Old Oct 04, 2012, 06:19 AM
indoor_fr is offline
Find More Posts by indoor_fr
indoor_fr's Avatar
Paris (France)
Joined Jan 2006
Build Log
twin edf- micro DC9 project
I started this project late 2009. The idea was to build the fiddlersgreen model (see pictures i found on Internet) with an EDF set up.
Wing span is 54 cm.
I began the building with 2mm wall foam covered with the fantastic water slide decals from Crafty computer. This is my favourite way of making planes.
I made the fuse, the nose and the tail and used some durobatics and polystyrene for the wings and the elevator + rudder.
I was not satisfied by the result: it looked great, but the foam was too flexible.
So i stopped the project for a while and destroyed my building...
Late 2011, i decided to make a new try with 4mm wall foam. The same i've used for my Gee Bee Z.
The big challenge is the weight. I want to fly the plane indoor, and i'm using 2 Airhogs edf30.
Of course, the size of the fan will not be scale, but i think that i can't use smaller units unless i use bigger motors etc...
The thrust is 11g per unit, which makes 22g for both. The AUW limit of the plane should be 1.5 x 22 = 33g as i consider that the thrust should be at least equal to 2/3 of the AUW.
It is not possible to make such a light airplane especially with 2 EDF units.
In 2010, i read on the micro edf forum that the 7mm walkera motors were stronger. I tried them at 5V with the Airhogs unit, and i found that the thrust was around 15.5 - 16g with a 1.2 A current. The motor seems to stand this power.
i made a micro edf jet using a dc/dc converter (to get 5V) and the edf equipped with the walkera motor, and the plane, weighing 27g, flew well.
http://www.rcgroups.com/forums/showthread.php?t=1346020
So the first solution is to use 2 dc converters (1.2g-90% efficiency).
If the output current is equal to 2 x 1.25 =2.5A, the input current is equal to 2.5 x (5/3.5 x 0.9) = 3.75A. That means that i would need a 300 mA.h battery: 10g.
10+ 2x1.2 =12,4g
The other solution is to use a 2S battery with a 2S ESC and limlit the throttle on the radio in order to keep the current just at 2.5A max.
I need smaller batteries (180 mA.h-5g) and the esc weighs 1.5g only:
1.5 + 2 x 5 = 11.5g
I choose this option.
My target AUW is less than 50g.
I will show you what i have done so far, but i will need your advices as i am still wondering about the wings and other things.
Please, do not hesitate to share your knowledge and your experience.
Thanks in advance.
Frank.
indoor_fr is offline Find More Posts by indoor_fr
Old Oct 04, 2012, 10:21 AM
speedy01 is online now
Find More Posts by speedy01
Gulf Breeze, FL
Joined Jul 2006
Looking forward to how you progress. Are the pictures of the Fiddler's Green paper model?
What is "Crafty computer"?
Gene K
speedy01 is online now Find More Posts by speedy01
Old Oct 04, 2012, 11:29 AM
indoor_fr's Avatar
Paris (France)
Joined Jan 2006
Hi Gene.
Yes, these are the pictures of the Fiddler's green model.
Crafty computer is an English company:
http://www.craftycomputerpaper.co.uk/default.aspx
Frank.
Old Oct 04, 2012, 11:55 AM
Gulf Breeze, FL
Joined Jul 2006
Crafty computer is an English company....
Thanks, Frank.
Since you're printing onto decal paper, have you also considered printing onto tissue and applying that to the foam?
Gene K
Old Oct 04, 2012, 01:22 PM
nemoskull is offline
Find More Posts by nemoskull
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
id second that. tissue and foam make a strong composite. and you might be able to get away with less foam. (cutouts)
tho id play it safe and add 25% to you weight estimates. either way youll be happier. (IMHO)
wiill be looking at this. no one has done a brushed EDF in awhile.
WERE DID YOU FIND THOSE AND WERE CAN I BUY SOME?
ive got a 3d printed order on order that im working on the duplicate the 7mm airhogs brushed EDF, but i am working on this mostly cuz i can find any to buy!
nemoskull is offline Find More Posts by nemoskull
Old Oct 04, 2012, 01:46 PM
Gulf Breeze, FL
Joined Jul 2006
To go briefly off topic, could you provide a link to that printer?
Gene K
Old Oct 04, 2012, 01:54 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Kevin (BiM) is working on small EDF's in the micro EDF forum.
I'm ordering some 20mm's for Albatros 7mm motors to try out. I'm thinking of a 20" A380. I figure each will make an easy 10g of thrust on 1S... more if I throttle 2S.
For larger EDF's the 30mm GWS rotor fits onto the 8.4mm motors. You can buy housings from BiM
UNGN is offline Find More Posts by UNGN
Old Oct 04, 2012, 02:13 PM
indoor_fr's Avatar
Paris (France)
Joined Jan 2006
I would be surprised if you'd get 10g of thrust on 1S with a 20mm EDF and with the albatros motor. I tested the albatros motor last year and it didn't give a good thrust with an EDF30.
I also doubt that you'll be able to run it on 2S without frying it (it is hotter than the walkera motor). Anyway, it worth a try.
I'm waiting for your test results.
Old Oct 04, 2012, 02:17 PM
indoor_fr's Avatar
Paris (France)
Joined Jan 2006
Thanks for the input. I have noticed that a lot of people make very nice planes with printed tissue. I've tried once in the past, but i didn't like the result (for my plane).
I will make an other try with printed tissue for a future project, but the DC9 is already begun, so i can't go backward.
The decals i buy are not the very fragile decals used for decorating static models. In fact, It's a kind of an "elastic skin" that gives a very glossy aspect and make the foam very strong as well. The additionnal weight is not very high.
About the edf30 fan for 7mm motors, these are fans from Airhogs JetScream. You'll have to buy one and dismantle it:
I don't know if they are still available...
Here is one on EBAY:
http://www.ebay.com/itm/Airhogs-Jets...item1c2bd738ab
What is the price of your 3d maker?
Old Oct 04, 2012, 10:29 PM
minimicrorc is offline
Find More Posts by minimicrorc
Joined Apr 2012
Isn't it shapeways?
minimicrorc is offline Find More Posts by minimicrorc
Old Oct 04, 2012, 11:01 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
I was able to get just under 10g with a jury rigged 7mm setup using a cut down GWS fan, a first gen 22mm housing without a bellmouth, using a "just OK" Nanotech 160.
I'm ordering fwd and reverse rotation fans and 22mm and 20mm housings from Kevon.
In a few weeks, when I get the parts, I'll post the thrust results.
For 2S, i have 7A brushed Pixie ESC's and I can throttle the ESC with the travel extents in the TX and a Voltmeter. Just want to see what kind of thrust happens @ 5.0 or 5.5 volts.
Old Oct 04, 2012, 11:12 PM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
Putting them together right now actually.
boredom.is.me is offline Find More Posts by boredom.is.me
Old Oct 04, 2012, 11:55 PM
Joined Apr 2012
with the albatross motor?
Old Oct 05, 2012, 12:14 AM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Flyzone Albatros 7mm. $2.99 @ Tower hobbies.
Will easily fly a 40g plane @ about 1amp current draw through a gearbox... probably about 25-30g of thrust depending on the battery/prop.
EDF's of course aren't as efficient, but infinitely cooler.
Old Oct 05, 2012, 08:33 AM
indoor_fr's Avatar
Paris (France)
Joined Jan 2006
The wing
Ok, let's talk about the wing.
The wing is made of a sheet of polystyrene. It is flat. I have glued it to the fuselage but i think it is possible to remove it (with care...).
I'm aware that a flat wing will bring drag.
I'm wondering if i shouldn't make a pair of under camber wings that could be attached to the sides of the fuselage with magnets:
Not only this will add lift, but i will be able to store the plane in a much smaller box!
Should i stay with the flat wing or should i change?
If i had to make new wings, how could i do? Both wings should weigh 5g max...
I have some 2mm depron and 2mm wall foam...
I could make ribs and cover with 2mm wall foam (coverd with decals of course).
Or maybe, i could use 2mm depron and give an under camber shape with hot water?
What do you think? If you have already made something like that, please tell me.
Thanks!
Sold A-10 Twin 35mm EDF Micro Jet EPO (BNF) glazzies Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Aug 13, 2012 10:17 PM
Sold SOLD - NIB A-10 Twin 35mm EDF Micro Jet EPO (PNF) ross_badger Aircraft - Electric - Airplanes (FS/W) 1 Jul 27, 2012 06:09 PM
Sold MIG-29 twin 35mm EDF Micro Jet BNF ScottTomasello Aircraft - Electric - Jets (FS/W) 1 Mar 26, 2012 09:54 PM
twin edf 50 jet liner project vincent from ne Foamies (Kits) 21 May 14, 2004 02:53 AM
Twin EDF project starter, MF480x2, Brushless ESC x 2, Jet plans realdeal Aircraft - Electric - Airplanes (FS/W) 6 Nov 18, 2002 05:36 PM
