Old Oct 02, 2012, 05:59 PM
Rick~K is offline
Find More Posts by Rick~K
Rick~K's Avatar
United States, WV, Salt Rock
Joined Nov 2006
Help!
Futaba 10CG Servo End Point help needed
Hello Everyone,
I need a little help on adjusting my "End Points" on my radio. I can find all the main channel adjustments but not on the Aux-Ch's, I have one of my Ch's set up on the lever switch (VR (E) ) but can't find where to adjust it, I've looked in the manual also. I can find them for the toggles and sticks but not knobs and lever switches.
Thanks!
Rick~K is offline Find More Posts by Rick~K
Old Oct 03, 2012, 09:52 AM
krysta is offline
Find More Posts by krysta
Champaign
Joined Apr 2003
Are you in 7ch mode or 10ch mode in your transmitter?
Sincerely,
Krysta
Product Development & Support Specialist
Futaba Service Center USA
service@futaba-rc.com
Originally Posted by Rick~K View Post
Hello Everyone,
Thanks!
krysta is offline Find More Posts by krysta
Old Oct 03, 2012, 10:01 AM
Rick~K is offline
Rick~K's Avatar
Joined Nov 2006
Sincerely,
Krysta
I'm not sure, it shows 8 ch in window and am able to adjust "gear" and toggle sw, just not levers or knob
Old Oct 03, 2012, 12:29 PM
krysta is offline
Champaign
Joined Apr 2003
On the main screen in the upper right hand corner directly below 2.4G, it should say either 7ch or 10ch.
But either way, in either 7 or 10 channel, when you go into the End point screen, toggle down to your Aux channel, it should show L or H, if you have that channel set to a dial. You should then be able to turn the appropriate dial or move the appropriate slider to adjust both sides of the end points.
What are they set to in your Aux channel menu?
Also, have you tried going into a blank model to see if you can set the end points in a completely new model?
Sincerely,
Krysta
Old Oct 03, 2012, 02:08 PM
pilotpete2 is offline
Find More Posts by pilotpete2
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
Rick,
Are you trying to use either channel 9 or 10 for this function? These channels do not have an endpoint or sub-trim adjustment, as they're only switched on/off channels.
Pete
pilotpete2 is offline Find More Posts by pilotpete2
Old Oct 03, 2012, 02:51 PM
Rick~K is offline
Rick~K's Avatar
Joined Nov 2006
Ok, That worked.. Thanks!!! I was setting my Ch8 that was Aux8 on end point adjustment. I was thinking that was one of my NAZA gain adjustment ch's but they are Ch6&7. I'm new to this radio, my first Futaba since my J series in the 80's and I'm using it for UHF... love the Radio.
Thanks Again Krysta and Pete!
Old Oct 09, 2012, 04:51 PM
Rick~K is offline
Rick~K's Avatar
Joined Nov 2006
Krysta, or anyone
Is there a way to disable 2.4 transmit on the 10CG? I'm using it for EZUHF and the manual for UHF says to disable the transmitter (10CG) so both UHF and 2.4 is not transmitted at the same time.
Thanks!
Old Oct 09, 2012, 05:53 PM
pilotpete2's Avatar
Joined Jun 2004
It's covered on page 17 of the manual. It's the option just below the range test power down option
Pete
Old Oct 09, 2012, 05:54 PM
Rick~K is offline
Rick~K's Avatar
Joined Nov 2006
Pete
Thank You Pete!
Question Tail Servo Arm / Gyro / End-Points Blade Crasher Electric Heli Talk 1 Sep 28, 2012 07:28 AM
Question Hitec servo programming, center and end points tb47 Radios 4 Jun 24, 2012 07:30 PM
Discussion Need Help! Futaba 10CG 2,4 hypstar Radios 7 Jun 07, 2011 10:13 AM
Help! Futaba 10CG - problem with end point adjustment Szymon Bartus Radios 0 Sep 01, 2010 04:14 AM
Discussion Futaba 12FG: Relationship between Servo Travel and End Point heliatom Radios 1 Apr 04, 2010 10:04 PM
