Old Oct 02, 2012, 03:16 AM
LiftOff is offline
Find More Posts by LiftOff
Telford,Shropshire,England
Joined Jan 2003
Ccharging A123 cell on PL8
hi i`m trying to set up the pl8 to charge a 3 cell A123 battery
its a 1500mAh Life battery..
can anyone tell me what settings for the pl8
what volts should the cells be charged at etc ?
thanks
Alan
LiftOff is offline Find More Posts by LiftOff
Old Oct 02, 2012, 11:31 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Use Preset 8 or 9 if it has balancing leads and charge at 1.5A for the first few charges .
The battery should be marked as to max. charge rate. Some can be charged at 5C or greater.
If it does not have balancing leads then use Preset # 11 which is for 1-5 cells non balanced.
Cells will charge to 3.65 each and will settle down to approx. 3.45 after a few hours.
Charles
Old Jan 09, 2013, 04:19 PM
still4given is offline
Find More Posts by still4given
Sky Pilot
still4given's Avatar
Victorville, CA
Joined Jun 2006
Hi Guys,
I have purchased this battery;
http://www.hobbyking.com/hobbyking/s...ter_pack_.html
Charles answered one of my questions but I have another. This is a Tx pack and I am wondering at what voltage I should think about recharging? I just want to make sure I don't draw it down too far.
Thanks, Terry
still4given is offline Find More Posts by still4given
Old Jan 10, 2013, 06:12 AM
Southern Pride
Terry the discharge curve for a decent LiFePO4 is close to a flat line until it is 98% empty and for that reason it is difficult to say what LV point is safe in a Trans. application. Cells should be fine down to 2.5 or lower but Transmitter may nit be happy below 9.6 or 3.2 per cell id LiFePO4 is in fact a 3S. Not all RC transmitters are nonimal 8 cell Ni / 9.6V these days.
http://www.rcgroups.com/forums/showt...highlight=life
If it we me I would recharge at 10.0V note and record mAh required along with Trans. on time for that cycle.
FYI I tried LiFePO4 in Transmitter and then went back to Sanyo Eneloops as I much prefer thier noticeable discharge curve and many years of proven reliable performance plus convience of using OEM charger.
Charles
Discussion PL8 - Cell Over Voltage Press to Reset defxxx FMA Direct 2 Oct 04, 2012 08:43 PM
Discussion Different voltage readings between PL8 and cell log hlalibe FMA Direct 11 Aug 14, 2012 09:54 AM
Discussion Will my PL8 charge a 2 cell pack that has no balance tap? WBFAir FMA Direct 7 Jul 04, 2012 11:39 PM
Discussion Low voltage level for PL8 where it won't even see cell anymore? WBFAir FMA Direct 3 Jul 01, 2012 07:24 PM
Discussion New Cell technology from A123 learn2turn Batteries and Chargers 4 Jun 16, 2012 05:44 AM
