Old Oct 18, 2012, 04:58 PM
indoor_fr is offline
Find More Posts by indoor_fr
indoor_fr's Avatar
Paris (France)
Joined Jan 2006
Nacelles
Ok, the nacelles have been made with the EDF inside. I've cut them because they were too narrow at the end, and that would have affected the thrust, i think.
The carbon rods were cut because i thought that the AR6400 would be located on the EPP support. In fact, i'll have to put it far frontward, in order to balance the plane.I will make a support for the Brick (that will cross the whole fuselage).
indoor_fr is offline Find More Posts by indoor_fr
Old Oct 26, 2012, 04:52 PM
indoor_fr's Avatar
Paris (France)
Joined Jan 2006
A little more progress. I have glued inside the fuselage 2 pieces of 2mm depron, and cut the fuselage at the size of the ribs.
The ribs(1) that you see will be attached to the fuselage with magnets.
I must make 2 others ribs (2) that i will glue to the wings.
I will then join the ribs(1) and (2) with the good angle for the dihedral.
Once the ribs (1) and (2) constitute a single rib, i have removable wings....
Old Oct 31, 2012, 01:20 PM
indoor_fr's Avatar
Paris (France)
Joined Jan 2006
Ok, i've used some 2mm depron to make this piece that supports the AR6400 brick.
I'll use small magnets for holding it his front part.
I'm working on the wings.
More news soon.
Old Nov 01, 2012, 09:22 AM
indoor_fr's Avatar
Paris (France)
Joined Jan 2006
wings
I've made one wing and i'm finishing the other. Do i have to insert carbon rods through the ribs to prevent twisting?
Old Nov 01, 2012, 01:19 PM
AJWoods is online now
Find More Posts by AJWoods
Aircraft Designer Guy
AJWoods's Avatar
United States, CA, Santa Clara
Joined Jul 2005
Really amazing!
AJWoods is online now Find More Posts by AJWoods
Old Nov 01, 2012, 05:16 PM
Chrizz is offline
Find More Posts by Chrizz
OY-5542
Chrizz's Avatar
Denmark, Central Denmark Region, Silkeborg
Joined Nov 2009
Hi indoor_fr!!
What a wonderful build you are making! Can't wait to see the finished result, hopefully also in a in-flight-video!?
Happy landings
Chris :-)
Chrizz is offline Find More Posts by Chrizz
Old Nov 01, 2012, 05:34 PM
indoor_fr's Avatar
Paris (France)
Joined Jan 2006
Thanks a lot Mit Kid and Chris for your kind words.. It encourages me to speed up this construction!
My main fear is the final AUW....With such low- efficiency edf units, it is a challenge.
Stay tuned.
Old Nov 02, 2012, 05:09 PM
indoor_fr's Avatar
Paris (France)
Joined Jan 2006
I have damaged my left wing with an accelerator for glue that has dissolved the foam.Grrr!!!!
I have to make it again!
This is an opportunity to show the process with Water slide decals.
Old Nov 02, 2012, 07:06 PM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
Nice. Where do you get the decal paper from?
boredom.is.me is offline Find More Posts by boredom.is.me
Old Nov 03, 2012, 07:49 AM
indoor_fr's Avatar
Paris (France)
Joined Jan 2006
Thanks. I buy them to Crafty computer in UK:
http://www.craftycomputerpaper.co.uk...-Paper_151.htm
Old Nov 03, 2012, 07:52 AM
indoor_fr's Avatar
Paris (France)
Joined Jan 2006
Originally Posted by Chrizz View Post
Hi indoor_fr!!
Chris :-)
Yes, for sure...if it flies!!!
Bye.
Old Nov 17, 2012, 12:01 PM
indoor_fr's Avatar
Paris (France)
Joined Jan 2006
Sorry, but i was too busy to work on this project. So, not much progress.
As always, the more the build gets to its conclusion, the more it takes time... like the charge of a capacitor...
Ok, i've worked on the nose. It will hold the support of the AR6400. I'll use 2 magnets to hold it to the fuselage.
I'm still working on the way to attach the wings to the fuselage. Not really happy so far with my trials.
So, the next steps are:
Install the wings
Make the landing gears
Find the battery location to balance the plane
Make a hatch for the batteries.
Old Nov 17, 2012, 08:46 PM
nemoskull is offline
Find More Posts by nemoskull
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
whats the current weight of the fuse?
nemoskull is offline Find More Posts by nemoskull
Old Nov 18, 2012, 07:32 AM
indoor_fr's Avatar
Paris (France)
Joined Jan 2006
Fuse+ nose: 6g
Fuse +nose + tail with the EDF 30+AR6400+ESC+linkages: 30.2g
Old Dec 25, 2012, 08:47 AM
indoor_fr's Avatar
Paris (France)
Joined Jan 2006
Calculating the optimal balance point
Ok, i have made the wing attachement system. It woks ok, but the dihedral is a little bit too much. We'll see later.
It adds 1,5g but it makes the plane easier to transport.
I've calculated with a program, that the COG is 8 cm after the leading edge of the wing.
In fact, the optimal balance point is backward because of the stabilisator's area and the great lever.
René Jossien proposed a formula that takes in account these parameters + the kind of airfoil, etc...
Read this instructive article:
http://jmquetin.free.fr/1indoor/tips8e.htm
With Rene Jossien's formula, i find a balance point at around 9,1 cm behind the Leading edge.
This result sems to be confirmed by the glide tests.
This would mean that i don't really need to put the AR6400 so much frontward to balance the plane.
I can probably shorten the piece of depron which supports the brick, and still balance the plane with two190 mA.h batteries (10g) installed a little frontward.
More to come...
Sold A-10 Twin 35mm EDF Micro Jet EPO (BNF) glazzies Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Aug 13, 2012 09:17 PM
Sold SOLD - NIB A-10 Twin 35mm EDF Micro Jet EPO (PNF) ross_badger Aircraft - Electric - Airplanes (FS/W) 1 Jul 27, 2012 05:09 PM
Sold MIG-29 twin 35mm EDF Micro Jet BNF ScottTomasello Aircraft - Electric - Jets (FS/W) 1 Mar 26, 2012 08:54 PM
twin edf 50 jet liner project vincent from ne Foamies (Kits) 21 May 14, 2004 01:53 AM
Twin EDF project starter, MF480x2, Brushless ESC x 2, Jet plans realdeal Aircraft - Electric - Airplanes (FS/W) 6 Nov 18, 2002 04:36 PM
