Old Oct 11, 2012, 01:16 AM
KE your cub.
Curare's Avatar
in the gutter, again....
Joined Jun 2005
I bought mine recently from cox international (ex xenalook)
Curare is offline Find More Posts by Curare
Old Oct 11, 2012, 09:37 AM
RknRusty's Avatar
United States, SC, Columbia
Joined May 2010
Whatever tool you have, the most important way to not mushroom the crown is to place your reset tool on a hard surface. Placed on a smooth surfaced anvil on a concrete floor is good. An anvil on a wooden table won't do as well. You have to have the tool supported on something that won't flex at all. Test your cylinder fit and check the SPI gap to make sure it has not closed up any. This happens sometimes.
Practice on an old worn out piston first because you have to get the feel of how hard to tap and how many taps it takes.
RknRusty is offline Find More Posts by RknRusty
Old Nov 12, 2012, 11:38 AM
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
Cleaning castor oil varnish from cylinder wall is also needed when motor tightens up. I twirled a dowel wrapped with fine steel wool and toothpaste by hand and cleaned residue carefully with fuel and paper towel.
E-Challenged is offline Find More Posts by E-Challenged
Sold OS 61 RF ABC Pump with Performance Specialties Piston & Liner set and header LCS Aircraft - Fuel - Engines and Accessories (FS/W) 1 Jul 18, 2012 07:44 AM
Found Screw set and piston pin retainers for OS 10 FP SLOPERDUDE Aircraft - Fuel - Engines and Accessories (FS/W) 2 Mar 03, 2012 01:06 PM
Discussion You're spending too much time on RCG when ktmrider Mini Helis 9 Apr 12, 2007 03:50 PM
What happens when motor is re timed? jhamm Power Systems 7 Jun 19, 2003 05:59 PM
