This thread is privately moderated by Flyboy1958, who may elect to delete unwanted replies.
Old Oct 02, 2012, 03:52 PM
Flyboy1958 is offline
Find More Posts by Flyboy1958
Trader Rating: 8
United States, PA, Lancaster
Joined Sep 2008
Trader Rating: 8
Sold
Hitec HFP-10 Digital Servo Programmer and Tester $30 shipped
I bought this programmer to use with my Digital Hitec servos and it works great. I am now using the 79xx series high voltage servos and this programmer does not support the overload protection feature. I have since had to buy the HFP-20 programmer in order to use it with my high voltage servos.
The new HFP-20 uses a new board; it is not just a software update so the HFP-10 cannot be updated. You will however still be able to use the HFP-10 programmer with the new 79XX series servos but you will not be able to utilize the servo overload protection feature or reduce the resolution from High to STD if you want to program the servo travel for greater than 90 total degrees of travel.
Otherwise it is still a great little machine. It works with all brand name servos as far as testing them.
Features
■Aluminum case, with a LCD display.
■Adjustment knob, ON/OFF switch
■Uses an internal 1100mAh, 4.8V NiCd battery.
■Charge unit is located at the end of the unit.
■Designed for use with any overnight charger
■Programming Features: For Digital Servos:
Factory Default Resets
Fail Safe ON-OFF
Dead Band Width Adjustments
End Point
Directional Rotation
Neutral Point
Speed of Rotation
Fail Safe Point Preset
■Features for Standard Servos:
Checks any brand of servo with a Manual test and Auto scan.
Plus it will check the Pulse width and Voltage.
Checks the transmitter signal pulse as well.
Specifications
■Length: 5-1/2 (138mm)
■Width: 3" (76mm)
■Height: 1" (25mm)
Package Contents
■Hitec HFP-10 Digital Servo Programmer Tester 44410
■User Manual
I will include personal notes on the use of this programmer since I was unclear on the purpose and use of a programmer when I bought it. You will wonder why you haven't used a programmer on your digital servos after you find how usefull it can be.
I am asking $30 shipped CONUS only.
Paypal only.
Flyboy1958 is offline Find More Posts by Flyboy1958
Old Oct 02, 2012, 04:15 PM
joedoan is offline
Find More Posts by joedoan
Trader Rating: 118
United States, CA, Santa Ana
Joined Apr 2012
Trader Rating: 118
I'll take it.Please give me you paypal address.
Thanks.
Joe
joedoan is offline Find More Posts by joedoan
Old Oct 02, 2012, 04:21 PM
Trader Rating: 8
Joined Sep 2008
Trader Rating: 8
Check your PM.
Old Oct 02, 2012, 04:32 PM
crispypilot is offline
Find More Posts by crispypilot
Trader Rating: 102
United States, GA, Athens
Joined Jan 2012
Trader Rating: 102
Pm sent
crispypilot is offline Find More Posts by crispypilot
For Sale Hitec HFP-10 Digital Servo Programmer Tester livinma1 Aircraft - General - Radio Equipment (FS/W) 2 Aug 23, 2010 11:20 AM
For Sale Hitec HFP-10 Digital Servo Programmer Tester livinma1 Aircraft - General - Radio Equipment (FS/W) 0 Nov 29, 2009 10:52 PM
Sold Hitec HFP-10 Digital Servo Programmer and Tester bc-slowflyer Aircraft - General - Radio Equipment (FS/W) 0 Apr 27, 2009 11:37 PM
Off Site Hitec HFP-10 Digital Servo Programmer & Tester AggieFlyer Aircraft - General - Miscellaneous (FS/W) 0 Mar 11, 2008 07:08 AM
Off Site HFP-10 Hitec Digital Servo Programmer And Servo Tester Bill K. Aircraft - General - Radio Equipment (FS/W) 1 Jan 09, 2006 02:09 PM
