Old Oct 13, 2012, 04:26 AM
Chris Jenkins is offline
Find More Posts by Chris Jenkins
Chris Jenkins's Avatar
United Kingdom, Wales
Joined Feb 2005
Another
Chris Jenkins is offline Find More Posts by Chris Jenkins
Old Oct 13, 2012, 04:28 AM
Joined Feb 2005
Last one
Old Oct 13, 2012, 11:15 AM
hew565 is offline
Find More Posts by hew565
USA, LA, Mandeville
Joined Feb 2005
I like West System #410 microlight filler. Light and sands very nice.
hew565 is offline Find More Posts by hew565
Old Oct 15, 2012, 08:44 PM
Joined Feb 2005
Progress so far
Well, removed the hull from the shadows last night, and they came out quite easily (I did wonder if they would !).
Did a quick clean up internally followed by a sanding, and then got a sealer coat on the internal surfaces as soon as I could. The hull had not sprung apart, so the temporary balsa cross bracing and the external epoxy coating had kept the shape.
Weight so far is 180g.
Internal glassing follows tonight.
Old Oct 15, 2012, 11:30 PM
Joined Feb 2005
More pictures.
Old Oct 16, 2012, 02:01 AM
8387mike is offline
Find More Posts by 8387mike
8387mike's Avatar
Perth Western Australia
Joined Jul 2009
Nice finish, she is looking good
8387mike is offline Find More Posts by 8387mike
Old Oct 16, 2012, 06:30 AM
The Tug is offline
Find More Posts by The Tug
Barbados
Joined Jan 2011
I agree,West System is a system so they have the complete package of the application of what you might be doing.They are many epoxy manufactures but they dont seem the carry the additives as West does.
The Tug is offline Find More Posts by The Tug
Old Oct 16, 2012, 06:52 PM
Tim B. is offline
Find More Posts by Tim B.
Tim B.'s Avatar
United States, CA, Oakland
Joined Aug 2009
Great planking !
Tim B. is offline Find More Posts by Tim B.
Old Oct 16, 2012, 08:00 PM
Joined Feb 2005
Thanks guys....this has been the easy bit for me, as I do have traditional "balsa bashing" experience from many years of aircraft modelling..fitting out will be getting into more uncharted areas
Ref West...yep, sure you are right. I just couldn't source it out here, and I couldn't find any supplier who would airfreight.
In the end I used micro balloons...which are fine, but leave the surface a little milky in appearance. I'm going to paint the hull anyway, so no great shakes.
The internal glassing is now finished, and I have been really impressed at the strength that it has imparted to the hull.
Any thoughts as to a target weight for the hull (without fittings) ?
Regards
Chris
Old Oct 16, 2012, 10:08 PM
MILLERTIME is offline
Find More Posts by MILLERTIME
Taking care of the pond.
MILLERTIME's Avatar
United States, CA, Sanger
Joined Apr 2004
Very nice.
MILLERTIME is offline Find More Posts by MILLERTIME
Old Oct 18, 2012, 12:25 AM
coolmobility is offline
Find More Posts by coolmobility
coolmobility's Avatar
Australia, VIC, Paynesville
Joined Sep 2009
Really nice job of planking. Looks a very sleek hull and will be stiffer than a pure glass hull.
Your bow treatment is especially nice method and results show it off well. Pity to paint it and put a deck over it. ;-)
What is your weight with glass both sides?
coolmobility is offline Find More Posts by coolmobility
Old Oct 18, 2012, 02:43 PM
hew565 is offline
USA, LA, Mandeville
Joined Feb 2005
My Vektor, fiberglass hull/deck weighed 525 gms bare.
With radio trays and paint primer, I was at 606. Paint added 6gm and clear coat another 9gms.
The finished boat is under weight by about 85 grams, but that is a bit over what the newest builds are coming in at. My Lintel needed 165 gm corrector weights.
I read where Pikanto's were about 600 gms for hull/deck only.
Old Oct 19, 2012, 02:32 AM
Joined Feb 2005
Thanks for the nice words and encouragement guys
Coolmob: I did think about staining and leaving the hull unpainted, maybe next time. The planking method seems to have worked okay...I cut the planks by using a 1 metre steel rule clamped to the 10mm x 3mm planks (with a support) on my building board so that they could taper down to almost nothing.
Hew..thanks for the input. My hull in its present state is 480g. I'll need to be carefull with the outfitting to keep the weight down. In retrospect I could have used lighter glass cloth in the internal covering, but the hull is really rigid, and minimal formers and bracing will be required.
My rudder is very light CF coming in at 45g. Hopefully all will be okay in the end.
Have a nice weekend all.
Chirs
Old Oct 19, 2012, 05:40 AM
8387mike is offline
8387mike's Avatar
Joined Jul 2009
The boats that I sell come in about 630 with a cockpit and under 600 with a flat deck.
Hope this helps
Old Oct 19, 2012, 06:19 AM
Joined Feb 2005
Hope this helps
Thanks Mike. Yes, very helpfull. I'm going to have to be carefull here on in to keep the weight within reasonable margins it seems.
Just had a look at your lovely IOM's...no doubt a better starting point than building from scratch, but I'm learning lots of lessons !
Cheers
Chris
Discussion f-15 build Foam scratch build, wanna go faster Foamies (Scratchbuilt) 60 Sep 03, 2012 11:57 PM
Discussion IOM Build Question dwatson Sailboats 3 Jun 10, 2012 08:43 PM
Discussion My IOM scratch build... Vanquish hew565 Sailboats 285 Feb 14, 2011 11:07 AM
Question IOM - Who is currently scratch building Mesnik Sailboats 25 Jun 02, 2010 06:22 PM
