Ok, got it done - works great!
Another question: I left channel #1 (aileron right) on the master receiver, but am not plugging any servos into that spot. Channel #1 also appears on the slave receiver into which the right aileron servo is plugged. Is this ok? Is it simply a duplication of channel #1 on both receivers? Please advise. Thanks, Paul |
Lake Havasu, AZ
Joined Jun 2005
The Master/Slave functionality was strictly to add extra channels. |
Lake Havasu, AZ
Joined Jun 2005
I setup my planes with the two or more associated surfaces on the same receiver. So, for 3D planes I have one receiver for the ailerons and elevator halves, and another for the rudder rack, throttle, smoke, etc. |
Here is a thought. Fail safe has user and hold options. How about a third option of off. For the areas with ganged servos driving a surface connect each of the servos to a different Rx. If one Rx fails one of the ganged servos will need to be free wheeling to allow the working servo to continue operating in a degraded mode.
The Villages, Florida
Joined May 2003
That is why he is recommending that you split surfaces between receivers.... that is, in case one looses signal on one receiver the second receiver can be used to fly the plane.....Jim gave the example of loosing one aileron...... |
Lake Havasu, AZ
Joined Jun 2005
Lake Havasu, AZ
Joined Jun 2005
These are two separate receivers, not joined or sharing any info between them. |
Lake Havasu, AZ
Joined Jun 2005
over some of the servoes (if servo-config/failsafe are set correct). So it is better to have two Receivers then one..... ![]() Or what? |
I have noted that the two receivers started with people that were sponsored and had access to all the RX they wanted. Why then not use two RX and promote that. With two 72 mhz RX they would both have signal problems at the same time. But even with the 72 mhz RX how many RX have you ever seen just fail during flight.
Now with 2.4mhz I just don't have signal loss. Never seen a 2.4mhz RX fail in flight. (I always exclude Spectrum) That takes us to the battery. In my larger birds I always use two batteries with two connections to the RX. In the over 50 planes I own, with the latest, 2.4 mhz equipment, I have never had a problem. So my TF B-25, 50cc P-47, 50cc P-40, 100cc Extra, 50cc Extra, etc. all fly with one RX and two batteries. Please note that with all the multiple RX that Spectrum uses in some of their DSM2 stuff guys still lost aircraft. So more than one RX did not save the plane. Point is that all you really need is one GOOD 2.4mhz RX. IMHO |
| Thread Tools | |
| Question Two Nanos for a Big Plane - Two Rx Batteries? | FlyingW | Xtreme Power Systems | 16 | Oct 19, 2012 12:24 PM |
| Discussion how close can you install two nanos to each other? | rcfan450 | Xtreme Power Systems | 3 | Sep 26, 2012 10:31 AM |
| Found XPS XtremeLink® 2.4GHz 6 channel Nano E or Nano RX's two hope | jcstalls | Aircraft - General - Radio Equipment (FS/W) | 1 | Jun 30, 2012 04:58 PM |
| Sold Two NIP Pentium 60 ESC for EDF applications and two NIP Pentium 80 amp ESC | The Don | Aircraft - Electric - Jets (FS/W) | 5 | Jul 22, 2009 10:51 PM |
| Discussion mapping channel 2 to channel 8for elevators | 3ddd | Xtreme Power Systems | 5 | Sep 23, 2007 03:22 PM |
