Old Nov 15, 2012, 12:43 AM
doxilia is online now
Find More Posts by doxilia
doxilia's Avatar
Montreal, Canada
Joined Mar 2008
Kevin,
this you've got to explain, I can't seem to get my head 'round it:
how d'ya get the servo horns on to the servo pinion and then bolt 'em down with no side access to a driver?
Are the elevator servos installed in to the core in the same way as for the ailerons?
David
doxilia is online now Find More Posts by doxilia
Old Nov 15, 2012, 06:21 PM
Kevin2035 is offline
Find More Posts by Kevin2035
Kevin S. Gribben
Kevin2035's Avatar
Joined Mar 2011
Yes, nothing more exotic that cutting them into the cores and sheeting over the top of them. On the Atalanta it has a removalble stab (dont ask me why) so the stab has hatches that can be acsessed when you slide the stab off. The wing has the servos comitted under the skin.
Agressive but pretty. I just have never had to change a wing servo. When you start engineering a good hatch with achors for the servo then achors for the hatch, then the 8 screws, it just doesnt make sense.
I am sure when I have to cut one of these out I am going to feel differnt, but they are pretty once completed.
Kevin2035 is offline Find More Posts by Kevin2035
Old Nov 15, 2012, 06:22 PM
Kevin S. Gribben
Kevin2035's Avatar
Joined Mar 2011
wing servo
Old Nov 15, 2012, 06:35 PM
doxilia's Avatar
Montreal, Canada
Joined Mar 2008
Kevin,
thanks for the explanation but I don't follow how you access the servo arm. Assuming it is in place when you install the servo and then leave it there when you sheet the wing, well, it's in place and no need to access it.
If for any reason, the servo arm should break or need replacing, can it be removed? Wouldn't you need to access the top of the servo with a screw driver to remove the arm?
I figured you have a system to install the servo, sheet the wing and then, whenever you want install and remove the servo arm. True?
David
P.S. Will be getting back to your insightful email later tonight. I'm a drawin' while the wee family is out!
Old Nov 15, 2012, 07:25 PM
dhal22 is offline
Find More Posts by dhal22
United States, GA, Alpharetta
Joined Dec 2007
My guess is you just play the odds on breaking a servo arm.
David
dhal22 is offline Find More Posts by dhal22
Old Nov 17, 2012, 11:05 AM
stuntflyr is offline
Find More Posts by stuntflyr
stuntflyr's Avatar
United States, AZ, Tucson
Joined Jun 2010
Don't European guys do this on their models as a matter of course. I recall seeing this on several models.
Chris...
stuntflyr is offline Find More Posts by stuntflyr
Old Nov 27, 2012, 10:55 AM
BrumBob is online now
Find More Posts by BrumBob
Birmingham, UK
Joined Apr 2007
as a European (at least nominally) I've only ever seen the servo built into the wing in gliders, usually of the small foam variety. Even the big glass soarers with glued in servos have an access hatch over them. Multiplex like the buried servo in their small electric powered all foam models like the Funjet but that's not a veneered wing!
On my wing mounted servos I either use a plastic servo mount that forms the hatch or make one from 1/16" ply and a couple of blocks. Occasionally I'll use a couple of servo rails across two ribs with the top of the servo proud of the wing just to ring the changes.
There is one setup (an old one) that would look the same. It used to be quite common to use 90 degree belcranks set out in the wing with pushrods to a single central servo. That would look like Kevin's setup but would have a lot more lost movement between the servo and aileron.
BrumBob is online now Find More Posts by BrumBob
Old Nov 27, 2012, 11:35 AM
doxilia's Avatar
Montreal, Canada
Joined Mar 2008
Bob,
good comments.
The above setup is as old as I am (actually, older). I remember building several models with the infamous bellcranks which made a lot of sense to me at the time when transitioning from C/L models to R/C. We were always on the lookout for the next slickest bellcrank linkage.
Today, in a pattern ship, and in a foam core wing, this has got to be the least desired setup I can think of. The whole concept of putting the linkage near the control is to have a short, positive, no play, setup. Introducing bellcranks and multiple linkages not only makes it difficult if not impossible to adjust but the original concept is lost. One might as well use torque rods which can be adjusted since the servo is in the middle anyway.
Companies like Futaba have even designed servo cases specifically for a smooth wing bottom where the servo is mounted. It might put the linkage on the outside "ruining" the looks but everything is easy to maintain and adjust when needed.
I probably couldn't bring myself to cut into a nice finish such as those done by Kevin if something were to go wrong with the servo.
David
Old Nov 27, 2012, 12:18 PM
Huang is offline
Find More Posts by Huang
United States, CA, SF
Joined Sep 2001
I fly sailplanes a lot so this is an interesting cross over . The current gen 3M+ F3J/F3F competition sailplanes use both servo frames and gluing the servo directly to the composite skin. Both methods work great, as long as the builder takes care in how the servo is supported so that there is no movement of the wing skin. The servos in foam wings (like in a DLG) are almost always glued in.
As Bob noted the difference with Kevin's build is there's no hatch, so it would require cutting into the sheeting to service. It definitely saves weight and produce a beautiful finish - nice to see how he did it. I agree with Kevin on the reliability of todays servos, for our application you would rarely need ever to change. I would do this if the wing is monokoted... though maybe not for a painted wing!
As for the servo arm, I've never had one break. The reliability of servos today are very good. Our sailplanes take constant beating especially the flap servos, but they are glued in because we don't often change them. Of course, we use very high quality servos and they are all metal geared.
For the Atlanta, I might paint the fuse but monokote the wings to save weight. If I go that route, I'll glue the servos in, but use a hatch that is tack glued in just like on the sailplanes. No additional weight and no protruding screws, and easier to service the servo if necessary.
Huang is offline Find More Posts by Huang
Old Dec 08, 2012, 02:43 AM
Huang is offline
Joined Sep 2001
Here's a question on the retracts. I was originally planning for electric, but just realized that electric retracts might not go so well for the nose wheel. I mean it is sitting right next to the hot exhaust header inside an enclosed pan, almost touching. It definitely is hot there, and electric retracts and wires will not likey...
Should I spring for a set of MK SP mechanicals old style? The mains are already cut out in the wings and MKs will drop in. Or should I go with electrics and make a heat shield for the nose gear? It's going to be a lot to take for the nose retracts, heat and vibration and all... tough life! What do you guys think?
Kevin I think you had the kawasaki Atlanta with e-flite electric retracts?
Old Dec 08, 2012, 01:38 PM
Fatherof4 is offline
Find More Posts by Fatherof4
Raised on 80's Pattern
Fatherof4's Avatar
Rancho Santa Margarita, CA
Joined May 2006
Matt,
I think the E Flites are a no-go on nitro classics. Tony had them in his P 7 and the vibration shook the nose gear apart. I run MKs on my Atlanta. I went to 2 servos with MKs on the C4, much easier. Spring Airs are the gear of choice for Kevin.
Doug
Fatherof4 is offline Find More Posts by Fatherof4
Old Dec 08, 2012, 08:21 PM
Kevin S. Gribben
Kevin2035's Avatar
Joined Mar 2011
Ya the Eflights have been a bust so far. The make a nice medium sized set but I am skittish to put then in on a "full" build. Nobody has had good luck on any of the P7's I have seen flown. I have been flyin the spring airs since the 80's with good luck....... but really want the air pump out of my flight box.
My current thought is to retrofit the sring airs with the "Down and Locked" actuators, currently that is the setup I am working tword. Though the $200 to Spring Air, then another $300 to down and lock seems stiff. Non of the chinese $79 solutions seem to have high resolution trunion blocks or steering systems that strike me pretty.
Old Nov 03, 2013, 07:32 PM
Boo is offline
Boo
Find More Posts by Boo
Boo
Joined Dec 2004
Originally Posted by Pitstop000 View Post
Oh, by the way the wing dihedral is wrong in the manuals.
Sorry for the late reply but what should the dihedral be on an Atlanta ?
Boo
Boo is offline Find More Posts by Boo
Old Nov 03, 2013, 09:29 PM
Pitstop000 is offline
Find More Posts by Pitstop000
Paul Pappas, AMA 42520
Pitstop000's Avatar
Joined Aug 2008
Hi Boo,
If using the method in the instruction manual for measuring the dihedral it should be 6mm.
To make it easier though just place the wing halves upside down on a flat bench and raise the center to 6mm, just make sure you’re leading and trailing edges are equidistant from the bench top.
Pitstop000 is offline Find More Posts by Pitstop000
Old Nov 05, 2013, 08:58 PM
Boo is offline
Boo
Boo
Joined Dec 2004
Thanks for the info and tip.
Boo
For Sale Bunch of planes and a quadcopter for sale LPU Metro Atlanta shadow102 Aircraft - Electric - Airplanes (FS/W) 6 Aug 25, 2014 03:19 PM
Alert GP Siren for sale / Atlanta area pickup sdstick Atlanta Area RC 5 Jul 17, 2006 11:35 PM
Alert For sale in Atlanta Area MagicFlyer Atlanta Area RC 0 Jun 23, 2006 12:42 AM
Two planes for sale for Atlanta flyers. MagicFlyer Atlanta Area RC 0 Nov 17, 2005 05:43 PM
X250 for sale in Atlanta Scott C Aircraft - Electric - Airplanes (FS/W) 3 Feb 09, 2002 04:34 PM
