Old Oct 01, 2012, 08:25 PM
caotri is offline
Find More Posts by caotri
Hochiminh City
Joined Mar 2004
Monster Octo Copter 1100mm M2M
Hi friends,
It has a big even coming in urgent and support friend, I have to stop the Quad Copter build for FoxtechFPV 48-22 motor test in two days for this project The Monster Octo with 1100mm M2M. Sorry FoxtechFPV for this delay, the 48-22 quad will be started back today and be finishing by tomorrow.
The target of this project: Monster Octocopter 1100mm M2M is build a giant heavy octocopter which can carry the 5DMAX2 or even sony FS100 for Air Video production.
The configuration of this copter:
- Kit DIY carbon fiber with 2mm carbon plate and 21.5mm carbon tube from 600 size helicopter tail boom. The Plastic Boom Block is also Home make. Kit will be 1100mm Motor to Motor in size.
- Flycontrol is K-Woong DJI firmware 5.08 since the 5.12 seem to have problems with Octo config.
- Motor Tiger MT-3515 400Kv with 15x5" carbon props, driving by Hk F-40A ESC reflask with Simonk firmware at 5S 6000mAh x 2 packs.
-Camera Gimbal will be Cinestart with cinestar Freefly Gimbal control for Roll and Pitch. The YAw will be control by Futaba GY- 240 headlock gyro.
Some pictures of build process to shared with you all, please give advise to help this project.
The ESC and power distributed board assebply, This ESCs are very easy to ReFlask since the programing port is in line with round dot so easy to make connection for reflash. These has been reflash with Simonk firmware version Jun 2012. Thansk Simonk for loverly firmware.
Tope view
Final image , need to place Props on for ready to maiden Waitting for the bad raining weather gone ...
More details at http://ngcaotri.blogspot.com/2012/10...100mm-m2m.html All comment and suggestion for better buil are welcome and thanks.
First maiden video
Octo size 1100 (1 min 33 sec)
the second is on uploading
caotri is offline Find More Posts by caotri
Old Oct 03, 2012, 04:27 AM
brodjack is offline
Find More Posts by brodjack
usual old know-it-all
Blackpool,U.K.
Joined May 2005
crikey,what a monster
brodjack is offline Find More Posts by brodjack
Old Oct 03, 2012, 08:47 AM
prodriverex is offline
Find More Posts by prodriverex
The Engineer
prodriverex's Avatar
Singapore
Joined Dec 2009
Cool! I can copy some details here for my built next, also to carry 5D..
Since you are doing motor test for the 4822, are you testing the thrust and efficiency? Are you doing also for this monster's Tiger MT3515? Would like to know what is result like..
i plan to use 6S.. Is there any motor and ESC match with your experience?
prodriverex is offline Find More Posts by prodriverex
Old Oct 03, 2012, 08:49 AM
The Engineer
Singapore
Joined Dec 2009
Originally Posted by caotri View Post
Hi friends,
Tope view
First maiden video http://www.youtube.com/watch?v=hpzPCU_-oG8
And i see carbon props! Holy!
Old Oct 03, 2012, 09:58 AM
caotri is offline
Hochiminh City
Joined Mar 2004
The other clip of maiden after the call stop
Octo size 1100 part 2 (1 min 3 sec)
I will do all the load test and flight time test.
The T3515 also good in 6S but I like the 5S with big carbon props :-)
I will update new test video and also load test by this weekend when I got time.
I do test the W48-22 also , the quad is ready but the weather .
This kit is 3.75kgs without battery anf the gimbal.It flys 20 minutes with 2 packs of 5600mAh 5S 25C GenAce make total flight weight of 5.3kg. I will do full load test by this weekend. The monster is on the way to DALAT city for some waterfall video capture.
Old Oct 03, 2012, 01:47 PM
brodjack is offline
Blackpool,U.K.
Joined May 2005
amazing stability,just looks suspended in mid air
Old Oct 03, 2012, 08:40 PM
caotri is offline
Hochiminh City
Joined Mar 2004
Thanks for view and comments
Old Oct 04, 2012, 10:02 AM
TayNinh68 is offline
Find More Posts by TayNinh68
Mosquito 6
Joined Jun 2012
Awesome build there amigo .. just need a hook for the beerlift ehh
TayNinh68 is offline Find More Posts by TayNinh68
Old Oct 04, 2012, 10:57 AM
caotri is offline
Hochiminh City
Joined Mar 2004
Thanks, it will have a beer bottle on each arm for load test this weekend :-)
Old Oct 09, 2012, 08:37 PM
The Engineer
Singapore
Joined Dec 2009
Caotri, how the the weekend test gone? Any beer showering?
Old Oct 12, 2012, 05:10 AM
caotri is offline
Hochiminh City
Joined Mar 2004
i did test last fews day with 0.75L bootle on each arms the octo can take off ok and fly well. The esc and motor do not get even warm but the battery 5s 5200mah 25C from genace get hot. actually the genace i boght this time is bad . i bought 6 packs, one die when they arrived, the other die after 2 rounds. I will take this octo to An Giang province for video take this week and will try the 6s 35C 5000mahs Pulse battery from our trex 700. The gimbal is 3D cinestars and D7000 camera.
Old Oct 12, 2012, 05:28 AM
The Engineer
Singapore
Joined Dec 2009
Congrats! Batt issue easy to resolve. Wish you all the best!
Have you measure the power & current consumption on take off, full throttle and hover? It will need telemetry to record them tho..
Old Oct 12, 2012, 10:24 AM
Mosquito 6
Joined Jun 2012
Great idea Pro .. there is one vendor that makes both an on-board data logger and an OSD .. forget which maker, but for such an awesome build, certain justified I think.
@caotri .. surprised you used the booms for lifting .. I'm guessing close to the body. Eight times 0.75 liter is 6 Liters .. that's 6 Killograms amigo, plus the tare of the bottles. No wonder the battery got warm .. LOL Sure would be interesting to know your grams per watt with that monster Nice goin'
Old Oct 12, 2012, 10:29 AM
The Engineer
Singapore
Joined Dec 2009
Eagle Tree System
Old Oct 12, 2012, 11:02 AM
Mosquito 6
Joined Jun 2012
Eagle Tree System
Ahh yes .. that's the one. If he can carry 6kg of water .. no problem for lift overhead
Discussion OCTO Copter mounirzoorob Multirotor Talk 42 Jul 20, 2012 06:57 AM
For Sale Y6 CarbonFiber frame (32cm M2M) Korken Aircraft - Electric - Multirotor (FS/W) 5 Apr 30, 2012 06:43 AM
Wanted Hex/octo copter frame Vyas Aircraft - Electric - Multirotor (FS/W) 0 Feb 22, 2012 10:28 PM
Sold X8 Octo copter KKMulticopter nicnaimless Aircraft - Electric - Multirotor (FS/W) 9 Jul 20, 2011 04:05 PM
Sold SUPER STABLE ARTF 15" M2M Quad Z06 Tony Aircraft - Electric - Multirotor (FS/W) 7 Jun 08, 2011 02:22 AM
