Old Oct 02, 2012, 04:59 PM
Z06 Tony is online now
Find More Posts by Z06 Tony
Z06 Tony's Avatar
United States, NY, Rochester
Joined Sep 2008
Build Log
Rc-Drones KongSix-6S 650mm 6 cell Y6
This build log is for a Rc-Drones KongSix 650mm 6s Y6.
It will be a mini beast.
Here is a list of what will be used:
CarbonCore 650mm Y6 Foldable CF Frame
DJI Wookong-M Flight Controller
Rc Tiger Motors MT3515-15 Motors
Graupner 14"x8 Props
Turnigy Plush 40a ESC's
Dual Distribution boards
Dual Hyperion 5000mAh 45c 6S Lipos
Z06 Tony is online now Find More Posts by Z06 Tony
Site Sponsor
Old Oct 03, 2012, 10:11 AM
Z06 Tony's Avatar
Joined Sep 2008
1st step is to epoxy all the blind nuts in.
Please note this is a kit I had sitting for a while for this build so the blind nuts were not installed.
ALL CarbonCore frames purchased from Rc-Drones will come with the blind nuts already installed in the arms.
Site Sponsor
Old Oct 04, 2012, 12:56 PM
Z06 Tony's Avatar
Joined Sep 2008
Next step is to mark the motor wires since they are not color coded.
Then I mount the motors to the motor plates and then togeather using the standoffs.
I also cut off the bullet connectors and mounted the prop adapters to the motors.
Site Sponsor
Old Oct 04, 2012, 06:56 PM
Z06 Tony's Avatar
Joined Sep 2008
Next I mount the motors/mounts to the arms.
Then I install the 4 long standoffs to the top of the bottom plate.
After that I install 6 short standoffs to the bottom of the bottom plate for the dual battery trays
Site Sponsor
Old Oct 08, 2012, 01:06 PM
Z06 Tony's Avatar
Joined Sep 2008
next I mounted the arms to the botom plate.
Then I mounted the LG
Next step was to attach the dual battery trays.
Site Sponsor
Old Oct 08, 2012, 02:05 PM
helidex is offline
Find More Posts by helidex
New Zealand, Hawke's Bay, Napier
Joined Jun 2011
Hi, watching your build with interest. I am planning a similar build. The objective is maximum stability / long flight time for Aerial Photography in windy conditions.
I get what you say about X8 but I can only afford Nazza + gps / in Y6 for now. I presume X8 is not just a quad with 2 motors on each leg.
I have a Sony NEX 5 , so payload should not be an issue.
What if any difference is there between Wooking and Nazza in terms of stability?
Does anyone use the Nazza to stabilise a gimbal successfully?
Do you have any reasonable cost + good performance gimbal + stabiliser suggestions?
helidex is offline Find More Posts by helidex
Old Oct 08, 2012, 02:13 PM
UAVProducts is offline
Find More Posts by UAVProducts
United States, MI, Goodrich
Joined Mar 2004
Tony,
What do those Tiger motors weigh? Are they heavy?
Nice build.
UAVProducts is offline Find More Posts by UAVProducts
Old Oct 08, 2012, 02:45 PM
Hellsiege is offline
Find More Posts by Hellsiege
Staying Frosty
Hellsiege's Avatar
United States, CO, Colorado Springs
Joined Feb 2008
Interesting - subscribed
Hellsiege is offline Find More Posts by Hellsiege
Latest blog entry: Construction Projects - Updated
Old Oct 08, 2012, 03:32 PM
red1one is offline
Find More Posts by red1one
red1one's Avatar
United States, MI, Ann Arbor
Joined Mar 2012
Tony -hello. Couple of questions re: your Y6 build. How much does boom length impact the stability during flight? I see everything from 650 mm all the way up to 1200 mm. Obviously a larger frame allows for larger props Which with the right motor/esc combo could provide much more lift for heavier applications. Do you ever build with lower pancake-style kv motors with larger props (good idea or bad for heavier lift)?
Regarding flight times, I currently run a MK Octo with 770 kv motors and 11 x 4.7 apc props. I know it not an ideal efficient set- up, but with a single 4s 4400 25c battery I'm getting 15.5 minutes flight time with a GoPro2 and everything is cool to touch when I land. I'm flying very simple and soft patterns for real estate. I've read many posts indicating for long term battery life, it's best to not run above 80% of battery capacity. Since I'm only running singles, I typically run 90-93% capacity and have run the math. Yes, I decrease over all battery life by about 20-23%, but based on my frequency of paying jobs, it's easier to just get new batteries every few months. That was an easy business decision. I'm planning on switching over to Vislero 4s 6600 flat batteries to save space. I will post the results once I get them.
red1one is offline Find More Posts by red1one
Old Oct 08, 2012, 04:11 PM
Z06 Tony's Avatar
Joined Sep 2008
You can run an X8 as a quad and split the motor signals to run 8 motors but I use all 8 motor outputs.
Not sure if there is a big difference in stability between a WKM and Naza.
I feel the WKM has better camera stabilization and will soon have the OSD and 5.8 TX/RX option.
Yes I have used a Naza to stabilize in many builds I have done.
Sorry I do not ship International but check with Gary on the AG550-NX V2 gimbal if it will work for you.
It is my favorite gimbal right now.
He ships International.
Site Sponsor
Old Oct 08, 2012, 04:12 PM
Z06 Tony's Avatar
Joined Sep 2008
Originally Posted by UAVProducts View Post
Tony,
Nice build.
They are heavy and weigh almost double what the Avrotos weigh.
They weigh 189g.
Site Sponsor
Old Oct 08, 2012, 05:21 PM
nighthawk117 is offline
Find More Posts by nighthawk117
United States, MA, Hadley
Joined Oct 2006
When will the frame be back in stock ? Thanks
nighthawk117 is offline Find More Posts by nighthawk117
Old Oct 09, 2012, 02:33 AM
helidex is offline
Joined Jun 2011
[QUOTE=Z06
He ships International.[/QUOTE]
Thanks for that - can you supply link for "Gary" i cant figure who you mean
Old Oct 09, 2012, 05:17 AM
MCrites is offline
Find More Posts by MCrites
I never finish anyth
United States, TX, Houston
Joined Jan 2012
http://www.rcgroups.com/forums/showthread.php?t=1582036
Their website is www.tppacks.com. I own a AG550v2 and it's amazing.
MCrites is offline Find More Posts by MCrites
Old Oct 09, 2012, 12:09 PM
Z06 Tony's Avatar
Joined Sep 2008
Sorry I do not have an ETA yet.
Hopefully soon.
Site Sponsor
Build Log Rc-Drones HexaKong 650mm HexaCopter w/AG550-NX Gimbal Z06 Tony Multirotor Talk 7 Jul 17, 2012 02:31 PM
Sold Carbon Fiber 650mm Foldable Y6 Blucross Aircraft - Electric - Multirotor (FS/W) 4 May 24, 2012 08:22 PM
Sold RC-Carbon 650mm Y6 frame with GoPro mount Sid3ways Aircraft - Electric - Multirotor (FS/W) 22 Aug 19, 2011 07:24 PM
Sold RC Carbon 650mm Folding Y6 RTF w/CF GoPro Mount Z06 Tony Aircraft - Electric - Multirotor (FS/W) 5 Jun 24, 2011 11:48 AM
Sold RC Carbon 650mm Folding Y6 RTF w/CF GoPro Mount Z06 Tony Aircraft - Electric - Helis (FS/W) 0 Jun 23, 2011 08:00 PM
