Old Oct 15, 2012, 11:57 AM
igotit is offline
Find More Posts by igotit
United States, LA, Houma
Joined Jun 2008
placed ad in classified boats section.
igotit is offline Find More Posts by igotit
Old Oct 16, 2012, 12:44 AM
igotit is offline
Joined Jun 2008
ran 7 test like this today...im trying to destroy these gears.
ok we seen the torture test vids right...just pulled her down.....looks the same as the last time i pulled it down.only damage to the gears is my fault,the motor coupling set screw backed out and allowed the vertical shaft and gear to rise,rounded off the tips of the gears....very slight damage.
im impressed,anyone want repeat the same test on stock gears....lol.
Old Oct 16, 2012, 01:11 AM
Kmot is online now
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Whoa! That is an electric powered trim you installed in your boat? Cool!
Kmot is online now Find More Posts by Kmot
Old Oct 16, 2012, 01:16 AM
igotit is offline
Joined Jun 2008
the trim works well from a cheap servo,home made screw drive.pretty simple to make.it could use a hitec 645 for more power,but its enough to lift the entire boat fully loaded.its slow and precise adjustments while riding.i never seen anything like it...so i had to build it.my setup is hidden,and allows the motor to kick up.i seen 1 other trim setup that hooked up to a rod on the top of the motor,it worked but wasnt precise,and lacked power.
my set up works well.
Old Oct 16, 2012, 01:18 AM
Kmot is online now
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Yeah, I could tell from the video. Do a build thread on it!
Old Oct 16, 2012, 01:28 AM
igotit is offline
Joined Jun 2008
its all here in racing boat forum.
http://www.rcgroups.com/forums/showthread.php?t=1418793
im going to redo it this winter....not that i dont like it,just know i can build a more user friendly production model thats more appealing.i was thinking $50 per unit....you supply the servo....just an idea sofar.can be used with any small ep outboard...maybe a 3.5 cc nitro....need bigger servo though.
this cheap servo (axial servo) can trim at full throttle,barely slows the servo down.
Old Oct 16, 2012, 11:55 AM
Kmot is online now
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
I gave up FE years ago so I don't visit that forum.
Nice work, thanks for the link.
Old Nov 23, 2012, 10:41 AM
igotit is offline
Joined Jun 2008
I have 20 new gear sets on the way.pm me if you need a set.thanx
Old Dec 06, 2012, 08:59 PM
igotit is offline
Joined Jun 2008
17 set left ,they arrived today.
$36 a set
Discussion A small challenge: Can you in 1 hour or less.. stonerscolony Flying Wings 7 Jul 11, 2012 12:19 PM
Help! Small Quanity Enameled Wire Vendor 43851E Electric Motor Design and Construction 6 Jul 04, 2012 11:10 AM
Discussion Small cam with video out, available in the UK Gazzz Aerial Photography 15 Sep 25, 2006 06:58 PM
For Sale 48 Pitch Pinion&Spur Gears for EP 1/10th. R_JOB Cars - Cars and Parts (FS/W) 0 Feb 14, 2006 03:57 PM
Gear Pulller for GWS and other small drives is available Bleriot Parkflyers 13 Apr 12, 2002 02:33 AM
