Old Oct 03, 2012, 03:00 PM
TheFernMan is offline
Find More Posts by TheFernMan
Too Many Thread Subscriptions
TheFernMan's Avatar
United States, FL, Miami
Joined Jul 2012
HobbyKing Turnigy Multistar MultiRotor ESCs
New HobbyKing Turnigy Multistar MultiRotor series ESCs
Turnigy Multistar 10 Amp Multi-rotor Brushless ESC 2-3S
Turnigy Multistar 15 Amp Multi-rotor Brushless ESC 2-3S
Turnigy Multistar 20 Amp Multi-rotor Brushless ESC 2-4S
Turnigy Multistar 30 Amp Multi-rotor Brushless ESC 2-4S
Turnigy Multistar 45 Amp Multi-rotor Brushless ESC 2-6S
Introducing the brand new range of Turnigy Multistar ESC's!
These brushless speed controllers are primarily intended for use in Multi-rotor aircraft and are the key element to our new Modular Multi-rotor power systems.
This series of ESC's features a very smooth, linear throttle response, without sacrificing a rapid, crisp, response to any throttle input. Safety is not forgotten with all Multistar Esc's featuring adjustable battery LVC, stalled motor (overload) protection, signal loss shut-down and safe arming.
All Multistar series ESC's come pre-terminated with bullet connectors suited to the ESC's rated power handling. This allows for plug and play convenience by simply adding the appropriate battery supply splitter (3,4 or 6 ESC) and motor lead extensions from the Multistar modular accessory line. What could be simpler?
Multistar ESC's can utilise the Multistar programming card. All Multistar ESC's feature an ATmega MCU that opens the door to customisable firmware - for those so inclined!
In total there are 5 ESC's, ranging from 10 45 amps.
Details:
Smooth and linear throttle control
Fast response to throttle input
Low-voltage cut-off
Stalled motor protection
Throttle signal lose protection
Safe power-on (throttle lockout)
Support 480Hz+ high refresh rates (up to 499hz)
Compatible with programming card
TheFernMan is offline Find More Posts by TheFernMan
Old Oct 03, 2012, 08:21 PM
TheFernMan's Avatar
Joined Jul 2012
SimonK said this on the HobbyKing discussion product page:
"Hello! This board does seem to be compatible with kda.hex in my tree (github****/sim-/tgy/), which was contributed by Esden earlier in the year. It has an oscillator and programming pads, and has a TQFP ATmega8 so works with the HobbyKing ATmega socket flasher. The downsides are it's P/N and the input is inverted so it can't work with the USB linker."
Old Oct 03, 2012, 08:36 PM
acetech09 is offline
Find More Posts by acetech09
I think I'm inverted. Maybe.
acetech09's Avatar
United States, CA, Pacifica
Joined Apr 2012
One thing that caught my attention was stall/overload protection. I'm surprised most ESCs don't have that already, if HK can put it into their ESCs for $10 a pop.
acetech09 is offline Find More Posts by acetech09
Old Oct 03, 2012, 08:51 PM
TheFernMan's Avatar
Joined Jul 2012
The F-30A are still better ESCs after flashed
Old Oct 03, 2012, 10:31 PM
TheFernMan's Avatar
Joined Jul 2012
And now they're all gone from the website lol what happened HobbyKing??
Old Oct 03, 2012, 11:16 PM
georgez is offline
Find More Posts by georgez
C'mon Man!
georgez's Avatar
United States, TX, Denton
Joined Jul 2012
Very strange. I just saw them about an hour ago.
georgez is offline Find More Posts by georgez
Old Oct 04, 2012, 01:50 AM
mongo56 is offline
Find More Posts by mongo56
about:blank
mongo56's Avatar
Slovenia
Joined Aug 2007
I guess they pulled them after seeing all the critique in the comments section.
Could be a good thing if they've listened.
Give us some atmel based, one type fet only, opto escs with simonk's firmware (and pay him royalties) for a decent price and they're golden.
mongo56 is offline Find More Posts by mongo56
Old Oct 04, 2012, 02:00 AM
Erknie is offline
Find More Posts by Erknie
Australia, QLD, Brisbane
Joined Nov 2011
They are still there.
http://www.hobbyking.com/hobbyking/s...idCategory=714
Erknie is offline Find More Posts by Erknie
Old Oct 04, 2012, 03:27 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Still there and still to avoid.
renatoa is online now Find More Posts by renatoa
Old Oct 04, 2012, 06:02 AM
Erknie is offline
Joined Nov 2011
Have you actually tried any of these new ESCs or are you just trolling them like several other people seem to be already?
Old Oct 04, 2012, 08:40 AM
jab is online now
jab
Find More Posts by jab
jab
Unregistered User
Joined Aug 2007
They might be suited for multicopters, just like other Turnigy ESC. Especially if re-flashed with a SimonK firmware. But in no shape or form are they designed to be dedicated multicopter ESC's.
Just take a look at the ESC/programmer card features and you see what I mean.
- Battery chemistry selection.
- Low voltage cut-off sensitivity.
- Cut-off type hard or soft.
- Soft start slow, medium or fast.
All airplane/helicopter specific features that has no place on a multicopter.
jab is online now Find More Posts by jab
Old Oct 04, 2012, 08:54 AM
TheFernMan's Avatar
Joined Jul 2012
The f-30a are still better after flashing. But these might be good for people who want fast response rate and no flashing. But then you can just get the ones from RCTimer which are similar hardware (P/N Fet) and flashed with SimonK firmware already.
So I don't know lol.
Old Oct 04, 2012, 08:55 AM
TheFernMan's Avatar
Joined Jul 2012
They were gonna at the time I wrote that. They updated something on the page. They added how to "turn off" the switching bec. To remove to wire. That line wasn't there before.
Old Oct 04, 2012, 09:12 AM
Joined Sep 2007
Some people don't need to try things to figure how they behave.
It is calling engineering
Old Oct 04, 2012, 09:41 AM
acetech09's Avatar
Joined Apr 2012
I'm gonna quote you on that .\
I'm pretty sure these ESCs are one of their other ESC lines, re-covered and pre-soldered with connectors for their "modular multirotor system". I.e. these are the n00b-ESCs for the countless people that think octocopters are a great way to get into the hobby.
Discussion New multistar ESCs line from HK just for multirotors. Quite a few problems so far Koo Multirotor Talk 62 Jan 05, 2015 06:32 AM
Discussion New Turnigy Fast Response Multirotor ESC`s Crissbrasil Multirotor Electronics 5 Oct 04, 2012 05:51 AM
Sold turnigy/hobbyking 18a esc hi2nr Aircraft - Electric - Multirotor (FS/W) 3 Sep 06, 2012 01:16 AM
Discussion Problem with HobbyKing KKmulticopter Board and Turnigy Plush 12A ESC drippin Multirotor Talk 7 Jun 04, 2012 02:04 PM
Alert Buddy Price Code (HobbyKing) Turnigy Plush 60amp ESC 7AFLYER Hot Online Deals 0 Apr 02, 2012 02:51 PM
