 18 NiCd cells, it
must be capable of around 22 volts.
But here's my question. If you need around 18 vdc to
charge a 3 cell LiPo pack using a multi-cell LiPo
charger, and you only have a 12 (or 13.6) vdc power
supply, can the Astro charger be used for this purpose?
Perhaps Doug Ingraham can address this.
________________________________________________
PeoplePC: It's for people. And it's just smart.
http://www.peoplepc.com
*** Any complaints or problems? Send an email to monitor@ezonemag.com
*** For help with list commands go to http://www.ezonemag.com/pages/mailhelp.htm
*** For the list rules go to http://www.ezonemag.com/pages/mailrule.htm
Old Dec 01, 2003, 07:03 PM   #2
Doug Ingraham
Guest
Posts: n/a
Re: [EFLT] Astro Charger as a Power Supply
This message from Doug Ingraham <dpi@rapidnet.com> brought to you by EFLIGHT!
The 110D 110DX 112D 112DX and the new 109 all have voltage boost
circuitry. The 109 and 110 series can boost to about 30 volts. The 112
can boost to as much at 80 volts. When boosting the input current will be
higher than the output current because watts in must equal watts out. If
the charger was perfect efficiency with a 12 volt input and a 24 volts
output the input current would be twice the output current. Since the
charger is something over 90% efficiency the input current will be a bit
higher than twice the output current in this case.
Without modification it would be a bad idea to try to use the 110D charger
to boost the 12 volts input to 18 volts to feed another charger. This is
because the charger controls current, not voltage as configured. Small
changes in load will dramatically change the output voltage. You would
need to change the feedback loop so that the charger was a constant
voltage output rather than a constant current.
Doug Ingraham
Rapid City, SD USA
Old Dec 01, 2003, 07:03 PM   #3
Doug Ingraham
Guest
Posts: n/a
I should have pointed out that you only need a little over 12.6 volts to
charge a 3S pack. You need a little over 16.8 to charge a 4 cell pack.
Doug Ingraham
Rapid City, SD USA
Using my car charger as a power supply question cat5 Batteries and Chargers 24 Nov 17, 2005 09:14 PM
Rave How to use the ATX PSU as a power supply for charger? BlitzDude Batteries and Chargers 4 Apr 27, 2004 03:42 AM
Using Automotive battery charger as a power supply? DRR EFLIGHT Mailing List 3 Nov 13, 2003 07:02 PM
Battery car charger used as a power supply?? Sylvain Batteries and Chargers 7 Feb 19, 2003 10:17 AM
WANTED: Best Price for Astro Flight 120 Power Supply CheeseWing Parkflyers 3 Aug 03, 2001 12:32 PM
Bored? Want to fight?
Join the RCGroups clan!
