Old Oct 02, 2012, 11:27 PM
Charles g is offline
Find More Posts by Charles g
Joined Oct 2012
Led
Hello, how is everyone? I was wondering if anyone knows if you can hook an led to Firebird Stratos and if so what kind ?
Thanks for your help.
Charles
Charles g is offline Find More Posts by Charles g
Old Oct 03, 2012, 12:08 AM
Piece is online now
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
You can use pretty much any type and any number of bulbs you want as long as you ensure that they're adequately powered. There are a few ways to do it. I think the easiest way with the Stratos would be to make up a parallel harness that goes between the battery and the ESC and have your LEDs wired to that so they're powered directly off the battery. Since the Stratos has a 2S lipo, you'd be best off running parallel sets of two 3V bulbs in series with a resistor to cut the voltage down a little so you don't cook them. I've run a lot of single 3V-rated LEDs directly off 1S lipos and they've worked fine, but LEDs will vary so it's probably best to run an inline resistor to be sure they're not being stressed too much.
Their brightness would fluctuate slightly with changes in throttle position (due to pack voltage sag), so if that's not something you want then you could also run them off a BEC unit wired in parallel with the ESC. This would strip the voltage down to about 5V, which would be easy enough to get to ~3-3.5V for the LEDs with resistors.
Piece is online now Find More Posts by Piece
Old Oct 06, 2012, 11:04 AM
rcflyinff is offline
Find More Posts by rcflyinff
rcflyinff's Avatar
United States, FL, Titusville
Joined Mar 2012
Sounds like you have a good understanding of power lights. I purchased a kit from headsuprc.com and planned on installing in my sons Dynam C-47 that has twin 30A ESC's. They suggested I buy a T-Plug to eliminate splicing, then connect a UBEC to that. From the UBEC I'm to connect the LED control that will in turn connect to an open channel on the receiver so I can actuate the lights from the TX. All sounds great, but looking at it further, the output wires on the UBEC have a receiver plug on it but there is nowhere to plug it into the LED control. So I was wondering, can I connect the LED control and the UBEC with a Y Harness and plug it into an open channel on the receiver? Any help would be appreciated. Thank you......Doug
P.S. He also has the Dynam SR22 that currently has a 30A ESC in it. If I upgrade to a 45A ESC, could I eliminate all of the above hassel and just plug the LED control into an open channel on the receiver? Thanks again.
rcflyinff is offline Find More Posts by rcflyinff
Old Oct 06, 2012, 04:54 PM
Renfield is offline
Find More Posts by Renfield
above us only sky
Renfield's Avatar
United States, SC, Greenville
Joined Jan 2006
Zeppelin
Renfield is offline Find More Posts by Renfield
Discussion LadyBird Qr SMD Led's mod, even more led's to come! croyal918 Multirotor Talk 6 Jan 13, 2014 08:15 PM
Sold HPI Baja 5 LED Light controller and two Baja led lights ronzer Cars - Trucks and Parts (FS/W) 0 Aug 16, 2012 11:46 PM
Discussion Flexible little LED Driver for 1W LEDs KTMRacr Night Flying 2 Aug 12, 2012 11:45 PM
Sold Turnigy LED strips - 60 LED's, 1 Meter sgomes Aircraft - General - Miscellaneous (FS/W) 2 May 13, 2012 05:56 PM
For Sale T-Rex 500 LED tail blades and Main blade LED's. TMASTER Aircraft - Electric - Helis (FS/W) 2 May 08, 2012 07:30 PM
