Old Oct 02, 2012, 03:07 PM
MaRcIu is offline
Find More Posts by MaRcIu
Joined Oct 2012
can I charge a 1s lipo with usb charger (used for phone with lipo)
hello I have a rc system 1s 3.7v 1200mah and it takes 2h and 30m to charge with rc system charger (output 4.2v. 500mA)
and I noticed my usb charger and wondering if I can charge it with usb charger... see in attachments.
thanks
MaRcIu is offline Find More Posts by MaRcIu
Old Oct 02, 2012, 03:47 PM
minbari is offline
Find More Posts by minbari
minbari's Avatar
Joined Jul 2012
not unless you have a USB compatable lipo charger to plug the usb into.
a "USB charger" is nothing but a power supply. it supplies 5V and 1A in the case of that one. there are no smarts in that supply to know how to charge a battery or when to stop. when you plug one of those into your phone, the phone has the charger built in.
minbari is offline Find More Posts by minbari
Old Oct 02, 2012, 04:14 PM
MaRcIu is offline
Joined Oct 2012
exactly what I thought but my only question is if I can charge it without harm the battery with that voltage.
I would calculate the estimated time to charge and unplug before.
as the connector I can solder one to those wires. I could even fabricate a "false battery" and charge the battery directly from the phone.
I want this just for when I can't wait 2 and half hours.
but yeah it's safer using the intelligent charger. I test the helicopter and runs out of power in 11minutes damn this is hard to wait lol
Old Oct 02, 2012, 04:31 PM
minbari is offline
minbari's Avatar
Joined Jul 2012
I wouldnt do it. you might not do it any harm the first time, but you only have to be off a little and you will start doing damage over time.
not only that, the USB supply will go to full out current when you plug that in. good posibility you will just melt the supply
Old Oct 02, 2012, 04:47 PM
MaRcIu is offline
Joined Oct 2012
ok I will follow your good advice! thanks!
Old Oct 02, 2012, 07:03 PM
Gedexas is offline
Find More Posts by Gedexas
CP heli ≠ 3D heli
Gedexas's Avatar
United States, NJ, Point Pleasant Beach
Joined Mar 2009
Just to clarify: A fully charged LiPo is 4.20 volts, a 5 volt power supply will feed that battery past it's 4.2 volt limit and the battery will start to heat up, puff, smoke and, eventually, catch fire.
A good charger is always cheaper than rebuilding a burned down home.
Gedexas is offline Find More Posts by Gedexas
Question Can I charge a LiFe Tx batt. with a basic Lipo charger? Just4parts Batteries and Chargers 5 Jun 03, 2012 02:09 PM
Question Can multiple 1s (mSRx) LiPo's be charged from a Swallow 2 charger Muttlee Batteries and Chargers 2 May 31, 2012 11:13 PM
Discussion Can i use my lipo charger to charge my phone? vvV FANG Vvv Australia 9 May 20, 2012 04:03 PM
Discussion Can I charge my cell phone using LiPo and BEC ? muda Batteries and Chargers 6 Jul 17, 2011 10:38 PM
New Product PLD 10~150mA 1S lipo charger with USB (PLD-LICH-150) Inflexo Batteries and Chargers 0 Dec 14, 2010 01:44 AM
