United States, IL, Chicago
Joined Nov 2007
Rather than using a bird-bath heater, I found this nice line-voltage thermostat for under $30.
http://www.zorotools.com/g/Portable%...tats/00053176/ I plan to put that in a picnic cooler connected to a drug-store heating pad. Set to 45 degrees it should keep the batteries very comfortable indeed. Now, keeping them cool in the summertime, when the garage can reach 95-plus, is a different story. I guess a small fridge will be in order. |
Chicago 'burbs
Joined May 2006
If it fails, good-bye garage! |
Joined Nov 2007
http://www.oreillyauto.com/site/c/de...0649&ppt=C0076 And these "Battery box heaters" http://www.oreillyauto.com/site/c/de...0651&ppt=C0076 http://www.autopartsandstuff.com/zer...rywarmer2.aspx |
Joined Feb 2011
If it matters at all ThunderPower says store at 40F-70F:
http://thunderpowerrc.com/documents/Winter.pdf If you are going to keep them in the garage at least make sure you keep them on the opposite side from all the flammable stuff normally in a garage. If you're going through all that trouble why not just bury them under ground below the frost line? |
Joined Sep 2012
A very low wattage light bulb in the cooler with two thermostats with the apropiate temperature range in series. Just in case one sticks. This is unlikely with a device drawing so little current. Not new thermostats unless cheap either. Plenty of good used ones should be out there. Actually in this application I would never rely on just one thermostat.
United States, MA
Joined Jul 2012
Here in eastern Massachusetts we occasionally get nights down below -10F. A garage attached to a house will stay a bit warmer than that, if the doors seal well. But it is getting down to questionable range. And if your garage is attached to your house, you're not really helping by putting the lipos in the garage anyway.
Hi Guys,
I can get rather "anal" about things also and was worried about where to store and charge lipo batteries from the day 6 years ago when I got into RC electric airplanes. At first, I charged them in my house, on some ceramic floor tiles, which are obviously fireproof. Then, a very informed guy on this forum mentioned to me that my charging method would prevent a possible fire, but he pointed out that the bigger problem if a lipo should "blow" is the toxic fumes that are emitted. Obviously, I don't want to kill my little dog and wife with toxic smoke (okay, at least not the dog). So, I began charging on my workbench in my garage, again on ceramic floor tiles (and the lipos in a fireproof "Lipo Sack"). With the garage door open, along with the back door out to the yard, at least if a battery "blew", the smoke would exit harmlessly out of the garage. Now, regarding storage. Two years ago, I bought 10 high-quality lipos, again recommeded by a very informed forum member and stored them in Lipo Sacks in my garage, on top of my workbench covered with tiles. I stored them fully charged so they'd be ready whenever I went flying....and sometimes they would sit there for days or weeks, fully charged. Temperatures here in Connecticut can be very warm in the summer and cold in the winter. After 2 years of storing them in my garage and with over 200 cycles on each battery, they only recently were retired...mostly due to them swelling and losing some of their "strength". I feel I got my monies worth out of them at this point anyway. Now, going forward, I've been convinced that I should change my storage procedure. I'm going to store them at 50% charge and only charge them as I need them. I bought a deep cycle battery that I can bring to the field and charge my batteries as I fly. I can also charge some before I leave for the field using house current from my 10amp power supply. I've been convinced that while 2 years and hundreds of cycles was a good "return on my investment", that with my new procedure, I may get even more cycles and years out of my new batch of batteries. I'll definitely let everyone know the results of my experince in a couple to three years. Obviously, it was easier to just fully charge a battery after a flight and store them fully charged. It takes a little more planning and thought to be sure to only charge what you need and sometimes, I end up having to wait for a battery to charge at the field because I didn't plan properly or I've decided to get "one last flight in". I'll see if the new procedure, with its new complications, is worth the effort. I hope this helps, Mondo |
Joined Nov 2007
AeroKen, the garage is detached. A car returning from a trip will keep it reasonably warm for a while, but not something to rely on here on the prairies. Ebill3, I would also have thought cold temps would not be a problem, but as I wrote a few posts back, the ThunderPower guys said not to let them get below 32. Perhaps they are doing a COA for lawsuits. |
| Thread Tools | |
| Discussion charging 1s lipo that has a built in protection circuit | iamsuperbleeder | Batteries and Chargers | 2 | Jul 01, 2012 10:38 PM |
| Yet another Lipo lvc to protect from undervoltage on older esc's: schematic | kodel | DIY Electronics | 98 | Jun 27, 2009 04:40 PM |
| Discussion Winter flight under freezing point | VRflyer | Video Piloting (FPV/RPV) | 15 | Jan 21, 2008 08:10 PM |
| Cool For those of you freezing in the midst of winter... | AnthonyRC | Electric Heli Talk | 9 | Mar 10, 2006 01:14 PM |
| Recommendations for R/C winter gloves. (My hands are freezing!) | 717 | Electric Plane Talk | 35 | Dec 05, 2003 09:47 AM |
