Old Oct 03, 2012, 12:16 PM
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
Looking for that "Perfect" design
A flying buddy and I have made a pact to go to the big Nostalgia bash at Lost Hills in 2013. That gives me a year to make a few models and get them trimmed out.
I'm looking for some inspiration for picking a Class A model that is not commonly modeled and that has good lines to it. Something that has a good amount of eye candy but stops somewhat short of the "way out there" building and possible trimming issues of designs such as the Cobra, beautiful though it may be.
I've started reviewing the Vintage Plans thread but it's a monumental task to sift through it checking for such models. So I thought perhaps some of you might have some design you found in that thread that stands out. Or perhaps one you have in a magazine stashed away that could give me a possible candidate to consider.
So far I'm leaning to a glow powered version of the Chet Lanzo Swayback as being a design that could fly decently well yet leans heavily towards having a bunch of character along with not being the sort of thing I'd find modelled by everyone and their brother at the field. Another one I like is the Super Pheonix other than the thin flat bottom airfoil. I'm hoping to find a design with a higher camber airfoil so it can slow down and have that "floaty" look in the air. Another I found in the Plans sticky is the class A 8-ball. But at only 300 sq inches it's a trifle small for a .15 as it would have to weigh in at too high a weight for a truly floaty sort of glide.
So now that you can see sort of where I'm wanting to go how about some suggestions?
BMatthews is offline Find More Posts by BMatthews
Old Oct 03, 2012, 09:20 PM
United States, AR, Hope
Joined May 2009
...nevermind
cd_webb is offline Find More Posts by cd_webb
Old Oct 03, 2012, 10:46 PM
RyanNX211's Avatar
Upper Arlington, Ohio
Joined Dec 2007
Demon (French)
Has anyone ever seen a Demon? A French design from about '45 in several sizes that looked bit like a Playboy w/o the stringers and a V dihedral.
RyanNX211 is offline Find More Posts by RyanNX211
Old Oct 04, 2012, 12:41 AM
Gold Coast Australia.
Joined Jan 2005
Hayseed is a pretty model with a cabin. It's about 50in span from memory.
gossie is offline Find More Posts by gossie
Old Oct 04, 2012, 01:44 AM
Gluehand's Avatar
The windy west coast of Sweden
Joined Sep 2008
Jerry Stoloff's Spearhead crosses my mind.....
Gluehand is online now Find More Posts by Gluehand
Old Oct 05, 2012, 02:40 AM
JMP_blackfoot's Avatar
Birthplace of Aviation
Joined Jul 2003
Demon and the smaller version called Pirate were designed by Robert Chabot, who was president of the MACA (Modele Air Club d'Asnieres).
Demon flew with a Micron 5cc fixed compression engine, Pirate with a Micron 2.8cc.
Robert Chabot also designed the Corsaire, flown with a Delmo 2.65cc engine at the June 1945 record days. I flew mine rudder-only with a Taifun Zyklon 2.5cc diesel to good effect.
JMP_blackfoot is offline Find More Posts by JMP_blackfoot
Old Oct 05, 2012, 07:31 AM
RyanNX211's Avatar
Joined Dec 2007
I think you found it!
I stumbled on a photo of a line up of four different sizes in a magazine that I permanently loaned (Model Builder, Designer & Constructor)
Is the landing gear wire with balsa fill?
Old Oct 05, 2012, 07:40 AM
Hatters gonna hat.
madbomber's Avatar
United States, CO, Denver
Joined Apr 2011
What about a Snow White? Very elegant, might prove to be a difficult build, though.
madbomber is offline Find More Posts by madbomber
Old Oct 05, 2012, 08:21 AM
Joined Jul 2003
Yes, wire with balsa fill, actually balsa plywood wrapped in silk (ctp = contreplaque = plywood).
PM me for full-size plan .tif scan file of either of these models.
Old Oct 05, 2012, 11:20 AM
B for Bruce
BMatthews's Avatar
Joined Oct 2002
Thanks for all the suggestions so far. A few of them are actually old timers. I'm looking for something that came out after the Jan 1942 date to qualify as Nostalgia. So sadly such things as the Snow White don't fit. Same with the Hayseed which was a design from before the war.
That Pirate looks fantastic. I'm a little worried about the low dihedral angle and I would need to study the plans more to find some key as to the span. But it has "The Look", no doubt about it.
The Spearhead is so out there that it could be a fun model to fly. Is it from the post Old Timer cutoff date? It has more the look of a pre-war design.
I went to the blogspot site shown on the Pirate plans to look for a date and wingspan. What I found is a wealth of odd designs from various countries. So I've got an evening or two worth of plodding through that site looking at options.
I want to try to get a design that is normal enough that I know it'll fly without any major surprises. But at the same time I want everyone that sees it to ask "WTH is THAT! !"
Old Oct 05, 2012, 11:26 AM
"Butchering Balsa since 1971"
CashRC's Avatar
USA, TX, McKinney
Joined Dec 2003
How about a Glory Bee? It's a pretty thing, and you don't see it very often.
CashRC is offline Find More Posts by CashRC
Old Oct 05, 2012, 11:54 AM
Joined Jul 2003
Originally Posted by BMatthews View Post
That Pirate looks fantastic. I'm a little worried about the low dihedral angle and I would need to study the plans more to find some key as to the span...
Pirate is essentially a reduced size Demon.
I can vouch for the flying qualities of both models, you would not need to alter the original dihedral. Even if you felt the need, the split wing with struts makes it easy to change the dihedral.
Statistics:
Weight: Demon 48 oz, Pirate 24 oz.
Wingspan: Demon 70 in, Pirate 57 in.
Dihedral: Pirate 3.75 in.
Length: Demon 40 in, Pirate 33.5 in.
Wing area: Demon 620 sqin, Pirate 387 sqin.
Tail area: Demon 181 sqin.
Fin area: Demon: 55 sqin.
Demon flew with Micron 5cc diesel, roughly equivalent to a Brown 60.
Pirate flew with a Micron 2.8cc diesel. My friend's Pirate does very well with a Taifun Hurrikan 1.5cc diesel.
A PM to me can bring you full-size plan files for either one, and I can help with translation if your French is rusty.
Old Oct 05, 2012, 11:55 AM
B for Bruce
BMatthews's Avatar
Joined Oct 2002
Oh yeah.... The Glory Bee was/is on the list of possibles as well. And you are very right that it's got the eye candy factor in spades.
I've pondered the GB for a while and I'd like to try the ammonia molding trick. I'd carve a plug out of balsa bulkheads for shaping and blue styro for fill and mold the balsa "planking" in quarter shells. This would reduce building time by a whole heap over strip planking.
Odd side note.... I flew here in the Northwest with a fellow named George Oldershaw. He was a cousin or some such relation to Vernon Oldershaw, the designer of the GB.
Old Oct 05, 2012, 11:59 AM
B for Bruce
BMatthews's Avatar
Joined Oct 2002
JMP, thankyou so much for the information on the Pirate. There's no doubt that it has "The Look" and being a French design it would certainly stymie the field pundits.....
The wing area would make it a natural for the steel finned OS.19 I've got if I can keep the weight down to the lower or mid 20's.
I'd have to go with a one piece wing though. The considerable stress of DT landings would simply massacre the center section as shown.
Old Oct 05, 2012, 04:55 PM
RyanNX211's Avatar
Joined Dec 2007
Is the construction of the Demon the same? It may have to be beefed up for R/C but it could give Freddie Mulholland's McCoy 60 powered Swayback a run for the money in R/C Nostalgia. Where was it published?
http://www.outerzone.co.uk/plan_details.asp?ID=506
Discussion Looking for VTOL that tilts props for control milo12 VTOLs 4 Aug 23, 2012 08:39 AM
Found Looking for a Pike Perfect FlyAndy Aircraft - Sailplanes (FS/W) 4 Apr 02, 2012 09:22 AM
Found Looking for something "Perfect"! Crash Prone Aircraft - Sailplanes (FS/W) 4 Mar 26, 2012 08:51 PM
Question Looking for plans that use electronics from 4 site smilam Foamies (Scratchbuilt) 1 Feb 23, 2012 11:39 PM
Found Looking for a Perfect Pike Perfect....... So Cal Flyer Aircraft - Sailplanes (FS/W) 3 Dec 26, 2011 08:03 PM
