That's the only name I have for it - here's a link to the page. I picked this one because it has some dihedral, 1.5 degrees, and figured it would be easy to fly. And yeah, you did sound sarcastic, lol, you're kind of right though, lol.
I just googled it and there isn't a whole lot out there, but here is the closest thing I found to a build thread: http://www.rcgroups.com/forums/showthread.php?t=1507043 I haven't even read it yet, but it hopefully has the info I need. Thanks for you help everyone! |
I know very little about electrics, but what I've surmised thus far is that approx 150-250W should be great for this Passer-ish bird. Lots of guys use bigger motors because they like 15 second vertical climbs to altitude then shut down. (I'm the type to use what I have and if I could rig something up to not spend more money, even at the expense of performance, i'll do it anyways...i'm a cheap sob!)
A quick search of your Scorpion numbers didn't reveal an exact match, but a 2221 is 525W which would be super-overkill IMO. I assume you've seen at least one Passer X thread such as http://www.rcgroups.com/forums/showt...light=passer+x in which you can get many different opinions. |
Joe ... I truly do not want to sound sarcastic, but you seem to be a bit lost about all of this. Sort of like buying a horse and not knowing how to put the saddle on it.
![]() Here is the link to the R2 manuals site.... http://www.r2hobbies.com/manuals/ I believe this is the plane you bought, the Raptor TX 2000? http://www.r2hobbies.com/4ch-rc-ep-2...ilplane-2.html I am afraid though that the specified SKU for the plane is not found in the R2 manuals site. Thus, you will need to contact the vendor and ask them for a manual or ask them if any of the current manuals can be used to build your plane. You can also look at the available manuals and find a plane that is close to yours. Here is the page with their motors. http://www.r2hobbies.com/catalogsear...=D2836&x=7&y=7 Now, if you did get the Raptor, you will see on the R2 site, they specify the motor as a 1000kv motor with a 40 amp ESC. Judging from the nose of the plane and from the motors listed, you will need a 28mm diameter, 1000kv motor. The motors show with that stock number seem to pull around 23 amps continuous. If that is the case, then your 30 amp ESC is sufficent. Looks like you will need 6 servos as well. Not sure of the rating for those but with 6 servos, a motor, receiver it is a very good bet the BEC on your ESC will go toes up and you will loose the plane. That means you should strongly consider a separate BEC to power the receiver and servos. Hope this helps. |
http://www.djaerotech.com/dj_askjd/askdesign.html and scroll down to 'The Famous V-Tail Debate' and this: http://www.southernsoaringclub.org.z...-Trimming.html V-tails do take a little more understanding of them to set them up properly. They do not behave the save as the standard x-tail or cruciform tail. It don't hurt that they are purtier than an X-tail either.
| Thread Tools | |
| Question R2 Hobbies e-gliders? | joe_crash | Electric Sailplanes | 5 | Feb 05, 2013 12:13 PM |
| Question Identify this glider + any info about it | aaron_jeffrey | Sailplane Talk | 4 | Aug 17, 2012 02:51 PM |
| Help! any opinions | Shannon87 | Racing Boats - Electric | 25 | Mar 23, 2012 09:30 PM |
| Discussion I've bought this glider - Will this glider be any good? | Johnn | Beginner Training Area (Aircraft-Electric) | 1 | Dec 25, 2008 06:53 PM |
