Old Nov 02, 2012, 01:45 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
rctimer are mixed P/N
From HK best are the F-20/30As
renatoa is online now Find More Posts by renatoa
Old Nov 03, 2012, 09:03 AM
Philip Morris is offline
Find More Posts by Philip Morris
Joined Sep 2012
please tell me how to calibrate the stick throttle?
at this speed controller
Philip Morris is offline Find More Posts by Philip Morris
Old Nov 03, 2012, 09:32 AM
nebstress is offline
Find More Posts by nebstress
Advanced Monkey
nebstress's Avatar
United Kingdom, England
Joined Nov 2011
Do you mean Throttle calibration? if so it is the same procedure as with most ESC's:
Connect ESC to the Throttle channel of RX, Power TX move Throttle stick to highest/maximum, Power ESC wait for beeps then move Throttle stick to lowest, more beeps & its done!
Manual for programming ESC's is HERE.
nebstress is offline Find More Posts by nebstress
Old Nov 03, 2012, 10:41 AM
Joined Sep 2012
thanks for the reply
I know how to do it on the other controllers speed
I do not understand what kind of signal at this controller speed . When lowered the stick Throttle down?
I read the manual, there is about calibration Throttle nothing written.
Old Nov 03, 2012, 10:52 AM
Advanced Monkey
nebstress's Avatar
Joined Nov 2011
The manual is for 'Programing' the ESC's only, no Calibration.
Sorry I don't understand what you mean:
"I do not understand what kind of signal at this controller speed . When lowered the stick Throttle down?"
If you know how to do it on other ESC's then you just do that!
Old Nov 14, 2012, 12:38 AM
alek3d is offline
Find More Posts by alek3d
Slovakia
Joined Nov 2010
I played with one yesterday and it does not seem to have throttle calibration like Plush or HobbyWing have. Perhaps it has automatic calibration.
I set the throttle to max then connected ESC, waited for the first beeps and set the throttle to min. All it did was it flipped the brake setting.
alek3d is offline Find More Posts by alek3d
Old Nov 20, 2012, 01:59 AM
Arxangel is online now
Find More Posts by Arxangel
Arxangel's Avatar
Bulgaria, Sofia-grad, Sofia
Joined Feb 2012
Sooo, any headway with calibrating throttle on this ESC? I received mine yesterday and still haven't been able to calibrate it using the "standard" method...
Arxangel is online now Find More Posts by Arxangel
Old Nov 20, 2012, 04:12 AM
alek3d is offline
Slovakia
Joined Nov 2010
I already installed and maidened my quad with these. Looks like they might have some kind of automatic throttle calibration.... quad with Naza and GPS flies great. Better than with regular ESC. It wobbles a lot less on fast descents, which is a common Naza issue.
It cooperates with Naza perfectly. Plush/SuperSimple/HobbyWing I had to connect Naza first and only then power up ESCs to initialize properly. Multistars initialize with no problem when powered up Naza and ESCs at the same time.
For me a big plus is changing rotation direction via card, because I don't use connectors so changing rotation of a motor was a bit of headache, since I needed to re-solder two wires again. No big deal but little things just make life a bit easier
Old Nov 20, 2012, 04:46 AM
Arxangel's Avatar
Joined Feb 2012
Yes, I figured it would work great with the Naza. I am puzzled, however, by this "automatic" throttle calibration. I will have to pester some HK product specialists to see whats that about.
Old Nov 20, 2012, 05:19 AM
alek3d is offline
Slovakia
Joined Nov 2010
I am just guessing it has some kind of automated throttle calibration, since manual does not offer any calibration procedure and "classic" one does not work. I read some ESCs have that.
If you find something out about it, please let us know.
Old Nov 20, 2012, 07:32 AM
Arxangel's Avatar
Joined Feb 2012
I tried to live chat to a HK Product specialist, but none were available at the moment, so I sent them an email. Will let you know if/when they respond.
Old Nov 24, 2012, 09:07 AM
anam_funny is offline
Find More Posts by anam_funny
India, Delhi, New Delhi
Joined Jan 2010
Were anyone of you able to find out about the Throtle Calibration... It turns out that the ESCs go directly into programming mode after initializing if you try to set the end points!!!
I am making a model for someone and I am using the Turnigy 9X Radio. I dont think that the auto calibration is good enough because the motors start off at around 10-12% throtle, strange...
Apparently, these look like the same as the MayTech ESCs...
Please update me if anyone figured out what to do...
anam_funny is offline Find More Posts by anam_funny
Old Nov 24, 2012, 04:09 PM
Arxangel's Avatar
Joined Feb 2012
I've peen pestering HK Product specialist for a couple of days now. Have not received a correct answer as of yet. One of the guys is searching for the answer out of office hours, the others that could be contacted at support@hobbyking.zendesk.com still cannot understand what throttle calibration means, and keep telling me how to set brake modes...
I am speechless at this point...
Old Nov 24, 2012, 04:19 PM
acetech09 is offline
Find More Posts by acetech09
I think I'm inverted. Maybe.
acetech09's Avatar
United States, CA, Pacifica
Joined Apr 2012
What do you expect from HK? The fact that you have a guy searching for it at all is what is leaving me speechless.
acetech09 is offline Find More Posts by acetech09
Old Nov 25, 2012, 02:16 PM
Arxangel's Avatar
Joined Feb 2012
I just hope he comes back with some useful info...
Discussion New multistar ESCs line from HK just for multirotors. Quite a few problems so far Koo Multirotor Talk 62 Jan 05, 2015 06:32 AM
Discussion New Turnigy Fast Response Multirotor ESC`s Crissbrasil Multirotor Electronics 5 Oct 04, 2012 05:51 AM
Sold turnigy/hobbyking 18a esc hi2nr Aircraft - Electric - Multirotor (FS/W) 3 Sep 06, 2012 01:16 AM
Discussion Problem with HobbyKing KKmulticopter Board and Turnigy Plush 12A ESC drippin Multirotor Talk 7 Jun 04, 2012 02:04 PM
Alert Buddy Price Code (HobbyKing) Turnigy Plush 60amp ESC 7AFLYER Hot Online Deals 0 Apr 02, 2012 02:51 PM
