Old Oct 04, 2012, 11:22 AM
Rob_P is offline
Find More Posts by Rob_P
Rob_P's Avatar
Grosse Pointe, Mi
Joined Jun 2005
Control for twin rudders?
I just planning out a "prospective" future build at the moment and I'm looking for feedback.
Is there a simple way of controlling two rudders from one servo?
The plane that I have in mind is the KK Invader. I built one as a child and it never did perform well as a glider but I like the shape and think that it might make a nice candidate for light electric power and an RC conversion.
Should I try and mechanically link both surfaces and use a bell crank to push / pull on one of the rudders?
Would it be better to come off both sides of the servo arm with flexible push rods to control horns mounted on each rudder?
Robert
Rob_P is offline Find More Posts by Rob_P
Old Oct 04, 2012, 01:32 PM
Sundancer is online now
Find More Posts by Sundancer
I like real wooden aeroplanes!
Sundancer's Avatar
South-west France
Joined Sep 2007
Pushed my memory button there Rob, the Invader was the very first successful flying model I ever built, mine went rather well about sixty years ago.
It is going to be tricky to drive the twin rudders on a model as small and light as the Invader, especially with the dihedralled tailplane. This latter feature would make it very tricky to use a centre crank and rods (the dihedral is also going to complicate the elevator linkage). I doubt that snakes of any sort would work. I wonder if it might turn OK with just one rudder working? But I'm not sure even how best to drive that. The best answer might be to build it 1.5 or 2 times and use two micro servos in the tailplane.
Sundancer is online now Find More Posts by Sundancer
Old Oct 04, 2012, 02:47 PM
owlsabie is online now
Find More Posts by owlsabie
owlsabie's Avatar
South Africa
Joined Feb 2009
Would it work to drive the elevators seperately so that do pitch and roll? Like on a vee tail?
owlsabie is online now Find More Posts by owlsabie
Old Oct 04, 2012, 03:26 PM
Guizzo 17 is offline
Find More Posts by Guizzo 17
Guizzo 17's Avatar
Joined Sep 2007
I use a torsion bar in the rudder hinge and a pull cable that goes to the rudders servo.
http://static.rcgroups.net/forums/at...ide%20view.jpg
see also here.
http://www.rcgroups.com/forums/showt...6#post20594808
Guizzo 17 is offline Find More Posts by Guizzo 17
Old Oct 04, 2012, 03:28 PM
GeeW is offline
Find More Posts by GeeW
SB-28 UK Display Pilot
GeeW's Avatar
ENGLAND
Joined Jul 2001
Pull string to actuate inner rudder only. Small elastic band to centralise rudder when servo centres. So each rudder only works in one direction.....if that makes sense?
I have this on a small canard model (circa 36"span). Works very well, so long as you renew the 'lacky bands regularly.
Gordon
GeeW is offline Find More Posts by GeeW
Old Oct 05, 2012, 08:59 AM
Circlip is offline
Find More Posts by Circlip
Bradford West Yorkshire, UK
Joined Apr 2010
Anyone got a copy of the R6B plan?
Regards Ian.
Circlip is offline Find More Posts by Circlip
Old Oct 05, 2012, 09:19 AM
bogbeagle is online now
Find More Posts by bogbeagle
Joined Mar 2007
That is going to be tricky. There is usually a lot of lost motion with twin-rudder setups.
I did think that you could hinge the whole tailplane, such that it rotates a few degrees about the normal axis. But, that might complicate the elevator' arrangement ... if you are fitting an elevator, that is.
I like the idea of the single rudder. And, I like the idea of the pull-only system, with a spring return.
If it were mine, I'd plump for the latter, I think. Very light pull-wires could be reasonably routed around the various angles and the whole set-up should be quite positive. I've certainly used flying controls that are spring-biased ... admittedly, on a much larger model ... but they worked really well.
I once knew a bloke who used a similar system to control the throttle on a Tartan Twin. Basically, he had a bit of string which pulled the throttle to OPEN; the thottle returned to CLOSED under its spring pressure. Sounds a bit crap, but it was a really good system, because it was easy to route and it completely isolated the servo from direct engine vibration.
bogbeagle is online now Find More Posts by bogbeagle
Old Oct 05, 2012, 10:33 AM
California Condor is offline
Find More Posts by California Condor
Old Timer
California Condor's Avatar
CARMICHAEL, CALIFORNIA USA
Joined Apr 2001
This one uses pull with a torsion spring to return. Rudders move out.
California Condor is offline Find More Posts by California Condor
Old Oct 05, 2012, 11:11 AM
Rob_P is offline
Rob_P's Avatar
Grosse Pointe, Mi
Joined Jun 2005
Thank you for the feedback, plenty to think about.
I'm intrigued about treating at as V tail as I'd have to split the elevator anyway. However the standard dihedral of the rear stabiliser is probably not enough.
California, thats a very nice plane, do you have any pics that show the pushrod / control horn set up?
Rob
Old Oct 05, 2012, 11:49 AM
BMatthews is offline
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
Like you suspect I think that the elevators are simply too shallow an angle for good rudder response. Also you'd have the fixed fins fighting to "correct" for the yaw produced by the ruddervators which would further reduce the yaw effectiveness.
The idea of tensioning the rudders and then using pull only lines is a good idea for a model of this size and flying speed. You want to arrange it so that the spring or rubber tensions are opposing each other so that when the lines come together at the servo or bellcrank arm that they are balancing each other and the servo doesn't see much spring force. Otherwise it'll load up the servo needlessly.
BMatthews is offline Find More Posts by BMatthews
Old Oct 05, 2012, 01:36 PM
Sundancer's Avatar
South-west France
Joined Sep 2007
From experience with a number of "V" tail rudder/elevator gliders I am certain that the angle on the Invader's tail is too shallow to give adequate rudder control. I found that the maximum included angle of the "V" for decent rudder effect is 110 degrees, i.e. each tail half inclined at 35 degrees above the horizontal. Spring centred rudders with pull action certainly sound the best bet on a model of this size.
Old Oct 05, 2012, 04:14 PM
LazyGlider is offline
Find More Posts by LazyGlider
Wildsteig (Germany, Bavaria)
Joined Mar 2009
Have a look on
http://www.antiquemodeler.org/sam_ne...sets/dt162.pdf
there is the BULLETIN No. 162 of SAM 1788 (Australia) January - February 2010. Go to page 8. Twin Rudder Linkage Systems. There is shown a tricky twin rudderlinkage made by Geoff Dunmore for small models about forty years ago.
Sincerely Yours
Helmbrecht
LazyGlider is offline Find More Posts by LazyGlider
Old Oct 06, 2012, 12:56 AM
Sundancer's Avatar
South-west France
Joined Sep 2007
Now that is CLEVER and so neat. Definitely one to file away for future use. Thanks for the lead.
Old Oct 06, 2012, 01:23 AM
sparks59 is offline
Find More Posts by sparks59
Sic itur ad Astra
sparks59's Avatar
United Arab Emirates, Abu Dhabi, Abu Dhabi
Joined Aug 2009
I agree with SD. Geoff Dunmore's method is neat and well thought out. Might even build a twin fin just to have a go!
sparks
sparks59 is offline Find More Posts by sparks59
Old Oct 07, 2012, 10:27 AM
imp.bob is offline
Find More Posts by imp.bob
Bob Imp
UK, Cardiff, Cardiff
Joined Nov 2006
Originally Posted by LazyGlider View Post
Have a look on
Sincerely Yours
Helmbrecht
Very clever indeed! Shows there`s always something to learn even after nearly 70 years of aeromodelling!
imp.bob is offline Find More Posts by imp.bob
Discussion Help needed for mixing twin engines to rudder- Futaba Vapor Trails Radios 4 Jul 23, 2012 04:23 PM
Discussion Independent twin elect.motor control for PT Boat Project azcaptain Scale Boats 11 Jun 24, 2012 03:50 PM
Discussion Twin Engine Rudder Mixing Screw Electric Plane Talk 7 Jun 13, 2012 04:24 PM
Discussion Rudder servo control on (left)throttle stick -vs- rudder control on (right)stick. chewbaca Electric Plane Talk 17 Feb 01, 2006 08:16 PM
Viper Twin - no rudder control zax Foamies (Kits) 6 Apr 01, 2002 11:24 AM
