This thread is privately moderated by D_FAST, who may elect to delete unwanted replies.
Old Oct 01, 2012, 10:39 PM
D_FAST is online now
Find More Posts by D_FAST
D_FAST's Avatar
Denver CO
Joined Apr 2008
Build Log
SU-25/39 Frogfoot
Figured i would give it a go.
I'm going with a clarkym-18 @root 0 incidence and clarkym-15 @tip 2 degrees washout
Gonna try to get some landing gear on this one.Would be nice to get at or near 1-1
being they were known for taking off with more loadout weight then the aircraft weighed itself.
D_FAST is online now Find More Posts by D_FAST
Old Oct 02, 2012, 02:54 AM
D_FAST's Avatar
Denver CO
Joined Apr 2008
more model'd
next up... ducting
Old Oct 02, 2012, 09:39 PM
D_FAST's Avatar
Denver CO
Joined Apr 2008
SU-39 Variant
being pretty much one of the same.Im modeling in the 39 or 25Tprts as well.
Old Oct 02, 2012, 11:38 PM
D_FAST's Avatar
Denver CO
Joined Apr 2008
All data used was from the fsa calulator
Old Oct 08, 2012, 09:26 AM
D_FAST's Avatar
Denver CO
Joined Apr 2008
Well my brother got a hold of a dynam a-10 2x64.
So 2x 64 it is. Im still going to work on the single plan as well.
I tried my best to keep everything scale. The A10 its supposed to be bigger then the frogfoot,in length and wing span.
But there was no way i could squeeze 2x64mm into something scale in size to dynam's a-10.
Im not sure how they did it. I had to tweak both the intake and exhaust areas, as well as fatten the whole engine naccles upjust to make this work on 43in wing span.
Im using EPS with this build, its so much lighter then the home depots pink foam.
Im cut all sections at 1" but im using mixture of 1" ad 2" section cuts, example canopy/wing root/front engine nacelles well be 1" to capture the nice curves, the rest is 2"cuts
to make this work i need other empty airframe weight of around 14oz.
Im thinking of a built up wing on this one, and i want to do the full moving stab, but then there is the angle it sits on.
I've never built a wing in such manner so have no way to know how to cad it.
been plowing threw the forums searching for built up+ wing + construction,my head is spinning.
Build Log EPP SU-39 (modernized SU-25 Frogfoot) formerly: lets play "guess the plane" Mr. UD Foamy EDFs 42 Sep 07, 2015 11:01 AM
Question Ducting for EPP SUKHOI SU-39 (~SU-25 Frogfoot) Mr. UD Scratchbuilt EDFs 8 Oct 15, 2011 01:26 PM
Question Su-25 Frogfoot.... got any plans? birdlives1955 Foamies (Scratchbuilt) 7 Feb 28, 2011 08:28 AM
su-25 frogfoot Robbie d Electric Ducted Fan Jet Talk 7 Dec 03, 2009 11:02 AM
Help! Steve Griffiths Su-25 Frogfoot Windknot Slope 7 Sep 07, 2008 09:28 AM
