Old Jan 22, 2013, 06:53 AM
GER44 is offline
Find More Posts by GER44
Vietgest, Germany
Joined Jul 2009
Originally Posted by Chris Jenkins View Post
Next ...........I'll be using futaba 2.4ghz radio....question to the old salts....what servo for the rudder is recommended.?...........
I use the HiTec HS-81. HS-81 (wheight is very importan in my meter boat class). It is in my boat from 2007. Only 2009 water was going inside the servo. I opend the servo, maked warm and dry and he is working up today. I use one 2 accu 5*ENELOOP AA 800 mAh (than I must change accu in mitday), or one accu 5*ENELOOP AA 2000mAh for one day racing.
But I think also, that you will find very many servos for rudder.
Ullis
GER44 is offline Find More Posts by GER44
Old Jan 22, 2013, 07:30 AM
8387mike is offline
Find More Posts by 8387mike
8387mike's Avatar
Perth Western Australia
Joined Jul 2009
Yeah Chris what's going on with the build?
8387mike is offline Find More Posts by 8387mike
Old Apr 13, 2013, 11:09 AM
Chris Johnson is offline
Find More Posts by Chris Johnson
Joined Apr 2013
Chris,
Sorry to be late to this build. i'm about to build a balsa Goth.
What glue did you use to bond the balsa strips to each other initially?
Chris
Chris Johnson is offline Find More Posts by Chris Johnson
Old Apr 14, 2013, 02:40 PM
FWAL is offline
Find More Posts by FWAL
Flying without a licence
FWAL's Avatar
United Kingdom, Wales, The Mumbles
Joined Dec 2010
Hi Chris J
I've built a couple of Balsa, Glass IOM's and use an Aliphatic glue as it's easier, better to sand than normal PVA. I keep a blog of my modelling boat building antics which may be of some help. My top tip whilst building is to try not to rush, it's not a race to finish. Enjoy the experience and learn from your mistakes. It's extremely rewarding.
http://soaring-sailing.blogspot.co.uk/
FWAL is offline Find More Posts by FWAL
Old Apr 18, 2013, 06:07 AM
Joined Apr 2013
Chris,
Thank you for that. I've seen Titebond as an aliphatic locally.
Chris
Old Apr 18, 2013, 04:42 PM
8387mike is offline
8387mike's Avatar
Joined Jul 2009
Originally Posted by FWAL View Post
Hi Chris J
Ha this coming from a guy who one minute has a design on the drawing board and then has it doing water testing in the next post
I have used an external PVA it sands a lot easier than the normal, but hey my attempts are still in the shed collecting dust.
Good luck Chris
Old Oct 04, 2013, 01:34 PM
Joined Apr 2013
Thanks for the glueing advice.
I used 2.5mm balsa, covered with a single layer of 100gm twill and West resin. 2 coats so far.
She's still on the shadows as I find it easier to sand and I want the glass to set completely to reduce twisting.
Chris
Old Oct 31, 2013, 05:21 PM
FWAL is offline
FWAL's Avatar
Joined Dec 2010
SWEET
Discussion f-15 build Foam scratch build, wanna go faster Foamies (Scratchbuilt) 60 Sep 03, 2012 11:57 PM
Discussion IOM Build Question dwatson Sailboats 3 Jun 10, 2012 08:43 PM
Discussion My IOM scratch build... Vanquish hew565 Sailboats 285 Feb 14, 2011 11:07 AM
Question IOM - Who is currently scratch building Mesnik Sailboats 25 Jun 02, 2010 06:22 PM
