Old Oct 10, 2012, 09:55 PM
JKinTX is offline
Find More Posts by JKinTX
Joined Jul 2012
Originally Posted by aspeed View Post
Sometimes I wear a helmet too, even when the rules don't require it. I got the cowboy hardhat for the sunshade too. I got the cheaper nylon shutoff. I have heard they break much easier than the aluminum one for $40. I still haven't tried it out yet, but have seen them go. Our club isn't all control line friendly. I don't think the motor would quit if the lines go slack. Maybe it is a good thing if it is that slack, it won't hit so hard.
Test it all and make sure it all works the way it is supposed to.
I still have scars down the inside of both my forearms in different places where I reached around the prop to try and "tweak it" just a tad more. Most of these were nylon props on old school 1/2As. Think about a modern high tech prop on a modern motor... Guys with hooks for hands aren't really all that cool.
JKinTX is offline Find More Posts by JKinTX
Old Oct 10, 2012, 09:58 PM
aspeed is offline
Find More Posts by aspeed
Canada, ON, Cottam
Joined Jan 2012
You probably had a reedie, they needed tweaking about three times in the middle of a flight too.
aspeed is offline Find More Posts by aspeed
Old Oct 11, 2012, 08:34 AM
RknRusty is offline
Find More Posts by RknRusty
RknRusty's Avatar
United States, SC, Columbia
Joined May 2010
Aspeed, are you saying reedies don't run well with a bladder? I've read on Cox Forums where someone was setting up a reedie for bladder feed, but no one ever followed up with how it actually worked. It was going to be for a Killer Bee. At least if the engine dies, most of the flow probably just runs out the back and less into the crankcase.
RknRusty is offline Find More Posts by RknRusty
Old Oct 11, 2012, 05:08 PM
aspeed is offline
Canada, ON, Cottam
Joined Jan 2012
It is ok with a bladder. I have seen it done many moons ago with a 1/8" hole in a BBee, and it worked for a few flights then. Just a stock BBee or Golden Bee or silver or pink or whatever always seem to go rich to lean at the end of the tank on suction.
Old Oct 11, 2012, 07:03 PM
aspeed is offline
Canada, ON, Cottam
Joined Jan 2012
Ok, I did a pic. of the "Little Red Caps" beside a regular bladder. I use tie wraps and the $5 tool to tighten them. It has an adjustable tension. The little red caps are about $5 for 20, and are used for caulking guns. I got mine at Lee Valley Tools, I don't know who else may have them. They are like little kitten condoms and have less pressure than a regular bladder.
Old Oct 11, 2012, 07:17 PM
JKinTX is offline
Joined Jul 2012
Yep. Pressure feed usually cuts out with no great variation at end of run, one reason Jim Walker liked using it.
The Fireball plans explain how to make a balloon tank with a toy balloon from the 5 and 10 cent store, and the Walker pressure regulator was the ultimate add on- they still show up on eBay and elsewhere today.
The more things change, the more they stay the same.
They used to run a real neat "Jim Walker" multi-task C/L event up in Canada, don't know if they still do or not.
Old Oct 11, 2012, 07:23 PM
JKinTX is offline
Joined Jul 2012
Cox .049s- others also. The McCoy .35 with the TF nylon prop was no slouch either.
Old Oct 11, 2012, 09:20 PM
RknRusty is offline
RknRusty's Avatar
Joined May 2010
Maybe they have those at Lowes or my little neighborhood HW store. I'll see if I can find some.
Old Oct 11, 2012, 10:12 PM
aspeed is offline
Canada, ON, Cottam
Joined Jan 2012
The Jim Walker event was cancelled last year around here, but came back by popular demand this year. Paul Smith (Detroit) won the last one I saw with a Nelson and a shutoff.
Old Oct 12, 2012, 03:47 PM
Gnu4FF is offline
Find More Posts by Gnu4FF
United States, TX, Spring
Joined Jul 2010
Unlikely at Lowe's, but try Ace or Tru-Value.
Gnu4FF is offline Find More Posts by Gnu4FF
Help! Macs thin-wall pressure fitting - how to install? Generic Member Classic Pattern Flying 13 Aug 15, 2012 12:43 AM
Discussion Vac Bagging - how long to keep pressure on? geoffers0_0 Composites Fabrication 5 Jul 12, 2012 07:44 AM
Help! Dle 55 how can do I use crank pressure for smoke? jamesrini Engines 3 May 17, 2012 04:15 PM
Discussion I finally tried a pressurized bladder tank RknRusty 1/2A Planes 38 Dec 27, 2011 01:09 AM
Discussion Pressure bladder with a wing pylon heliwill10 Composites Fabrication 11 Oct 26, 2011 04:37 PM
