Old Feb 02, 2013, 11:05 AM
ilektron is offline
Find More Posts by ilektron
Will fly for food
ilektron's Avatar
United States, CA, Carlsbad
Joined May 2011
Originally Posted by typicalaimster View Post
I recently ground tested my standard Futaba radio out to 1.5km. I would have went further but I ran out of road. Keep in mind this is a ground test with the radio TX at hip level and the RX inside my car on the dash. I wanted to get an idea of a poor radio setup. I recently bought a FrSky setup. Once it arrives I'll give that a test. Some folks are reporting 2-3km before the RSSI beeper goes crazy.
The other thing you can do is put the radio in range test. Then move away until the system loses link. You then measure that distance and do the math.
The Futaba 617FS RXs (and perhaps other futaba) also just have whip antennas with UMCs on them. It is pretty easy to replace them with higher gain antennas, and get a little more range out of them.
ilektron is offline Find More Posts by ilektron
Old Feb 02, 2013, 11:23 AM
flyandi is offline
Find More Posts by flyandi
United States, CA, Aliso Viejo
Joined Aug 2009
Originally Posted by Kloner View Post
the south end of the property up there has a campground, w want to have a get together and fly from the campground. flyandi was working on it, then it went silent.... (crickets chirping)
Still working on Red Beach FPV Fly-in .. they re-doing the airfield right now and my contact says that early May would be the first possibility to have an event there.. but it's Military :-)
Next FPV Meetup will be at Dave's Beach in March.
I will announce something in the coming days.
flyandi is offline Find More Posts by flyandi
Old Feb 02, 2013, 11:26 AM
typicalaimster is offline
Find More Posts by typicalaimster
typicalaimster's Avatar
United States, CA, San Diego
Joined Jan 2005
Correct. Plus FrSky has the same thing going for them. I already have the U.FL to SMA connector for the Futaba RX. Just never got around to using it. I'll probably tear into my FrSky setup. Might even get the booster. I noticed that FrSky has longer standard antennas you can order for them. They have the same connector Futaba uses. Nice because you can leave the RX in the plane and run the wires out onto the wing.
typicalaimster is offline Find More Posts by typicalaimster
Old Feb 02, 2013, 11:27 AM
flyandi is offline
Joined Aug 2009
I got 2.4 miles with 60mm Antenna FrSky setup .. running the Antennas on the wing is a good idea.
Old Feb 02, 2013, 11:28 AM
Joined Jan 2005
-------- Original Message --------
Subject: Desert RC Camping Trip
Hello Gents,
I am starting to get the feelers out for a trip to Ocotillo, to fly in open space.I sold my dune buggy, so this winter I had no desert trips and am longing for some open space and wide skies.
So far folks are good with March 23 & 24, the weekend before Easter.
I would be happy to organize a pot luck for the first evening, so someone coming out for the day could participate with that also.What say ye? Its close enough for a day trip, and if you are ok camping, night flying, good eats and camaraderie.
Jim
If anyone is interested in going out to the Wells in March.
Old Feb 02, 2013, 11:29 AM
Joined Jan 2005
Have you tried arranging the leads in the Inverted V pattern? I've been thinking about doing that instead of the 'suggested' antenna setup.
Old Feb 02, 2013, 11:43 AM
dartmouth01 is offline
Find More Posts by dartmouth01
Joined Oct 2006
Just wondering what is the suggested setup? I'm wondering if I have my frsky wires set up wrong.....
dartmouth01 is offline Find More Posts by dartmouth01
Old Feb 02, 2013, 11:55 AM
flyandi is offline
Joined Aug 2009
I just put on each wing one antenna pointing straight up
Old Feb 02, 2013, 12:04 PM
ilektron is offline
Will fly for food
ilektron's Avatar
Joined May 2011
You probably want them orthogonal.
Old Feb 02, 2013, 12:26 PM
1320fastback is offline
Find More Posts by 1320fastback
Detroit 2-stroke junkie
1320fastback's Avatar
USA, CA, Oceanside
Joined Jul 2008
I'm in.
Desert flying is a blast.
I usually go with the MiraMar club to Superstition Mountain a couple times a year.
Only one other fpv pilot but we all have big stuff to fly LOS.
Shenanigans include multiple planes flying formation from the back of a moving truck across the desert, ulta micros catching thermals off the camp fire at night, usually a movie protected onto a toy hauler each night.
Might look into Split Mountain Road also. It is very near Octillio but is usually less busy. Also opportunity for Proximity flying along the mountain.
1320fastback is offline Find More Posts by 1320fastback
Old Feb 02, 2013, 12:46 PM
SDSURFnGLIDE is offline
Find More Posts by SDSURFnGLIDE
Multi rotors=No Paycheck left
SDSURFnGLIDE's Avatar
Joined Apr 2011
Anyone down to fly later in the afternoon? Like around 2or 3?
SDSURFnGLIDE is offline Find More Posts by SDSURFnGLIDE
Old Feb 02, 2013, 01:05 PM
Joined Oct 2006
Right now I have mine pointed 90 degrees apart with one going along the arm of quad and another going down a leg. But I'm wondering if I should go 90 degrees horizontally, instead of vertically. Maybe it doesnt make much difference.
Old Feb 02, 2013, 01:29 PM
Disp0sablehero is offline
Find More Posts by Disp0sablehero
United States, CA, Marine Corps Base Camp Pendleton
Joined Jan 2013
There still not done!? We tried to get some field ops for out there a while back but didn't cause of that. I mean it's JUST 2M matting.... Lol kidding had to help 29 stumps re-do theirs, not fun
Disp0sablehero is offline Find More Posts by Disp0sablehero
Old Feb 02, 2013, 01:42 PM
flyandi is offline
Joined Aug 2009
I am going to hit the Lots around 1ish and going to test fly the FPV Racer ..
If it works well, I can meet you at Dave's around 2pm ...
flyandi is offline
Joined Aug 2009
or come up to the Lots .. it's like 5-8min drive from Daves...
Yippee! 1st FPV Meetup San Diego North County - September 29th 2012 at Dave's Beach, Carlsbad flyandi FPV Talk 364 Nov 13, 2012 09:05 AM
Link FPV Meetup in North County San Diego flyandi USA - District X 0 Aug 24, 2012 05:54 PM
Sold $60 LPU San Diego flyzone Focke wolf fw-190 reciver ready hepavirus Aircraft - Electric - Airplanes (FS/W) 5 Jun 20, 2012 07:59 PM
Discussion San Diego FPV Flyers? scrtsqrl FPV Talk 21 Mar 21, 2011 08:58 PM
Discussion AUV show in San Diego with FPV/RPV questtek FPV Talk 0 Jun 11, 2008 10:25 AM
