Old Oct 02, 2012, 05:40 PM
Tom Z is offline
Find More Posts by Tom Z
RC Reviews & Tx Setup Guides
Tom Z's Avatar
United States
Joined Sep 2007
New Product
Astroid Designs High Performance Motor/ESC Upgrade Kit for Walkera Genius CP/Mini CP
Tom Z is offline Find More Posts by Tom Z
Old Oct 02, 2012, 05:56 PM
dkfuji is offline
Find More Posts by dkfuji
RC Helis: My Healthy Obsession
The OC, California
Joined Feb 2007
Nice job on your review Tom. Looks like I may have to upgrade my MiniCP after all. LOL
dkfuji is offline Find More Posts by dkfuji
Old Oct 03, 2012, 06:16 AM
Masen72 is offline
Find More Posts by Masen72
Übernewbie eager to learn
Sweden, Skåne County, Malmö
Joined Jun 2012
Subscribed...
Nice job, Tom!
I'll hang around for the Mini CP flight times.
Masen72 is offline Find More Posts by Masen72
Old Oct 03, 2012, 04:42 PM
Tom Z is offline
Tom Z's Avatar
United States
Joined Sep 2007
Originally Posted by Masen72 View Post
Nice job, Tom!
Thanks guys.
I just added results for the mini cp helicopter with the mini cp main gear that covers headspeed, thrust, and flight times.
I now have tested the mini cp helicopter with the genius cp main gear and the mini cp main gear using the 8T pinion.
My personal preference is the mini cp and genius cp main gear.
Dylan's preference is the mini cp and the mini cp main gear.
We are both using the 8T pinion.
Tom
Old Oct 04, 2012, 02:51 AM
Dylwad is offline
Find More Posts by Dylwad
Dylwad's Avatar
Phoenix,Arizona, United States
Joined Jun 2002
Good review Tom!
Quick note about the error message in BLheli setup software, its most likely because your ESC is flashed with Blheli V7, and your using BLheli setup V6.11.
V7 has more programming options than 6.11, mainly just that you can now adjust beep volume and adjust the volume and delay time on the lost model alarm, or Beacon as its called in the software. A few other changes were more for Multi rotors and airplanes.
Each time Steffan Skaug (creater of BLheli) makes an update, Achim (4712 on HF, creator of Blhelisetup software) has to make an update as well to match the firmware.
Dylan
Dylwad is offline Find More Posts by Dylwad
Old Oct 05, 2012, 08:49 PM
Razors edge 29 is offline
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
Does that oversky 7mm motor help prevent blowouts on stock mcpx?
Razors edge 29 is offline Find More Posts by Razors edge 29
Old Oct 05, 2012, 09:59 PM
Tom Z is offline
Tom Z's Avatar
United States
Joined Sep 2007
I haven't tried in on my mCPX stock or BL but from the posts I saw for the 4G3 tail motor it performs much better than the stock tail motor.
The 7mm tail motor is comparable performance to the Walkera 4G3 tail motor.
Maybe Dylan can answer this better for you as he sells the 7mm motor for the mCPX.
http://astroid-designs.myshopify.com...7mm-tail-motor
Tom
Old Oct 05, 2012, 10:02 PM
QuAd FaNaTiC
Canada
Joined Aug 2009
Old Oct 10, 2012, 08:09 AM
Tom Z is offline
Tom Z's Avatar
United States
Joined Sep 2007
Update 10/10/12
I just found out some more information on the kit and posted it in the review under "Update".
Also Dkfuji is being sent the upgrade kit to test out.
We will be comparing our results and he will be testing the 8T and 9T pinions.
Tom
Old Oct 14, 2012, 04:03 PM
Crasy666 is offline
Find More Posts by Crasy666
Crasy666's Avatar
Germany, BY, Nord
Joined Oct 2012
Hi,
I have the Hobbyking ESC, which is the Same as the Oversky 10a but for the MCPx , which FW did you Flash?
Rgds
Crasy666
Crasy666 is offline Find More Posts by Crasy666
Old Oct 14, 2012, 10:33 PM
Tom Z is offline
Tom Z's Avatar
United States
Joined Sep 2007
Hi,
My ESC firmware is Blheli V7.
Tom
Old Oct 15, 2012, 05:23 AM
Crasy666 is offline
Crasy666's Avatar
Germany, BY, Nord
Joined Oct 2012
and you used the XP7A .hex file correct? since there is no special xp10a version availbale here
Regards
crasy666
Old Oct 15, 2012, 06:35 AM
Tom Z is offline
Tom Z's Avatar
United States
Joined Sep 2007
My ESC came with the Blheli V7 so I didn't have to flash it.
You can flash the ESC with the BLHeli-Setup 7.0.0.1. It has the hex file in it.
Press the button FlashBLHeli, then press OK. For my ESC the program
knows I already have the Blheli V7 installed and it asked me to continue anyway.
Tom
Old Oct 15, 2012, 09:37 AM
RaymondM is online now
Find More Posts by RaymondM
Multirotor Promotor
RaymondM's Avatar
United States, MI, Cadillac
Joined Apr 2011
subscribed
RaymondM is online now Find More Posts by RaymondM
Old Oct 16, 2012, 03:04 AM
Crasy666 is offline
Crasy666's Avatar
Germany, BY, Nord
Joined Oct 2012
thank you for your fast and valuable answer. now, the shipments from Asia need to arrive here in Germany, (hopefully without delay by the German customs) so I can check it my self.
I will keep you posted if that upgrade of the cheap Hobbyking ESC works, so perhaps a good option for upgrading only the main motor with a C05M and 10A ESC for only ~ 33 USD with shipping...
Regards
Discussion Blade Mcpx v1 v2 vs Walkera Mini Cp vs Genius Cp vs solo pro 100 3d f.a.r.m.e.r Micro Helis 134 Mar 30, 2016 10:51 AM
Rant Walkera genius cp brushless upgrade kit problem Bigde Micro Helis 14 Jan 24, 2016 11:15 AM
Wanted Want Mini CP / Genius CP / m CP X v2 for trade / cash GrandpappyToke Aircraft - Electric - Helis (FS/W) 2 Jul 07, 2012 07:18 PM
Sold Walkera Genius CP/Mini CP brushless motors RawmadeCF Aircraft - Electric - Helis (FS/W) 0 May 04, 2012 12:33 AM
