Old Oct 03, 2012, 11:59 AM
blutoh is offline
Find More Posts by blutoh
---o-O-o---
blutoh's Avatar
United States, NJ
Joined Mar 2012
Building an engine from plans?
Hi guys,
Has anyone built either of these steam engines? Whats your opinion, do you think either would make a good marine engine for RC boat use? The first one looks rather simple, but could be made into a twin for more power. There is a raw materials kit available. The second is a twin that doesn't require castings to build. But neither has reverse gear? Not sure how you would gedt reverse without some sort of transmission.
Pete
Little Machine Shop oscillating engine:
http://www.littlemachineshop.com/pro...ProductID=3484
http://swarfrat.com/VariableTwin.htm
Or this more complex "no castings" twin cylinder:
Two Cylinder Marine Steam Engine (2 min 1 sec)
Plans here.
blutoh is offline Find More Posts by blutoh
Old Oct 03, 2012, 03:55 PM
ooyah is offline
Find More Posts by ooyah
ooyah's Avatar
GLASGOW
Joined Feb 2011
Originally Posted by blutoh View Post
Hi guys,
Pete
http://youtu.be/_TwRhMlzf58
Plans here.
Hi Pete,
The twin cylinder engine looks very much as tho' it's influenced by Stuart Turners launch engine which at the bore and stroke you will need a big boiler to keep up with the engines needs.
Being a piston valve engine if the designer had made it with outside admission he could have done away with the uniflow exhausts in the side of the cylinder and exhausted it thro' the piston valve and then it's a simple job to make a reversing valve which changes the steam from the inlet to the exhaust and makes it reversible.
If you have never made an engine before and you don't have machining facilities I would suggest that you start on something simpler.
Here are some pics of a Launch engine nearly completed.
George.
ooyah is offline Find More Posts by ooyah
Old Oct 04, 2012, 09:15 AM
steamboatmodel is offline
Find More Posts by steamboatmodel
steamboatmodel's Avatar
Toronto, Canada
Joined Nov 2004
Hi Pete,
If you look in the Books thread I have listed a number of plans that can be downloaded, some of the books also have excellent plans and instructions.
Regards,
Gerald.
steamboatmodel is offline Find More Posts by steamboatmodel
Old Oct 04, 2012, 11:08 AM
blutoh is offline
---o-O-o---
blutoh's Avatar
United States, NJ
Joined Mar 2012
Thanks George and Gerald.
The book thread is a great resource. I can see I have a LOT of reading to do. Earlier this summer I picked up a hobbyist lathe/mill combo tool at a garage sale, and thought maybe I would look into applying it to do something in conjunction with my model boating interests. I see now that I have a big learning curve ahead of me, but thats what makes it all so interesting
Thanks.
Pete
Old Oct 06, 2012, 07:35 PM
Toronto, Canada
Joined Nov 2004
Thanks.
Pete
Which "hobbyist lathe/mill combo tool " did you pick up?
Regards,
Gerald.
Old Oct 07, 2012, 04:07 AM
Henk Goosen is offline
Find More Posts by Henk Goosen
Henk Goosen's Avatar
The Netherlands
Joined Dec 2008
Pet I found another plan.
http://www.machinistblog.com/bogstan...-engine-plans/
this looks like a nice engine.
Henk.
Henk Goosen is offline Find More Posts by Henk Goosen
Old Oct 07, 2012, 08:38 AM
blutoh is offline
---o-O-o---
blutoh's Avatar
United States, NJ
Joined Mar 2012
Gerald,
It's a Unimat 3. It has a milling attachment and a jig saw attachment. A little surface rust on the milling column, but nothing I can't clean up. Theres some other accessories as well, live center, support thingie wil three adjustable arms and a few others. I am looking for a manual so I can identify all the pieces. I found a few web sites with parts and accessories, but no manual. The Unimat looks like it was barely used. I paid $20 for it, so even if I only use it to learn on, I figure it's still not a bad deal.
Henk,
Thanks, that looks interessting, maybe a good project to get my feet wet. I downloaded the pdfs and I am going to read thru it tonight.
Pete
Old Oct 07, 2012, 10:35 AM
The Netherlands
Joined Dec 2008
Pete I downloaded the plans to, but first I build this one. It is the French wobbler plans from the John Tom engine site.
The Emco Unimat 3 is a fantastic little lathe, I have the predecessor the 4 which I use for clock repair.
Old Oct 10, 2012, 09:08 AM
Toronto, Canada
Joined Nov 2004
Gerald,
Henk,
Pete
Pete you must have been in a pirate outfit at that price. I have seen tham go for over $200 (thats when I stoped biding as that was as high as my budget would go). They are a great little machine, I have its bigger brother the emco compact 5 without the milling colum that I payed $1200 for years back. I haven't seen a manual for one recently but I have asked on my Model engineering group forum if I can borrow one to scan. There is a book "Book 32 Unimat III Lathe Accessories (WPS)" That may be helpfull. http://www.rcgroups.com/forums/newre...ply&p=22935231
Regards,
Gerald.
Old Oct 10, 2012, 10:01 AM
blutoh is offline
---o-O-o---
blutoh's Avatar
United States, NJ
Joined Mar 2012
Gerald,
It was one of those rare lucky finds. I stopped at a freinds house and across the street was a garage sale. I nosed around and there it was, all thrown in a cardboard box like trash. I aksed how much and the woman hesitated and said $20. I summoned up all of my negotiating skils and said "sold!". It's probably the only time in my life where I stepped in somehting good. There seems to be something wrong with that link, it goes to the reply page.
Pete
Old Oct 10, 2012, 06:58 PM
Kcal is offline
Find More Posts by Kcal
Joined Jul 2008
Ha ha, well played sir.
Kcal is offline Find More Posts by Kcal
Old Oct 11, 2012, 03:09 PM
blutoh is offline
---o-O-o---
blutoh's Avatar
United States, NJ
Joined Mar 2012
Thanks Kcal,
Now I have to learn how to use it !
I'll start with some small, simple parts before I tackle an engine, and slowly work my way up.
Pete
Old Oct 11, 2012, 05:44 PM
Toronto, Canada
Joined Nov 2004
I will try again,
Book 32 Unimat III Lathe Accessories The Workshop Practice Series Books
http://www.myhobbystore.co.uk/browse...ractice-series
http://www.myhobbystore.co.uk/produc...ccessories-wps
Regards,
Gerald.
PS There is sometimes when just making chips can be satisfying.
Old Oct 12, 2012, 05:26 AM
Circlip is offline
Find More Posts by Circlip
Bradford West Yorkshire, UK
Joined Apr 2010
Surprised that no one has mentioned "Edelstaal" yet.
River Queen Plans Instruction
This was a "technical" document for unimat owners to build.
http://www.john-tom.com/html/SteamPlans3.html
Scroll about a third of the way down.
Regards Ian.
Circlip is offline Find More Posts by Circlip
Old Oct 12, 2012, 10:18 AM
Toronto, Canada
Joined Nov 2004
I had forgotten about that article Ian, I remember someone doing one years back, the only tricky part is the valve, I think he made about three before he had one he was happy with.
Regards,
Gerald.
Build Log Bird of Time scratch build from plans ourbluehorizon Electric Sailplanes 19 Nov 30, 2013 12:36 PM
Mini-HowTo Model Airplane Building Clinic #2 ~ Building From Plans >> Begins TBD. All Welcome Murocflyer Balsa Builders 79 Dec 12, 2012 09:58 AM
Discussion Please Help with Building 3-Point Hydro From Plans Dave8888 Racing Boats - Electric 5 Aug 28, 2012 06:25 AM
Discussion New to building from plans hiflying The Builders Workshop 10 Aug 22, 2012 12:04 PM
