Old Oct 03, 2012, 06:55 PM
trevorcgross is offline
Find More Posts by trevorcgross
United States, NY, Hamburg
Joined Mar 2012
Question
What do you do to your Duraplane Trainer 40 to make sure wing stays aligned?
I just picked one up at an auction, and the wing seems to wiggle a little, even with 8 rubberbands. Can you help?
trevorcgross is offline Find More Posts by trevorcgross
Old Oct 03, 2012, 08:03 PM
Mig Man is offline
Find More Posts by Mig Man
David Drowns
Mig Man's Avatar
Southern California
Joined Nov 2010
One method would be to put a bead of RTV sealer on the wing seat, put wax paper down as a parting media and set the wing back until dry. Remove the wax paper and you have a surface with 'some' grip to it and it should reduce the wiggle.
Mig Man is offline Find More Posts by Mig Man
Old Oct 03, 2012, 08:06 PM
Joined Mar 2012
Okay. How about not using rubber bands? what would you do? notch in front and 2 screws in back?
Old Oct 03, 2012, 08:41 PM
Mig Man is offline
David Drowns
Mig Man's Avatar
Southern California
Joined Nov 2010
To be perfectly honest with you, I'm not familiar with that particular plane. You'll need someone else to help with that question. The plane design would determine your best answer for that one.
BTW. Weather stripping could work similar to the RTV also.
Old Oct 04, 2012, 09:14 AM
draftman1 is offline
Find More Posts by draftman1
draftman1's Avatar
central CA
Joined Aug 2002
8 rubber bands is not enough, a 40 size needs at least 12, i usually use 16 on mine. you will loose a wing in flight with only 8,
draftman1 is offline Find More Posts by draftman1
Old Oct 11, 2012, 08:51 AM
Zenmaniac is online now
Find More Posts by Zenmaniac
Building with TLAR precision
Zenmaniac's Avatar
near Madison, WI
Joined Jan 2009
I don't know that plane either, but I use velcro on all my combat planes (plus 6-8 rubber bands! ) A strip or two along the cord on the wing and the fuze works wonders.
-= Dave
Zenmaniac is online now Find More Posts by Zenmaniac
Discussion What do you guys do with your Old RC Toys? Sherlock221B Chit Chat 11 Oct 08, 2014 12:46 AM
Discussion How do you make your loops shorter? helikido Micro Helis 16 Aug 10, 2012 01:35 AM
Discussion What Do *You* Do With Your Clapped-Out Servos? A Useless Geek DIY Electronics 6 May 03, 2012 02:30 PM
Poll What do you do with your Old Timer? orange&white Vintage & Old-Timer Designs 17 Apr 25, 2012 03:14 PM
