Old Jan 02, 2013, 09:24 AM
Bill0 is offline
Find More Posts by Bill0
Bill0's Avatar
United States, CA, Oceanside
Joined Aug 2010
See Otto made the Mail Online, from England no less Pretty impressive.
http://www.dailymail.co.uk/sciencete...-Superman.html
Bill0 is offline Find More Posts by Bill0
Old Jan 02, 2013, 09:53 AM
SDSURFnGLIDE is offline
Find More Posts by SDSURFnGLIDE
Multi rotors=No Paycheck left
SDSURFnGLIDE's Avatar
United States, CA, San Diego
Joined Apr 2011
Originally Posted by Kloner View Post
if you never use HD viewing of your flicks or aren't integrating gopro with a regular video camera you probably don't need protune. It had an option for on or off. You guys saying the camera malfunctions with protune off as well? Mine holds it's own but i had to get one of them fancy memory cards. Mine works, but it tends to shut off from vibrations, like wide open throttle kinda stuff. it hardly ever freezes and when it does is in the first 3 seconds 99% of the time
Yea...i don't think id really ever use the pro tune to its full potential..I'm happy without it...i was frustrated a hell trying to use my gp...it kept stopping after about 2 seconds after recording...I'm using a class 10 16 gig too....
SDSURFnGLIDE is offline Find More Posts by SDSURFnGLIDE
Old Jan 02, 2013, 10:48 AM
typicalaimster is offline
Find More Posts by typicalaimster
typicalaimster's Avatar
Joined Jan 2005
It still malfunctions with ProTune turned off. In fact it didn't matter if ProTune was turned on or off it'd still die. Nor did it matter what video resolution or frame rate it was set to. If it didn't freeze at 2-3 seconds.. It'd freeze right around 30 seconds. Once it DOES record I can fly or even set it on the bench and it'll go for hours. I even went out and bought one of the expensive class 10 SD cards in hopes it'd fix the problem. Instead it made the problem worse than using a Class 4 card. The firmware has caused problems since the beginning. Either killing people's GoPro's or causing them to lock up. Most companies would have acknowledged the problem and released a patched firmware to fix the problem. Instead it seems GoPro is pulling an Apple and pushing everyone to upgrade to their new camera. Based on this firmware performance I hesitate to buy a GoPro Black. Mind you I can trade this Hero 2 in at Best Buy and get the Black!
I thought it was vibration as well. Then I thought it might have something to do with the Live Out. Having the time to spend on the camera out in Az last week.. It's the firmware. It's the only thing on the camera that has changed. I'm still doing HD viewing of my videos. The only difference between Protune and normal is 'Broadcast Quality' as they put it. About 90% of the time my videos are going to end up on YouTube which already does their thing with them. Considering CNN and some of the other news agencies use Skype to interview people.. If I ever catch something news worthy I doubt they're going to care about the quality. Don't think I'll see a NatGeo offering any time soon. /soapbox
typicalaimster is offline Find More Posts by typicalaimster
Old Jan 02, 2013, 10:51 AM
Joined Apr 2011
Yep as soon a you down grade the FW....it works like a charm......and I'm satisfied with that!
Old Jan 02, 2013, 11:26 AM
Kloner is offline
Find More Posts by Kloner
Aerial DP
United States, CA, Lakeside
Joined Apr 2010
you need that uhs-1 thing, it's different than a class 10, but none the less.
http://www.bhphotovideo.com/c/produc...mory_Card.html
like those
Kloner is offline Find More Posts by Kloner
Old Jan 02, 2013, 11:44 AM
Joined Jan 2005
I'll give it a whirl.. My confidence in GoPro's product diminished when I spend more time trouble shooting something that worked one firmware release ago!
Old Jan 02, 2013, 11:51 AM
Kloner is offline
Aerial DP
Joined Apr 2010
i hear ya. they are pushing the processors limits.
Old Jan 02, 2013, 01:06 PM
nieder2 is offline
Find More Posts by nieder2
Joined Jan 2012
hey guys, been a while since I've had a chance to fly since I've been traveling a lot but I got out and flew my small flying wing yesterday with the Crius All in one pro flight controller running ArduPlaneNG and Minim OSD. Pretty impressed with it so far for ~$100 for a full IMU flight controller and OSD
$Tree Foamboard flying wing and Crius All-in-one-pro (AIOP) Maiden (2 min 54 sec)
The large flying wing that some of you have seen suffered a crash so I'm in the process of rebuilding that one and plan to run this FC setup on it when its done.
nieder2 is offline Find More Posts by nieder2
Old Jan 02, 2013, 01:25 PM
Joined Apr 2011
http://youtu.be/0YdF88qPMTU
Hey..welcome back...
Old Jan 02, 2013, 01:38 PM
tregtronics is offline
Find More Posts by tregtronics
Fly it, edit it, post it.
tregtronics's Avatar
Joined Dec 2011
There is a heap of information on that OSD, what OSD is that?
tregtronics is offline Find More Posts by tregtronics
Old Jan 02, 2013, 01:54 PM
Joined Jan 2005
Very cool. Can you send the MAVLINK command over one of your channels to flip through the OSD screens?
Old Jan 02, 2013, 02:03 PM
nieder2 is offline
Joined Jan 2012
MinimOSD extra http://code.google.com/p/minimosd-extra/ totally configurable to whatever you want. I thought you had it?
Old Jan 02, 2013, 02:05 PM
nieder2 is offline
Joined Jan 2012
right now i just have it set up to cycle based on flight mode changes. If you toggle from manual to stab then back to manual within 2 seconds, it will go to the next screen panel.
Old Jan 02, 2013, 02:11 PM
Joined Jan 2005
Very cool. It's quite a lot of information on the screen. I found I removed a bunch of stuff after a couple flights.
Old Jan 02, 2013, 02:33 PM
Joined Dec 2011
I do have it, never turned it on yet.... now I am stoked. The plane it is in is waiting for maiden flight... so I have never even turned it on after embedding it in the wing
Been SUPER sick since hanging with Kloner in the desert, so I am on an FPV pause.
Yippee! 1st FPV Meetup San Diego North County - September 29th 2012 at Dave's Beach, Carlsbad flyandi FPV Talk 364 Nov 13, 2012 09:05 AM
Link FPV Meetup in North County San Diego flyandi USA - District X 0 Aug 24, 2012 05:54 PM
Sold $60 LPU San Diego flyzone Focke wolf fw-190 reciver ready hepavirus Aircraft - Electric - Airplanes (FS/W) 5 Jun 20, 2012 07:59 PM
Discussion San Diego FPV Flyers? scrtsqrl FPV Talk 21 Mar 21, 2011 08:58 PM
Discussion AUV show in San Diego with FPV/RPV questtek FPV Talk 0 Jun 11, 2008 10:25 AM
