Old Oct 23, 2012, 07:25 PM
MMangus is offline
Find More Posts by MMangus
Sport R/C Flyer/Sailer/Driver
United States, MS, Columbus
Joined Nov 2001
Ouch. I feel the pain for removing the bad resin. Had something like that happen to a 1:144th scale wood built warship I glassed a while back. The glass started separating from the hull due to aged resin. It would not have been so bad except I knew that the resin was suspect even before using it.
Even worse? I used that resin on three different ships and had to redo them all. Bleah!
Stick with it! Your boat is gorgeous.
MMangus is offline Find More Posts by MMangus
Old Oct 24, 2012, 12:14 AM
Chris Jenkins is offline
Find More Posts by Chris Jenkins
Chris Jenkins's Avatar
United Kingdom, Wales
Joined Feb 2005
Thanks Magnus....still scraping away !...but at least I've cut out the frames.
Back to it.
Cheers
Chris Jenkins is offline Find More Posts by Chris Jenkins
Old Oct 24, 2012, 07:40 AM
MMangus is offline
Joined Nov 2001
Not sure if it would help, but I used a heatgun to help soften the bad resin even more to pull the cloth off the wood hulls.
Korea huh? There was a half decent hobby shop up in the Seoul Electronics Market. I did best by ordering from Korean online web sites and having the goods delivered directly to my door.
Old Oct 24, 2012, 07:39 PM
Joined Feb 2005
Pretty much the same for me. Not much modelling activity here. I am on an 8 on 2 off rotation back to my native S Wales, so try to stock up when I am at home !
Ref heating the epoxy...no need really in this case as I dont need to remove the glass cloth, as the problem is only related to the glue used for the internal formers and deck beams, where the goo can be removed by with a finger nail and a sharp edge. They have all been removed, and the hull internal is now clean. New formers have now been cut and so the process of installing these starts again today.
So nothing lost, apart from time and the frustration factor !
Old Oct 26, 2012, 07:01 PM
Joined Feb 2005
Test fitting the fin housing and new internal framing...a slightly different arrangement this time. Hole cut for housing using my trusty Dremel...a must have tool for this sort of job
Old Oct 27, 2012, 07:02 PM
Joined Feb 2005
No expense was spared in constructing an alignment jig to fit the fin housing
Old Oct 27, 2012, 10:38 PM
Joined Feb 2005
Not forgetting the rudder & supporting bulkhead.
Can some of the old hands advise what maximum rudder angles are needed ?
I'm pondering foredeck options....1/16 ply seems overkill...any thoughts ?
Old Oct 27, 2012, 10:48 PM
hiljoball is online now
Find More Posts by hiljoball
hiljoball's Avatar
Canada, BC, Strathcona
Joined Jul 2011
45 degrees either side is plenty.
You can get 1/64th and 1/32 marine birch plywood at Michaels. Lighter is better.
John
hiljoball is online now Find More Posts by hiljoball
Old Oct 28, 2012, 12:23 AM
Joined Feb 2005
John
Thanks John...
Old Oct 28, 2012, 07:41 AM
8387mike is offline
Find More Posts by 8387mike
8387mike's Avatar
Perth Western Australia
Joined Jul 2009
John
You don't have to cover the whole deck you can leave plenty of access holes and cover with patch's, this will keep weight don and the fore deck construction looks very strong anyway.
8387mike is offline Find More Posts by 8387mike
Old Oct 29, 2012, 01:51 AM
Joined Feb 2005
Thanks Mike.
Here is the state of play so far. Construction this week will be on the mast box and installing the shroud fittings. After that things will slow down a bit waiting for the winch and and other bits and pieces from UK.
Old Nov 01, 2012, 11:29 PM
Joined Feb 2005
Mast housing and deck bowl support now fitted.
Old Nov 02, 2012, 04:22 AM
Joined Feb 2005
Next couple of weeks will be slow, until I can pick up the winch & radio from Wales. Anyway, quite pleased so far, and am wondering if I should leave the hull untainted and just paint the deck...any thoughts ?
I'll be using futaba 2.4ghz radio....question to the old salts....what servo for the rudder is recommended.?....standard sized 3003 for example ?
Have a great weekend all
Chris
Old Nov 02, 2012, 09:28 AM
hiljoball's Avatar
Joined Jul 2011
A mini digital servo has the power and less weight than a standard.
http://www.servocity.com/html/hs-524...ital_mini.html
or if you are going to use lipos, then a high voltage servo
http://www.servocity.com/html/hs-7245mh_servo.html
John
Old Nov 03, 2012, 01:13 AM
Joined Feb 2005
John
Thanks John...appreciate the input. Been building aircraff for 50 years or so, and this is new ground for me.
Here she is...(thinks : I really must get a proper model stand sorted out !)..rudder isn't flared to hull properly yet, will do that when final finishing done.
Discussion f-15 build Foam scratch build, wanna go faster Foamies (Scratchbuilt) 60 Sep 03, 2012 11:57 PM
Discussion IOM Build Question dwatson Sailboats 3 Jun 10, 2012 08:43 PM
Discussion My IOM scratch build... Vanquish hew565 Sailboats 285 Feb 14, 2011 11:07 AM
Question IOM - Who is currently scratch building Mesnik Sailboats 25 Jun 02, 2010 06:22 PM
