Rough up the sides of the magnets that are meant to be glued, and let the epoxy cure fully next time. I place wax paper between the wing halves to prevent them getting glued together, and let the magents cure with the wings in place.
Steve |
Latest blog entry: And now for something completely...
Paint Question
Just got one of the last Black Weasels.
Have seen some nicely decorated ones and would like to paint mine up. Likely leave the bottom black for visibility, but want to make the upper area more visible. Any suggestions on what type of paint to use, or cover? Also, (havent read the manual yet), is there an advantage other than mobility to use the magnets for the wings, or is it better just to glue them permanently. One more. I used two carbon fiber spars on my Alula to help keep the nose on after a few crashes resulting in it shearing off. I think will do the same for the Weasel. Suggestions? Thank you |
United States, CA, Carlsbad
Joined Jun 2012
If you glue the wings, permanently, the only place to put ballast, for windier days, would be in the belly finger hole. If not, you could just substitute the carbon rod with a steel one Others with more experience, may suggest more, as, I just now built my first ever Weasel. Hope it helped |
United States, ID, Lewiston
Joined Apr 2011
Another way to go is to use some UltraCote, spray a little 3M 77 on the wings to help adhesion. I did this to the top of the wings in flourecent green and just used clear packing tape on the bottoms. A lot lighter than paint, in fact my weasel came out ready to fly at 11.89 oz. Plenty of color, Tom.
| Thread Tools | |
| Wanted Weasel EPP Original | ch701 | Aircraft - Sailplanes (FS/W) | 7 | Jul 28, 2012 04:04 PM |
| Discussion Videos - Weasel Wild & Weasel Smooth - flying the flag for the Queens diamond Jubilee | Phil.Taylor | Slope | 10 | Jun 09, 2012 06:18 PM |
| Build Log New EPP VTPR kitbash: Le Cygne (The Swan) | surfimp | Slope | 26 | Mar 26, 2012 10:04 AM |
| Sold LE Weasel with Extras | Chickenfoot | Aircraft - Sailplanes (FS/W) | 1 | Nov 01, 2011 02:35 PM |
| White EPP Vs Black EPP | Red Baron | Slope | 19 | Sep 21, 2004 09:53 PM |
