Old Oct 13, 2012, 02:51 PM
igotit is offline
Find More Posts by igotit
United States, LA, Houma
Joined Jun 2008
i recieved the gears today....im impressed with the quality and craftsmanship.ill try to get them in and tested on a stock ep1.my original gear have 3 runs on them and half worn already.so ill try to do 3 runs,then inspect,then 10 runs...ect.then a 12-24 hour steady running in water test.
ill let you guys know.
igotit is offline Find More Posts by igotit
Old Oct 13, 2012, 03:32 PM
igotit is offline
Joined Jun 2008
ive installed the gears,had to trim the grub screw on the vertical gear,mesh feels great,gears went right on with no slop.this machinist is good....cant beat it for $30.gonna go charge my batts and give em a try....after i lube the lower unit.
i adjusted the mesh a lil on the tight side to allow the gears to wear into each other,alittle tight spot...but not too tight to deter me from running them.
stock brass gears on the left,phosphor bronze on the right.
Old Oct 13, 2012, 07:05 PM
catchthis is offline
Find More Posts by catchthis
catchthis's Avatar
USA, NY, Laurel
Joined Aug 2010
I posted on the other thread, but I'm in for 2-3 sets
catchthis is offline Find More Posts by catchthis
Old Oct 13, 2012, 07:09 PM
igotit is offline
Joined Jun 2008
i read it...thanx.
just ran for 20 mins,gonna pull it down and have a look,i think one of my screws backed out.
Old Oct 13, 2012, 09:15 PM
igotit is offline
Joined Jun 2008
ok i was right,after the first run i had lots of slop,even heard a clicking sound during the run.
it turned out that the motor coupling grub screw came loose and allowed the vertical shaft to rise....causing the gear mesh to open up.i had to file the tips of the teeth....this metal is pretty hard to file.so i pulled everything down and shimmed the lower shaft and gear,and the upper shaft.stock the lower unit has plenty slop,so the lack of close tolorences helps eat the factory gears.so please shim your lower unit.even the best gears will fail if you fail to line em up correctly.ill be doing another test run shortly.
Old Oct 13, 2012, 09:28 PM
Kmot is offline
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
We all appreciate your time and effort to get these gears so that those of us with EP-1's can keep them running. Thank you!
Kmot is offline Find More Posts by Kmot
Old Oct 13, 2012, 10:27 PM
igotit is offline
Joined Jun 2008
no problem guys...im tired of the most scale outboards being shelf queens...lol.
i just ran 2 full packs through her,i must say im very impressed.no more wear than the last time i pulled them.im running a 27 turn axial stocker,stock prop with the boat tied off in one spot on 2 s lipo,i cavitated numerous times on purpose.after the second run the gears finally broke in,its now quiet and smooth with minimal backlash.
now the bad news ...my only lipo charger wont power back up.
my power trim servo is acting up,but did trim it while load.
Old Oct 14, 2012, 12:14 AM
Kmot is offline
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
That's quite a jacuzzi you have there!
Old Oct 14, 2012, 01:18 PM
igotit is offline
Joined Jun 2008
Its alright for testing....lol.
These gears are holding up great sofar.
Old Oct 14, 2012, 09:43 PM
igotit is offline
Joined Jun 2008
heres some more torture test.....holding up great.
alittle insight about the guy that made the gears...he installed a set in his ep1,brushless with 37 mm 3 blade prop pushing a 3 foot boat.he has over 30 runs still no excessive wear.ill try to get him to join here and post up his results.
just pulled down after 5 runs.
Old Oct 15, 2012, 01:44 AM
igotit is offline
Joined Jun 2008
spoke with the guy tonight,he wont join up her,not intrested in mass producing the gears,he comfortable with 4-6 sets per mths production,doesnt want to deal with the hassel of emails and questions...so i will be the middle man.
ive just ordered 5 more sets,ill keep 1 set for myself...sell 4 sets here.right now price is $33 shipped per set.
price may rise to $35-40 in a mth or so once more testing is done.
Old Oct 15, 2012, 05:56 AM
Gravman is online now
Find More Posts by Gravman
United States, TX, La Porte
Joined Apr 2007
Ok how do I pay for a set? PayPal?
Gravman is online now Find More Posts by Gravman
Old Oct 15, 2012, 10:35 AM
Kmot is offline
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
I'm in for a set of those gears.
Old Oct 15, 2012, 11:06 AM
igotit is offline
Joined Jun 2008
yes paypal will be the paypemt method.once i recieve the gears ill make a list of the intrested buyers,then start shipping them out.
Old Oct 15, 2012, 11:28 AM
igotit is offline
Joined Jun 2008
i guess i need to setup a forsale ad on this,start taking payments for back orders,create a list of paid and recieved...ect.
Discussion A small challenge: Can you in 1 hour or less.. stonerscolony Flying Wings 7 Jul 11, 2012 12:19 PM
Help! Small Quanity Enameled Wire Vendor 43851E Electric Motor Design and Construction 6 Jul 04, 2012 11:10 AM
Discussion Small cam with video out, available in the UK Gazzz Aerial Photography 15 Sep 25, 2006 06:58 PM
For Sale 48 Pitch Pinion&Spur Gears for EP 1/10th. R_JOB Cars - Cars and Parts (FS/W) 0 Feb 14, 2006 03:57 PM
Gear Pulller for GWS and other small drives is available Bleriot Parkflyers 13 Apr 12, 2002 02:33 AM
