United States, GA, Centerville
Joined Mar 2012
Ah, I see that I missed Jim's allusion to an external ESC in the answer to the OP. When he was talking about the ESC he wasn't talking about the onboard ESC.
I know that an AR6400 can drive an external ESC. What is the voltage supplied to the rxr by the ESC? I would expect that external ESCs would supply a nominal 5vdc but I don't know. They could simply pass through the battery voltage (lots of rxrs have a broad operating range). |
Sorry Vince,
I forgot the hyperlink, here it is: http://www.hobbypartz.com/88e-gps001-c03-gearbox.html Thanks, Free |
You could make a geared AP-03 to run a 5-6" prop!Free |
Here is another way to wire it that doesn't need a special 3 pronged plug for the motor block (NEVER EVER EVER use 3 individual wires here, or your plane will eventually catch fire) 1S: 2S: |
Latest blog entry: AR6400 guillows Space Shuttle
Massachusettes
Joined May 2010
Trying this out for a BL set up, techone C05 micro motor, 6a esc w/ 5v bec, AR6400 board and aileron servo on a Sbach epp 19". Hoping to get auw of 40gr. With 2 1s 250 in series. Rite now citing the weight of the motor/ esc by tossing out any extra wires. Soldering motor wire directly to esc. And ligther gauge batt wire. Motor/ esc weighted in at 12.6 gr shooting for 8gr. I see that a lot of pilots are using the aux channel on the board as a linear throttle why? Is the throttle range different on the regular channel can it be adjusted via the esc? I'm using a dx5i for all my bnf. Thanks for and feed back
Joined Mar 2010
Throttle
Jyester: In my limited experience, the throttle action (with Dx8 radio) will be the same from the Brushless mode on the motor socket, or the Aux channel or Flaps channel. I tried all 3, no difference, I even connected a servo to verify. Watch out your prop may spin about 1/4 power after you attach the 2S battery, is so, disconnect battery and start again. I'm going to try another ESC, model XP7A and hope for a different result.
| Thread Tools | |
| Sold 2S ar6400 Brushless setup - 30 shipped conus | nemoskull | Aircraft - Electric - Micro & Indoor Airplanes | 8 | Sep 21, 2012 11:07 PM |
| Discussion Best fuel tank system (proof) The search for the best performing tank setups | schusterjo | Fuel Plane Talk | 414 | Aug 29, 2012 12:19 PM |
| Discussion What castle creation setup would be best for stampede 4x4? | Rellik | Off-road Cars | 9 | Apr 27, 2012 07:47 PM |
| what is the best setup of brushless motors for Twinstar 2 ? | lempert | Foamies (Kits) | 0 | Aug 05, 2005 07:43 AM |
| What's the best brushless setup for a 400X? | Bill Germanson | Foamies (Kits) | 6 | Feb 18, 2003 02:44 PM |
