Old Oct 01, 2012, 09:22 PM
GRIPDOG is offline
Find More Posts by GRIPDOG
Las Vegas
Joined Apr 2012
Question
OS 95 or 1.20?
Iím either going to get a new OS 1.20 or a OS 95. for the 9lbs. Edge 540 Iím building.
Is there a big difference in fuel consumption between the two engines.
GRIPDOG is offline Find More Posts by GRIPDOG
Old Oct 02, 2012, 09:39 AM
GRIPDOG is offline
Las Vegas
Joined Apr 2012
Thanks for all your replys. Guess I'll go with the 1.20
Old Oct 02, 2012, 10:16 AM
I TOBOR is offline
Find More Posts by I TOBOR
I TOBOR's Avatar
Joined Feb 2007
Grip, how about some sound late advice, when in doubt, pick more cubic inches, it works every time.
I TOBOR is offline Find More Posts by I TOBOR
Old Oct 02, 2012, 11:16 AM
GRIPDOG is offline
Las Vegas
Joined Apr 2012
Will do. Thanks Tobor.
Old Oct 02, 2012, 11:21 AM
Gary Cee is offline
Find More Posts by Gary Cee
The best stuff is higher up
Gary Cee's Avatar
Joined Apr 2010
The OS 95 is still only around in small numbers but all the tests say it is a fine engine . Check the weight difference . If your plane winds up tail heavy , the added weight of a bigger lump may be OK . It the plane is already nose heavy weight may be a detriment. Bigger engines often shake a bit more as well as the requirement for a heavier fuel load . Some planes fly well "on the wing" others make better use of a bit more power . The Edge can probably make good use of more power so long as the weight/balance issues are resolved first .
Sometimes it takes a bit more than 24 hours for people to offer advice . It is free after all .
Gary Cee is offline Find More Posts by Gary Cee
Old Oct 03, 2012, 08:25 PM
KaP2011 is offline
Find More Posts by KaP2011
KaP2011's Avatar
United States, GA, Calhoun
Joined Jun 2011
I just got a new OS 95v the other day and based on the manual it should be pretty good on fuel consumption. The manual states that a 10oz tank should last 12-15 min. However, if I had a 9lb Edge 540 I would go with the 120.
KaP2011 is offline Find More Posts by KaP2011
Old Oct 07, 2012, 11:44 AM
LowlyElevated is offline
Find More Posts by LowlyElevated
Because I was INVERTED
LowlyElevated's Avatar
United States, FL, DeLand
Joined Sep 2012
Never had any experience with the 95s, but I do have one of the older pre-fix 91s. I stuck a .46 needle vavle on it 4 months ago and now it it starts on the first spin witht the starter every time. It will pull my 60 size u-can-do vertical all day.
However, It refuses to run on anything I have tried but a 14-8 prop. That is the magical ticket, it seems.
LowlyElevated is offline Find More Posts by LowlyElevated
Latest blog entry: More Miniquad FPV!
Sold Two OS FS 1.20 Engines. 1 Surpass 1 non-Surpass C_Watkins Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jun 01, 2012 03:54 PM
Wanted I need a pipe & muffler for a YS 1.20, OS 1.20, & Saito 1.20 stevster Aircraft - Fuel - Engines and Accessories (FS/W) 0 Oct 04, 2010 12:45 AM
Found OS 1.20 or a Saito 1.20 for my T-34 tigermike Aircraft - Fuel - Engines and Accessories (FS/W) 3 Mar 15, 2009 02:18 PM
Found Cash waiting for K&B 20, OS FS 20 or 26, Fox 15 or other small engines arukum17 Aircraft - Fuel - Engines and Accessories (FS/W) 10 Nov 17, 2007 10:33 AM
Wanted Webra 1.20 or OS 1.60 trade for Quadra 35cc GAS jhicks Aircraft - Fuel - Engines and Accessories (FS/W) 5 Apr 11, 2006 06:20 AM
